Tool offsets defined in RRF config sheet are not saved.
  • Today I noticed that when defining the offset for a number of tools, On the webpage the data is retained. When saving however, the offsets are slost.
    Below an output of the config.g file.
    M563 P0 D0 H1 F0
    G10 P0 X0 Y0 Z0
    Also when saving and reimporting the json file, the offset values are lost.
    Ofcourse, I can define them by hand, but I would expect the config page to do this, or am I doing something wrong?
    Kind regards,
    Harald
  • Moderator
    I assume you mean the online configuration tool?
  • Yes indeed
    https://configtool.reprapfirmware.org/Start
    okay wrong category, sorry
  • Moderator
    Thanks for the report. I believe configurator tool fixes will be coming post 3.2 release.
  • Is there an overview of reported problems/issues with config page as well as firmware?
  • Moderator
    Not currently. The forum is the main source of reporting and support. Issues are troubleshot and reproduced as possible and then escalated as needed where they are reproduced, tracked, and hopefully resolved internally.
    In the near future we hope to have a github issue tracker up and running, however it would still be required to use the forum to attempt to troubleshoot the reported issues before being tracked on github simply because 99% of the time it's a configuration issue or misperception of how something should work.
