Need eclipse build help
I followed the steps to setup the environment and seems right, but I am running into an issue:
13:08:33 **** Incremental Build of configuration SAM4E8E for project CoreNG ****
make all
process_begin: CreateProcess(C:\Users\Server\AppData\Local\Temp\make8732-1.bat, C:\Users\Server\AppData\Local\Temp\make8732-1.bat, …) failed.
make (e=267): The directory name is invalid.make: *** [variants/duetNG/exceptions.o] Error 267
I have the path defined correctly I am ale to build duetNG from command line
this happens if I build from eclipse
if I open a command prompt and run my env.bat
set PATH=C:\Arduino-1.5.8\hardware\arduino\sam\system\CMSIS\Examples\cmsis_example\gcc_arm;C:\Arduino-1.5.8\hardware\tools\gcc-arm-none-eabi-4.8.3-2014q1\binthen go to
C:\eclipse\Firmware\CoreNG\SAM4E8E
and run make all – it works.I have the same problem with build RepRapFirmware in eclipse
make all
process_begin: CreateProcess(C:\eclipse\Firmware\RepRapFirmware\DuetEthernet\make11596-1.bat, C:\eclipse\Firmware\RepRapFirmware\DuetEthernet\make11596-1.bat, ...) failed.
make (e=267): The directory name is invalid.when I try to build
from commandline:I tried exporting the command line arguments
set LINK_FLAGS_1=-mthumb -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--entry=Reset_Handler -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -Wl,--warn-unresolved-symbols -Wl,--start-group
set LINK_FLAGS_2=-Wl,--end-group -lm -gccthen run make all -- it runs to a point and then
it gives an error:
'Building target: DuetEthernetFirmware.elf'
'Invoking: Cross G++ Linker'
arm-none-eabi-gcc -L"C:\eclipse\Firmware\CoreNG\SAM4E8E" -Os -Wl,--gc-sections -Wl,--fatal-warnings -mcpu=cortex-m4 -TC:\eclipse\Firmware\CoreNG\variants\duetNG\linker_scripts\gcc\flash.ld -Wl,-Map,C:
\eclipse\Firmware\RepRapFirmware\DuetEthernet/DuetEthernetFirmware.map -o "DuetEthernetFirmware.elf" -mthumb -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--entry=Reset_Handler -Wl,--unresolv
ed-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -Wl,--warn-unresolved-symbols -Wl,--start-group ./src/Tools/Filament.o ./src/Tools/Tool.o ./src/Storage/FileStore.o ./src/Storage/Ma
ssStorage.o ./src/Movement/Kinematics/CartesianKinematics.o ./src/Movement/Kinematics/CoreBaseKinematics.o ./src/Movement/Kinematics/CoreXYKinematics.o ./src/Movement/Kinematics/CoreXYUKinematics.o .
/src/Movement/Kinematics/CoreXZKinematics.o ./src/Movement/Kinematics/Kinematics.o ./src/Movement/Kinematics/LinearDeltaKinematics.o ./src/Movement/Kinematics/ScaraKinematics.o ./src/Movement/BedProb
ing/Grid.o ./src/Movement/BedProbing/RandomProbePointSet.o ./src/Movement/DDA.o ./src/Movement/DriveMovement.o ./src/Movement/Move.o ./src/Libraries/sha1/sha1.o ./src/Libraries/Math/Isqrt.o ./src/
Libraries/General/StringRef.o ./src/Libraries/Fatfs/ccsbcs.o ./src/Libraries/Fatfs/diskio.o ./src/Libraries/Fatfs/fattime_rtc.o ./src/Libraries/Fatfs/ff.o ./src/Heating/Sensors/CpuTemperatureSensor.
o ./src/Heating/Sensors/CurrentLoopTemperatureSensor.o ./src/Heating/Sensors/RtdSensor31865.o ./src/Heating/Sensors/SpiTemperatureSensor.o ./src/Heating/Sensors/TemperatureSensor.o ./src/Heating/Senso
rs/Thermistor.o ./src/Heating/Sensors/ThermocoupleSensor31855.o ./src/Heating/Sensors/ThermocoupleSensor31856.o ./src/Heating/Sensors/TmcDriverTemperatureSensor.o ./src/Heating/FOPDT.o ./src/Heating/
Heat.o ./src/Heating/Pid.o ./src/Heating/TemperatureError.o ./src/GCodes/GCodeBuffer.o ./src/GCodes/GCodeInput.o ./src/GCodes/GCodeMachineState.o ./src/GCodes/GCodeQueue.o ./src/GCodes/GCodes.o ./src
/GCodes/GCodes2.o ./src/GCodes/RestorePoint.o ./src/DuetNG/DuetEthernet/Wiznet/Internet/DHCP/dhcp.o ./src/DuetNG/DuetEthernet/Wiznet/Ethernet/W5500/w5500.o ./src/DuetNG/DuetEthernet/Wiznet/Ethernet
/WizSpi.o ./src/DuetNG/DuetEthernet/Wiznet/Ethernet/socketlib.o ./src/DuetNG/DuetEthernet/Wiznet/Ethernet/wizchip_conf.o ./src/DuetNG/DuetEthernet/Network.o ./src/DuetNG/DuetEthernet/Socket.o ./src/
DuetNG/DueXn.o ./src/DuetNG/FirmwareUpdater.o ./src/DuetNG/FtpResponder.o ./src/DuetNG/HttpResponder.o ./src/DuetNG/NetworkBuffer.o ./src/DuetNG/NetworkResponder.o ./src/DuetNG/SX1509.o ./src/DuetNG/T
MC2660.o ./src/DuetNG/TelnetResponder.o ./src/Fan.o ./src/OutputMemory.o ./src/Platform.o ./src/PortControl.o ./src/PrintMonitor.o ./src/RepRap.o ./src/RepRapFirmware.o ./src/Roland.o ./src/Scanner.o
-lCoreNG -Wl,--end-group -lm -gcc
c:/arduino-1.5.8/hardware/tools/gcc-arm-none-eabi-4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv7e-m\libg.a(lib_a-sbrkr.o): In function_sbrk_r': sbrkr.c:(.text._sbrk_r+0xc): warning: undefined reference to
_sbrk'
collect2.exe: error: ld returned 1 exit status
make: *** [DuetEthernetFirmware.elf] Error 1I saw this brought up elsewhere, bu I can't seem to figure out what I'm doing wrong.
Just re-did everything and it worked. No idea what I changed.
Now works fine in eclipse – spent a good while trying to get it to work -- no dice...just changed path -- and works!
A few others have hit the undefined _sbrk issue, there is another thread about how to get around this.
dc42:
no idea what I did wrong the first time – but it compiles now -- started making changes to the firmware -- I started another thread with what I'm changing -- if it makes sense I'd like to contribute to the code. (I'm a programmer in my day job with 20 years experience) -- just trying to wrap my head around the logic. I've made modifications to my smoothieware firmware based delta by adding an independent Z axis gantry for a platform to wipe the extruder between color changes, so I can generally figure my way around, so I don't have any doubts I'll get the dual-y quad X IDEX setup working. The kinematics build is done, so now it's about wiring and firmware.
might try a much shorter path statement. some apps struggle with long paths and especially any sort of space or wild characters(like under score above) in path statement. Anyone beside me remember the old DOS days ? LOL
