    Gcode: pause until KEY is pressed
    Gcode meta commands
    • CJ.BRAVO
      CJ.BRAVO last edited by CJ.BRAVO
      Hi there,
      looking for a gcode command that allows me to pause a print until a key is pressed (or endstop is triggered).
      for example, when layer is done, goto center bed and wait until the key is pressed.
      key can be also resume on the DWC or external endstop/key.
      thoughts?
      • A Former User
        A Former User last edited by
        use m291 to pause and set a trigger with m292
        that gives you a message in dwc/paneldue that you can close with either a physical pin, web or paneldue i think. (subject to failing a reality check).
        https://duet3d.dozuki.com/Wiki/Gcode#Section_M291_Display_message_and_optionally_wait_for_response
        • CJ.BRAVO
          cool!
          looks like what i'm after
          cheers
