Probing Macro
  • Hello All.
    For our Giant Delta 3D printer project, We are trying to calibrate the bed.
    in order to measure and set the parameters, I wrote a Macro.
    The Macro:
    ;https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer
    G28   ; Home all
    G90  ; absolute positioning
    G0 X0 Y0 F2000  ; 0. Start point.
    G1 Z35 ;
    M561 ; Cancel any existing bed compensation by sending M561
    M208 S1 Z-30 ;Send M208 S1 Z-3 to temporarily allow Z moves down to Z=-30mm. This is to ensure that you can lower the nozzle all the way to the bed in step 5.
    ; Command the print head to the XY coordinates you want to probe
    G30 S-1 ; find the difference
    G92 Z0 ; Set the new zero.
    G1 Z35 ;
    G0 X0 Y500  ; 1. point.
    G1 Z35  ;
    G0 X433.01 Y250  ;2. point.
    G1 Z35 ;
    G0 X433.01 Y-250  ;3. point.
    G1 Z35 ;
    G0 X0 Y-500   ;4. point.
     Z35 ;
    G0 X-433.01 Y-250   ;5. point.
    G1 Z35 ;
    G0 X-433.01 Y250   ;6. point.
    G1 Z35 ;
    G1 X0 Y0  ; 0. Finish point.
    On the first trial, I get successful output. I believe these outputs are the Bed.g H values going to be right?
    According to the GCode This is the output: resulted
    11/12/2020, 6:01:41 PM	Stopped at height 32.718 mm
    11/12/2020, 6:01:16 PM	Stopped at height 32.839 mm
    11/12/2020, 6:00:52 PM	Stopped at height 31.475 mm
    11/12/2020, 6:00:27 PM	Stopped at height 29.794 mm
    11/12/2020, 6:00:01 PM	Stopped at height 30.364 mm
    11/12/2020, 5:59:35 PM	Stopped at height 30.809 mm
    11/12/2020, 5:59:09 PM	M98 P"0:/macros/ProbingMakro.g"
    Stopped at height 0.495 mm
    But Later test start failing. After 2. sampling axis moves behaves strangely. IT is going the next line before completing the current job.
    Questions:
    • What is the problem in the code or somehere?
    • How do I use this measurement values?
    Thanks.
