    "Upload G-Code Files" button and File Open Dialog shows/allows .stl
    Duet Web Control wishlist
    1.1k
    • Yonkimanundefined
      Yonkiman
      I originally mentioned this in the wrong place: https://www.duet3d.com/forum/thread.php?id=1977
      Would be nice if the File Open Dialog launched after clicking on "Upload G-Code Files" filtered out all files except *.gcode" files.
      Unrelated minor bug: Sometimes (I believe it's immediately after launching), Macros don't appear on the "Machine Control" page. If I then click on the "Macros" tab and then go back to "Machine Control", they do show up. Very minor but it happens several times a week for me.
      Thanks,
      Fred
      • chrishammundefined
        chrishamm administrators
        This has been implemented as part of DWC 1.17+2. Allowed G-code formats are .g, .gcode, .gco and .tap (for pcb2gcode).
        Duet software engineer
        • DADIYundefined
          DADIY
          I no longer get any .g files displayed when uploading after updating to the 1.19 firmware and DWC release. I have to change customized files to all files to be able to pick them from the file upload explorer. That's on Chrome version 60.
          • DADIYundefined
            DADIY
            Looking at the code, the default filter doesn't match up with the defaults from slic3r.
            $(".btn-upload").click(function(e) {
            if (!$(this).is(".disabled")) {
            var type = $(this).data("type"), filter = "";
            if (type == "print" || type == "gcode") {
            filter = ".gcode,.gc,.gco,.tap";
            } else if (type == "filament") {
            filter = ".zip";
            } else if (type == "generic") {
            filter=".zip,.bin,.csv,.g,.json,.htm,.html,.ico,.xml,.css,.map,.js,.ttf,.eot,.svg,.woff,.woff2,.jpeg,.jpg,.png,.gz";
            $("#input_file_upload").prop("accept", filter).data("type", type).click();
            e.preventDefault();
            I suspect this:
            should really be this for completness.
            filter = ".gcode,.gc,.g,.gco,.tap,.ngc";
              Thanks for reporting this, it explains a problem I had earlier today.
                @DADIY:
                filter = ".zip";
                e.preventDefault();
                I suspect this:
                Thanks, I'll fix it in my next release.
                • DADIYundefined
                  DADIY
                  @chrishamm:
                  @DADIY:
                  filter = ".zip";
                  e.preventDefault();
                  I suspect this:
                  thanks Chris, for people that use Duets for CNC machines it might also be worth adding .nc which is the default from software like cambam & vectric's products.
