    MQTT4DSF - An SBC Python service for MQTT integration with DSF
    Third-party software
    1
    1
    776
    • MintyTreborundefined
      MintyTrebor
      Following a conversation over on the DSF LPC discord group about using MQTT with DUET, I've had a go at creating a python service for SBC's running DSF, which enables MQTT integration with DSF.
      MQTT4DSF (https://github.com/MintyTrebor/MQTT4DSF) has 4 main functions:
      1. Subscribe to user defined DSF events and send mqtt msgs to a broker of choice on receipt of event (user configurable)
      2. Poll DSF on a timed frequency and send mqtt msgs based on a value delta (user configurable)
      3. Send user defined MQTT msgs when specially formatted M117 msgs are received from DSF events.
      4. Act as MQTT to GCode proxy - passing GCode commands to DSF and executing them on the machine, by subscribing to a custom MQTT topic.
      Short video of features in use - https://www.youtube.com/watch?v=2XwTgxythTE
      It runs on the DSF SBC (tested on rpi), using the DSF python API library, and the Duet Rest API. Its user configurable through a json file accessible through DWC.
      It's had limited testing but I hope it might be of use to someone here.
      NodeDSF - Native Node-Red integration with Duet boards.
      BtnCmd - Customise DWC with user defined buttons/layouts/panels (DWC Plugin)
      ReleaseMgr - Duet update info inside DWC.
      Repo
      1 Reply Last reply Reply Quote 10
