RepRapFirmware 3.2beta3.2 released
@Veti said in RepRapFirmware 3.2beta3.2 released:
from the changelog.
Efficiency improvements to TMC2208/2209 drivers for both main and tool boards
Which board uses the TMC2208? did you mean TMC2224?
Yes, I did. I think of the TMC2224 as a 2208 (it's the same with a different pinout).
@dc42 said in RepRapFirmware 3.2beta3.2 released:
@DaBit, 3.2beta4 for Duet WiFi is released now.
Makes no difference. Skirt goes well, once the printing of the circles starts the Duet hangs (cancel print does not work, emergency stop does, changing temperatures in DWC does too)
You've posted the print file, but I need your config.g file too.
@dc42 : Here is the entire bundle, directly downloaded from the printer:
https://www.icecoldcomputing.com/directlink/DaBit3D_config_26nov2020.zip
Thanks, that's on my list to look into.
It is not an issue for me. I suspect the large amount of short segments simply choking the Duet. When using gcode with sane segment length the Duet hums along fine.
But still, it should slow down to a crawl, but not hang. -
Absolutely right, it should not hang.
I believe this is now fixed in the new RRF 3.2bete4+3 binaries at https://www.dropbox.com/sh/tehhdvunh0pgr7q/AADgJ4Qj7W18MYaRRNNDdhpwa?dl=0.
not fixed or 'now fixed'?
I will give it a try, will report back...
The issue seems resolved.
I did not let the print finish since that's only a waste of plastic and I don't think it proves anything, but after 63000 moves it was still printing fine.
Thanks for confirming.
