    Duet Wifi 3.2beta2 crashes with long menu file
    Beta Firmware
    127
    • spw
      spw last edited by
      When the menu file is over 30 lines long the board restarts when the menu is selected. Making the menu shorter by a few lines makes it stable for a little bit and crashes after a moment. Short menus < 20 seem to work fine. Maybe memory issue?
      My HW:
      Duet Wifi v1.03 with 3.2beta2 firmware
      My config:
      M918 P1 E4 F2000000
      crashing menu file:
      text R0 C2 F0 T"x:"
      alter N510 D1 W26
      text C46 T"y:"
      alter N511 D1 W26
      text C88 T"z:"
      alter N512 D2 W32
      image R12 C0 L"hline.img"
      text R14 C1 F0 T"x"
      button C11 T"-50 "  A"G91 G1 X-50 F6000"
      button C32 T"-10 "  A"G91 G1 X-10 F6000"
      button C50 T" -1 "   A"G91 G1 X-1 F6000"
      button C69 T"+1 "   A"G91 G1 X1 F6000"
      button C87 T"+10 "  A"G91 G1 X10 F6000"
      button C108 T"+50 " A"G91 G1 X50 F6000"
      text R26 C1 F0 T"y"
      button C11 T"-50 "  A"G91 G1 Y-50 F6000"
      button C32 T"-10 "  A"G91 G1 Y-10 F6000"
      button C50 T" -1 "  A"G91 G1 Y-1 F6000"
      button C69 T"+1 "   A"G91 G1 Y1 F6000"
      button C87 T"+10 "  A"G91 G1 Y10 F6000"
      button C108 T"+50 " A"G91 G1 Y50 F6000"
      text R38 C1 F0 T"z"
      button C11 T"-25 " A"G91 G1 Z-25 F6000"
      button C32 T"-5 "  A"G91 G1 Z-5 F6000"
      button C50 T" -1 " A"G91 G1 Z-1 F6000"
      button C69 T"+1 "  A"G91 G1 Z1 F6000"
      button C87 T"+5 "  A"G91 G1 Z5 F6000"
      button C108 T"+25 " A"G91 G1 Z25 F6000"
      image R50 C0 L"hline.img"
      button R51 C0 F0 T"<" A"return"
      button T" Home All " A"M98 P/sys/homeall.g"
        Please run M122 and check the value shown as Never Used RAM.
        • spw
          spw last edited by spw
          Never used ram: 76
          value with smaller menu: 468
          value without screen (no M918): 5968
            That's the problem then, RepRapFirmware has run out of RAM. Try creating fewer elements per menu page.
            • spw
              spw last edited by
              What value I should be aiming for safe operation?
                I suggest you aim for at least 200 bytes free, after switching between different menus repeatedly and doing a print.
                The difficulty is that RRF on the Duet WiFi/Ethernet supports up to 12 stepper drivers, so it needs more RAM for the movement buffers than the Maestro does.
                • spw
                  spw last edited by
                  I'm using only 3 motors is there an easy way to free this memory, I can recompile firmware if needed.
                    dc42 administrators @spw last edited by
                    @spw said in Duet Wifi 3.2beta2 crashes with long menu file:
                    Yes, you can reduce the value of NumDms in file Move.h. I suggest you reduce the *8 to *4.
                    • spw
                      spw last edited by
                      Thank you it helped a lot. I reduced *8 to *5 and it doubled free memory, now with the complex menu, I still have 4000+ bytes free.
                      Since the memory is dynamically allocated do you think you could add a GCode to reallocate this buffer so I don't have to recompile firmware with every version, I think other users would benefit too since 4 motors + 1 or 2 heater is the most common setup.
                      seraser 1 Reply Last reply Reply Quote 0
                      • seraser
                        seraser @spw last edited by
                        Can you share your compiled firmware with only 5 motors?
                        • spw
                          spw last edited by
                          Duet2CombinedFirmware.bin
