Object Model User Variables
I'm hoping a small array of user variables could be added in into the object model. Maybe 10 or less? that could have their value set with a gcode/mcode. They could be queried by object model requests on an interface and could be used inside gcode with meta commands. A workaround can be done at the moment using other settings associated with hardware like a dummy gpio pin or pwm pin but it uses a real hardware pin. it would be nice to associate a char string to each variable as well.
JD
if you search the forum you'll find you can use names for imaginary tools or fans/sensors etc as a string variable until support is added to the firmware which is on the road map afaik
