BL Touch 3.1 + Tool 1LC + Duet 3 + Online Config
Trying to config a BL touch with a Tool 1LC board using the online config tool.
I followed the instructions, being...
Toolboard IO_0 connector pin BLTouch pin Colour
io0_out Control Orange
GND GND Black + Brown
io0_in OUT White
5V_EXT +5V RedWhen in the reprap config tool, I can set PWM to io0.out but cannot set input pin to io0_in.
Any help would be appreciated
Thanks
Thanks for the report. It looks like the only pins that show up in the drop down for the board is temp0 and temp1.
You can modify the config.g manually after the fact to choose the tool board pin you want. Post your config.g if you'd like help with that.
Also, see this post regarding using the BLTouch 3.1 and a tool board.
https://forum.duet3d.com/topic/19211/bltouch-and-duet-3-tool-board?_=1603389293240
Thanks for the reply
I edited the config file and it's working now
This post is deleted!
