    A few small things
    Duet Web Control wishlist
    • Styler93gsx
      Styler93gsx last edited by
      MM/sec
      current layer height/total layers
      current travel speed(live update mm/per sec instead of speed of percent of something you entered 10 hours ago on a long print)
      current print speed(same)
      current acceleration settings
      extruder retratction settings (live update) Hard I know cause this is done in the slicing software but maybe could be done in firmware
      Serial console of gcode that is being transmitted.
        I'm not sure exactly what you mean, but here goes:
        MM/sec: in what context? In GCode, mm/min are always used, probably because GCode was originally designed for CNC machines which use lower speeds than we do.
        The speed of the current move could be displayed, but how useful is that?
        current acceleration settings You can use M201 and M204 without parameters to report them
        extruder retratction settings (live update) Hard I know cause this is done in the slicing software but maybe could be done in firmware As you say, hard, but not impossible. Why not use firmware retraction instead?
        Serial console of gcode that is being transmitted You can get this sent to the USB port if you send M111 S1 P3.
