    Motors Nema 23 Nema 17
    Firmware installation
    • chris974Mundefined
      chris974M
      Bonjour petite question comment calculer Motor Current (mA), Acceleration (mm/s²), Max. Speed (mm/s) et Max. Speed Change (mm/s)
      j'ai 2 nema 23 en Y 23HS30-2804S.pdf 2 nema 17 en X et 2 en Z 17HS19-2004S1.pdf
      • nhofundefined
        nhof
        Hello Chris,
        You will want to set motor current to 85% of rated current.
        Your nema 23 rated current is 2.80A/phase, so set motor current to 2400mA
        Your nema 17 rated current is 2.00A/phase, so set motor current to 1700mA
        chris974Mundefined 1 Reply Last reply Reply Quote 0
          chris974M @nhof
          @nhof Thanks
