duet 2.... an ajax error..... means i cannot load settings
  • Hello everyone.
    i am very very new to this so please go easy with me. i have recently bought a buffalo cnc machine that has duet2 wifi board. I have been able to connect with yat and put the relivent commands in to turn the wifi on. I now come to the DWC. I am asked to "locate the firmware files that came with machine and unzip them onto the pc, which i have done (put on desktop) then to open DWC "click upload under settings-General tab in DWC" now when i do that i get bthe error an ajax error has.......... so now i cannot loads the setting of the size of bed i am using or any of the other settings. Having looked on the forum site i don't know if this is of use but the firmware version is Software Information
    Firmware Version: 2.03beta3 (2019-03-25b6)
    Web Interface Version: HTML: 1.11, JS: 1.11
    Web Interface by Christian Hammacher
    Licensed under the terms of the GPL v2.......
    would reallty like some help on this matter.
  • https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Fallback_procedure_Num_1
    and
    for the web ui. remove all files in the folder /www
    then unzip the content of the new dwc in the www folder
  • thank you that works
