    Impossible for every timelapse script to comunicate with RRF?
    Firmware installation
    1
    1
    83
    • A Former User?
      A Former User
      Good morning, I've installed the latest version of RFF3 in my printer. I've already placed a Raspberri PI vith a PI cam to take timelapses. Well, I've tried three different Python script to make Timelapses and none of them worked...It looks like they all can't "comunicate" with the printer. This is the last one: https://github.com/DanalEstes/DuetLapse
      wich gives me this message:
      but
      At this point I'm starting to think that I forgot to set something in the firmware because three different scripts "suffers" of lack of comunication with the printer....what could I check?
      this is my config.g (I've just obfuscated the password):
      ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sun Nov 01 2020 08:34:36 GMT+0100 (Ora standard dell’Europa centrale)
      M550 P"DragonCore" ; set printer name
      M669 K1 ; select CoreXY mode
      M551 P"*********" ; set password
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S1 ; enable FTP
      M586 P2 S1 ; enable Telnet
      M569 P0 S0 ; physical drive 0 goes backwards
      M569 P3 S0 ; physical drive 3 goes backwards
      M350 E16 I0 ; configure microstepping without interpolation
      M350 X16 Y16 Z16 I1 ; configure microstepping with interpolation
      M92 X159.6 Y159.6 Z1188.11 E411.88 ; set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
      M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X330 Y330 Z400 S0 ; set axis maxima
      M574 Z1 S2 ; configure Z-probe endstop for low end on Z
      G31 P500 X-39 Y0 Z1.10 ; set Z probe trigger value, offset and trigger height
      M557 X40:290 Y10:320 S20 ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
      M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
      M106 P1 S1 H1 T50 ; set fan 1 value. Thermostatic control is turned on
      M106 P2 S0 H-1 ; set fan 2 value. Thermostatic control is turned off
      M563 P0 S"E3DVolcano" D0 H1 F0 ; define tool 0
      ; = D R A G O N C O R E =
      M671 X5:165:320:320:165:5 Y325:325:325:5:5:5 P0.5 ; point1 (40,320), point2 (165,320), point3 (290,320), point4 (290,10), point5 (165,10), point6 (10,10)
      M591 D0 P3 C"e0_stop" S1 R70:130 L25.8 E3.0 ; Duet3D rotating magnet sensor for extruder drive 0 is connected to E0 endstop input, enabled, sensitivity 24.8mm.rev, 70% to 130% tolerance, 3mm detection length
      M308 S10 Y"mcu-temp" A"MCU"
      M911 S11.0 R11.5 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"
