    1st Layer height -
    Beta Firmware
    1
    1
    133
    • Garfieldundefined
      Garfield
      Something odd .. really odd with my systems Z height using 3.2 beta 3.2
      Machine is a core XY, Duet3, Z height measured using Pinda probe, triple independent z axis (bed supported on kinematic mounts, I am not using a Pi at this time.
      I did a print, something wasn't right I was getting a lot of filament building up on the nozzle during the first layer of a print and yet in some places filament wasn't deposited as expected. Pretty characteristic for PETG when the nozzle is too low.
      I therefore decided to verify the Z axis settings. In a test print using a single 0.15 layer square the 1st layer was 0.0660 - it was supposed to be 0.15. The G31 code at this time was G31 P1 X-21 Y0 Z0.739 C0.002 S29 H3
      Changed this to G31 P1 X-21 Y0 Z0.759 C0.002 S29 H3
      and the 1st layer height was .... yup 0.0660
      changed to G31 P1 X-21 Y0 Z0.859 C0.002 S29 H3
      and the 1st layer height was ... yup you guessed it 0.0660 ....
      I have done a measure on the actual trigger height using a feeler gauge and it is 0.88mm, I have verified the Z calibration (M92 X160.00 Y160.00 Z1600.00 E400.00) these are 1.9 degree steppers on a Tr8x2 pitch single start leadscrew (E3D)
      The calibration height is measured using a high end Mitutoyo micrometer (no it is not a fake)
      Understand that the original G31 P1 X-21 Y0 Z0.739 C0.002 S29 H3 was deliberate to ensure adequate nozzle height for PETG which does not like to be squished. I have verified that Z0 really is 0 when the nozzle time touches the bed.
      Anyone care to offer a clue why the layer height is not as expected, why is the machine not calculating the appropriate height for the first layer ?
      G29 S0
      182 points probed, min error -0.081, max error 0.087, mean -0.004, deviation 0.033
      G32
      Leadscrew adjustments made: 0.091 -0.086 0.065, points used 4, (mean, deviation) before (0.011, 0.083) after (-0.000, 0.047)
      DUMMY ALERT - make sure you don't hit the imperial selector on your fancy micrometer and jump to the wrong conclusion - 0.0660" = 0.167mm .... doesn't explain why the nozzle is picking up filament but it isn't the Z height - this isn't a beta code problem-
