    Bed Heating SSR
    Firmware installation
    282
    • chris974M
      chris974M last edited by
      Bonjour je voudrais une aide pour mon bed please
      J'ai une thermistance NTC 100K 3950 1750w temperature 150c brancher sur Relais à Semi-Conducteurs Monophasé DC-AC SSR-40DA 40A comment je dois le configurer dans le firmware ?
        Hello I would like help with my bed please I have a NTC 100K 3950 1750w temperature 150c thermistor plug into Single Phase DC-AC SSR-40DA 40A Solid State Relay How do I configure it in the firmware?
        Connect the control side of the SSR to the duet heater you want to use, and then configure the heater and thermistor as usual.
        M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
        M143 H0 S150 ; set temperature limit for heater 0 to 150C
        • chris974M
          Thanks for your answer but i d'ont have the bed temperature in my web control
            Please confirm your firmware version and DWC version and post your configuration.
            Verify your wiring as well.
            • chris974M
              RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later + DueX5
              Board ID: 08DLM-996RU-N8PS4-6JKD8-3S06T-KBVRN
              Used output buffers: 3 of 24 (8 max)
              • chris974M
                My wiring is OK
                  Phaedrux Moderator @chris974M last edited by
                  @chris974M said in Bed Heating SSR:
                  version 2.05.1
                  In that case the code snippet I gave is incorrect because it is for version 3.
                  Please post your entire config.g
                  • chris974M
                    ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sat Oct 03 2020 15:26:33 GMT+0200 (heure d’été d’Europe centrale)
                    M550 P"MonsterPrinter" ; set printer name
                    M552 S1 ; enable network
                    M586 P0 S1 ; enable HTTP
                    M586 P1 S0 ; disable FTP
                    M586 P2 S0 ; disable Telnet
                    M569 P1 S0 ; physical drive 1 goes forwards
                    M569 P5 S1 ; physical drive 5 goes forwards
                    M569 P6 S1 ; physical drive 6 goes forwards
                    M569 P7 S0 ; physical drive 7 goes forwards
                    M584 X0:5 Y1:6 Z2:7 E3 ; set drive mapping
                    M92 X100.00 Y80.00 Z400.00 E420.00 ; set steps per mm
                    M566 X900.00 Y1400.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
                    M203 X9000.00 Y9000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
                    M906 X800 Y1950 Z1400 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
                    M84 S30 ; Set idle timeout
                    M208 X-6 Y-10 Z0 S1 ; set axis minima
                    M208 X780 Y510 Z350 S0 ; set axis maxima
                    M574 Y2 S0 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
                    M574 Z1 S2 ; configure Z-probe endstop for low end on Z
                    M950 S0 C"duex.pwm5" ; create servo pin 0 for BLTouch
                    G31 P500 X0 Y20 Z3.71 ; set Z probe trigger value, offset and trigger height
                    M557 X40:780 Y80:510 S100 ; define mesh grid
                    M307 H7 A-1 C-1 D-1 ; Disable the 7th Heater to free up PWM channel 5 on the Duex board.
                    M305 P1 T4606017 B5848 C5.548428e-8 R4700 H0 L0
                    M308 S1 P"e0temp" Y"thermistor" T4606017 B5848 ; configure sensor 1 as thermistor on pin e0temp
                    M307 H1 A580.4 C256.6 D6.4 S0.50 ; disable bang-bang mode for heater and set PWM limit
                    M143 H1 S493
                    • chris974M
                      Je dois faire une mise a jour vers la version 3 ?
                        Ok so the problem is that your config.g is formatted for RRF3 but you have RRF2 installed. I suggest that you update your firmware.
                        Connect to the web interface and upload these zip file as is (do not extract them first) to the system folder.
                        https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
                        https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/Duet2and3Firmware-3.1.1.zip
                        Afterwards you should be running firmware 3.1.1 and your config.g should work a lot better. Send M115 to confirm.
                        Then send M98 P"config.g" and report any error messages.
                          Oui.
                          • chris974M
                            Install updates?
                            You have uploaded at least one firmware update. Would you like to install them now? i say yes or no
                              Upload them one at a time starting with 3.0 and update, reboot, and then upload 3.1.1
                              • chris974M
                                06/10/2020 à 23:58:37 M115
                                FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.05.1 ELECTRONICS: Duet WiFi 1.02 or later + DueX5 FIRMWARE_DATE: 2020-02-09b1
                                • chris974M
                                  M997 S0:1
                                  Error: M997: In-application programming binary "iap4e.bin" not found
                                    Upload the full zip file as is. Do NOT extract it.
                                    • chris974M
                                      oui j'ai telecharger le fichier ZIP
                                      • chris974M
                                        j'ai toujours se message d'erreur M997 S0:1
                                          When uploading the zip file to the /sys folder it should prompt to install the firmware. You do not need to send M997 at all.
                                          However, because it is complaining about missing IAP files you can try this method which should also work.
                                          https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Updating_Duet_3_from_RRF3_0_Beta_12_to_3_0_Final_via_DWC
                                          • chris974M
                                            ok i try thanks
                                            • chris974M
                                              not work
                                                Can you make a video of your screen showing what you're trying to do?
                                                • chris974M
                                                  yes but the link is for duet3 and i have a duet2
                                                    Yes of course you are correct. Sorry about that.
                                                    I think you are missing some files from the 2.05.1 release which makes me think you might be uploading the wrong zip file.
                                                    Please download these zip files fresh and make sure you don't change the names.
                                                    Start with 2.05.1 zip file and it should update everything for RRF2.
                                                    Then do 3.0 and then 3.1.1.
                                                    • chris974M
                                                      2.05.1 OK
                                                      3.0 OK
                                                      3.1.1 is really too long is it normal ?
