compiled binary does not work with configuration Duet3_V06_CAN0
  • Hi,
    I'm trying to compile version 3.1.0 of firmware. Compilation seems to work, but once flashed using bossa, nothing works, I don't even have a tty to read from.
    I have checkout tag 3.1.0 from each repository, and compile with configuration Duet3_V06_CAN0. It does work a little wit configuration Duet3_V06_Debug, but is unusable nonetheless (web page keeps on reconnecting).
    Any tip on what I could do to understand what may be happening ?
    Thanks in advance,
    The CAN0 build configuration is intended only for testing the CAN0 port. You should use the Duet3_V06 configuration instead.
  • It works, thanks a lot !
