    Crash mid print with 3.2 beta 4
    Beta Firmware
    • kuonundefined
      kuon
      I have a printer with Duet 3, SBC and 2 toolboards and my print crashes mid print. The print head just stops moving and nothing works, including emergency stop.
      I have two toolboards.
      Here are the logs I got from the Raspberry PI:
      Dec 11 15:43:30 lili DuetControlServer[1139]: [info] Starting file print
      Dec 11 15:43:30 lili DuetControlServer[1139]: [info] Starting macro file start.g on channel File
      Dec 11 15:43:30 lili DuetControlServer[1139]: [info] Finished macro file start.g
      Dec 11 15:44:06 lili DuetControlServer[1139]: [info] Starting macro file homeall.g on channel File
      Dec 11 15:44:36 lili DuetControlServer[1139]: [info] Starting macro file deployprobe.g on channel File
      Dec 11 15:44:36 lili DuetControlServer[1139]: [info] Finished macro file deployprobe.g
      Dec 11 15:44:42 lili DuetControlServer[1139]: [info] Starting macro file retractprobe.g on channel File
      Dec 11 15:44:42 lili DuetControlServer[1139]: [info] Finished macro file retractprobe.g
      Dec 11 15:44:42 lili DuetControlServer[1139]: [info] Starting macro file deployprobe.g on channel File
      Dec 11 15:44:42 lili DuetControlServer[1139]: [info] Finished macro file deployprobe.g
      Dec 11 15:44:46 lili DuetControlServer[1139]: [info] Starting macro file retractprobe.g on channel File
      Dec 11 15:44:46 lili DuetControlServer[1139]: [info] Finished macro file retractprobe.g
      Dec 11 15:44:47 lili DuetControlServer[1139]: [warn] Resending packet type #0 (request LockMovementAndWaitForStandstill)
      Dec 11 15:44:48 lili DuetControlServer[1139]: [warn] Resending packet type #0 (request LockMovementAndWaitForStandstill)
      Dec 11 15:44:49 lili DuetControlServer[1139]: [warn] Resending packet type #0 (request LockMovementAndWaitForStandstill)
      Dec 11 15:44:49 lili DuetControlServer[1139]: [info] Finished macro file homeall.g
      Dec 11 15:44:49 lili DuetControlServer[1139]: [info] Height map loaded from file heightmap.csv
      Dec 11 15:54:18 lili DuetControlServer[1139]: [warn] RepRapFirmware got a bad data checksum
      Dec 11 15:55:14 lili DuetControlServer[1139]: [warn] Bad data checksum (expected 0x4efb, got 0xdbff)
      Dec 11 15:55:14 lili DuetControlServer[1139]: [warn] Note: RepRapFirmware didn't receive valid data either (code 0x00000003)
      Dec 11 15:55:14 lili DuetControlServer[1139]: [warn] Bad data checksum (expected 0x4efb, got 0xe7fe)
      Dec 11 15:55:14 lili DuetControlServer[1139]: [warn] Restarting transfer because the Duet received a bad response (data response)
      Dec 11 15:55:27 lili DuetControlServer[1139]: [warn] Restarting transfer because a bad data response was received (0x00000008)
      Dec 11 15:55:28 lili DuetControlServer[1139]: [warn] Restarting transfer because a bad data response was received (0xffffff61)
      Dec 11 15:55:35 lili DuetControlServer[1139]: [warn] Lost connection to Duet (Board is not available (no header))
      Dec 11 15:55:35 lili DuetControlServer[1139]: [warn] Bad header checksum (expected 0x0000, got 0x1760)
      Dec 11 15:55:35 lili DuetControlServer[1139]: [warn] Note: RepRapFirmware didn't receive valid data either (code 0x0003005f)
      Dec 11 15:55:35 lili DuetControlServer[1139]: [warn] Restarting transfer because the number of maximum retries has been exceeded
      Dec 11 15:55:35 lili DuetControlServer[1139]: [info] Connection to Duet established
      Dec 11 15:55:35 lili DuetControlServer[1139]: [warn] Lost connection to Duet (Board is not available (no data response))
      Dec 11 15:55:35 lili DuetControlServer[1139]: [warn] Bad header checksum (expected 0x0000, got 0xc221)
      Dec 11 15:55:35 lili DuetControlServer[1139]: [warn] Restarting transfer because the Duet received a bad response (header response)
      Dec 11 15:59:07 lili DuetControlServer[1139]: [warn] Lost connection to Duet (Board is not available (no header))
      Dec 11 15:59:07 lili DuetControlServer[1139]: [info] Connection to Duet established
      Dec 11 16:00:05 lili DuetControlServer[1139]: [warn] Bad data checksum (expected 0xef9b, got 0xb24e)
      Dec 11 16:00:53 lili DuetControlServer[1139]: [warn] Bad data checksum (expected 0xb2e5, got 0xeaa8)
      Dec 11 16:00:53 lili DuetControlServer[1139]: [warn] Note: RepRapFirmware didn't receive valid data either (code 0x00000006)
      Dec 11 16:01:00 lili DuetControlServer[1139]: [warn] Bad data checksum (expected 0x71a6, got 0xeaa8)
      Dec 11 16:01:00 lili DuetControlServer[1139]: [warn] Note: RepRapFirmware didn't receive valid data either (code 0x00000003)
      Dec 11 16:01:00 lili DuetControlServer[1139]: [warn] Bad data checksum (expected 0x71a6, got 0x2aa7)
      Dec 11 16:01:00 lili DuetControlServer[1139]: [warn] Restarting transfer because the number of maximum retries has been exceeded
      Dec 11 16:02:07 lili DuetControlServer[1139]: [warn] Lost connection to Duet (Board is not available (no data response))
      Dec 11 16:02:07 lili DuetControlServer[1139]: [info] Connection to Duet established
      Dec 11 16:02:07 lili DuetControlServer[1139]: [warn] Controller has been reset
      Dec 11 16:02:07 lili DuetControlServer[1139]: [warn] File: Out-of-order reply: ''
      Dec 11 16:02:07 lili DuetControlServer[1139]: [info] Aborted job file
      Dec 11 16:02:07 lili DuetControlServer[1139]: [info] Cancelled printing file 0:/gcodes/Cable holder - Part 1.gcode, print time was 0h 18m
      M122
      RepRapFirmware for Duet 3 MB6HC version 3.2-beta4.1 running on Duet 3 MB6HC v1.01 or later (SBC mode)
      Board ID: 08DJM-956L2-G43S8-6J9F4-3S86S-TA3QD
      Used output buffers: 1 of 40 (13 max)
      Static ram: 123292
      Dynamic ram: 138612 of which 188 recycled
      Never used RAM 130100, free system stack 126 words
      Tasks: Linux(ready,77) HEAT(blocked,276) CanReceiv(blocked,829) CanSender(blocked,339) CanClock(blocked,352) TMC(blocked,20) MAIN(running,1215) IDLE(ready,19)
      Owned mutexes: HTTP(MAIN)
      Last reset 04:34:18 ago, cause: software
      Last software reset at 2020-12-11 15:42, reason: User, GCodes spinning, available RAM 129976, slot 0
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0440f000 BFAR 0x00000000 SP 0xffffffff Task Linu
      Error status: 0x00
      MCU temperature: min 44.7, current 46.2, max 46.9
      Supply voltage: min 24.1, current 24.2, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
      12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0
      Driver 0: position 9093, standstill, reads 18801, writes 29 timeouts 0, SG min/max 0/1023
      Driver 1: position 9536, standstill, reads 18802, writes 29 timeouts 0, SG min/max 0/1023
      Driver 2: position 42380, standstill, reads 18803, writes 29 timeouts 0, SG min/max 0/1023
      Driver 3: position 26400, standstill, reads 18803, writes 29 timeouts 0, SG min/max 0/699
      Driver 4: position 0, standstill, reads 18810, writes 23 timeouts 0, SG min/max 0/57
      Driver 5: position 0, standstill, reads 18823, writes 11 timeouts 0, SG min/max 0/0
      Date/time: 2020-12-11 20:16:25
      Slowest loop: 198.95ms; fastest: 0.09ms
      === Storage ===
      Free file entries: 10
      FreeDm 375 (min 354), maxWait 15232028ms, bed compensation in use: mesh, comp offset 0.000
      === MainDDARing ===
      Scheduled moves 22237, completed moves 22237, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 3], CDDA state -1
      === AuxDDARing ===
      Segments left: 0
      Movement lock held by null
      Telnet is idle in state(s) 0
      File* is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty.
      === CAN ===
      Messages queued 86898, send timeouts 0, received 394955, lost 0, longest wait 2ms for reply type 6049, free buffers 47
      === SBC interface ===
      State: 0, failed transfers: 6
      Last transfer: 18ms ago
      RX/TX seq numbers: 56645/56647
      SPI underruns 7, overruns 7
      Number of disconnects: 0, IAP RAM available 0x209d8
      Buffer RX/TX: 0/0-0
      === Duet Control Server ===
      Duet Control Server v3.2.0-beta4
      Code buffer space: 4096
      Configured SPI speed: 8000000 Hz
      Full transfers per second: 35.31
      M122 B20
      Diagnostics for board 20:
      Duet TOOL1LC firmware version 3.2-beta4.1 (2020-12-03)
      Bootloader ID: SAMC21 bootloader version 2.1 (2020-11-03b2)
      Never used RAM 4120, free system stack 38 words
      HEAT 46 CanAsync 89 CanRecv 83 TMC 54 MAIN 218 AIN 64
      Last reset 04:38:15 ago, cause: software
      Last software reset data not available
      Driver 0: position 637134, 830.0 steps/mm, standstill, SG min/max 0/240, read errors 0, write errors 1, ifcnt 27, reads 24580, writes 14, timeouts 0, DMA errors 0
      Moves scheduled 20994, completed 20994, in progress 0, hiccups 0
      No step interrupt scheduled
      VIN: 24.4V
      MCU temperature: min 38.0C, current 40.6C, max 54.1C
      Ticks since heat task active 119, ADC conversions started 16691369, completed 16691368, timed out 0
      Last sensors broadcast 0x00000002 found 1 123 ticks ago, loop time 0
      CAN messages queued 200356, send timeouts 0, received 238051, lost 0, free buffers 36
      M122 B21
      Diagnostics for board 21:
      Never used RAM 4152, free system stack 84 words
      HEAT 50 CanAsync 89 CanRecv 83 TMC 54 MAIN 218 AIN 64
      Last reset 04:38:39 ago, cause: software
      Driver 0: position 0, 830.0 steps/mm, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 25, reads 36650, writes 12, timeouts 0, DMA errors 0
      Moves scheduled 0, completed 0, in progress 0, hiccups 0
      VIN: 24.3V
      MCU temperature: min 36.8C, current 37.0C, max 40.0C
      Ticks since heat task active 3, ADC conversions started 16652923, completed 16652923, timed out 0
      Last sensors broadcast 0x00000004 found 1 6 ticks ago, loop time 0
      CAN messages queued 200596, send timeouts 0, received 217337, lost 0, free buffers 36
      My config files: https://matrix.goyman.com/2020-12-11-duet.7z
      • kuonundefined
        kuon
        Another print crash (I was able to M999 restart the board after):
        Dec 11 23:12:22 lili DuetControlServer[1139]: [info] Selected file /opt/dsf/sd/gcodes/Cable holder - Part 1.gcode
        Dec 11 23:12:22 lili DuetControlServer[1139]: [info] Starting file print
        Dec 11 23:12:22 lili DuetControlServer[1139]: [info] Starting macro file start.g on channel File
        Dec 11 23:12:23 lili DuetControlServer[1139]: [info] Finished macro file start.g
        Dec 11 23:12:23 lili DuetControlServer[1139]: [info] Starting macro file homeall.g on channel File
        Dec 11 23:12:45 lili DuetControlServer[1139]: [info] Starting macro file deployprobe.g on channel File
        Dec 11 23:12:45 lili DuetControlServer[1139]: [info] Finished macro file deployprobe.g
        Dec 11 23:12:51 lili DuetControlServer[1139]: [info] Starting macro file retractprobe.g on channel File
        Dec 11 23:12:51 lili DuetControlServer[1139]: [info] Finished macro file retractprobe.g
        Dec 11 23:12:51 lili DuetControlServer[1139]: [info] Starting macro file deployprobe.g on channel File
        Dec 11 23:12:51 lili DuetControlServer[1139]: [info] Finished macro file deployprobe.g
        Dec 11 23:12:55 lili DuetControlServer[1139]: [info] Starting macro file retractprobe.g on channel File
        Dec 11 23:12:55 lili DuetControlServer[1139]: [info] Finished macro file retractprobe.g
        Dec 11 23:12:56 lili DuetControlServer[1139]: [warn] Resending packet type #0 (request LockMovementAndWaitForStandstill)
        Dec 11 23:12:57 lili DuetControlServer[1139]: [warn] Resending packet type #0 (request LockMovementAndWaitForStandstill)
        Dec 11 23:12:58 lili DuetControlServer[1139]: [warn] Resending packet type #0 (request LockMovementAndWaitForStandstill)
        Dec 11 23:12:58 lili DuetControlServer[1139]: [info] Finished macro file homeall.g
        Dec 11 23:12:58 lili DuetControlServer[1139]: [info] Height map loaded from file heightmap.csv
        Dec 11 23:19:06 lili DuetControlServer[1139]: [warn] Restarting transfer because a bad data response was received (0x000000ae)
        Dec 11 23:21:10 lili DuetControlServer[1139]: [warn] Lost connection to Duet (Board is not available (no header))
        Dec 11 23:21:10 lili DuetControlServer[1139]: [info] Connection to Duet established
        Dec 11 23:21:40 lili DuetControlServer[1139]: [warn] RepRapFirmware got a bad data checksum
        Dec 11 23:22:37 lili DuetControlServer[1139]: [warn] Restarting transfer because a bad data response was received (0x00000030)
        Dec 11 23:25:49 lili DuetControlServer[1139]: [warn] Lost connection to Duet (Board is not available (no header))
        Dec 11 23:25:49 lili DuetControlServer[1139]: [info] Connection to Duet established
        Dec 11 23:26:55 lili DuetControlServer[1139]: [warn] Lost connection to Duet (Board is not available (no header))
        Dec 11 23:26:55 lili DuetControlServer[1139]: [info] Connection to Duet established
        Dec 11 23:28:27 lili DuetControlServer[1139]: [warn] Restarting transfer because a bad data response was received (0xffffff61)
        Dec 11 23:29:00 lili DuetControlServer[1139]: [warn] Lost connection to Duet (Board is not available (no header))
        Dec 11 23:29:00 lili DuetControlServer[1139]: [info] Connection to Duet established
        Dec 11 23:32:03 lili DuetControlServer[1139]: [warn] Lost connection to Duet (Board is not available (no header))
        Dec 11 23:32:03 lili DuetControlServer[1139]: [info] Connection to Duet established
        Dec 11 23:32:51 lili DuetControlServer[1139]: [warn] Lost connection to Duet (Board is not available (no header))
        Dec 11 23:32:51 lili DuetControlServer[1139]: [info] Connection to Duet established
        Dec 11 23:36:46 lili DuetControlServer[1139]: [warn] Lost connection to Duet (Board is not available (no data response))
        Dec 11 23:36:47 lili DuetControlServer[1139]: [info] Connection to Duet established
        Dec 11 23:36:50 lili DuetControlServer[1139]: [warn] Lost connection to Duet (Board is not available (no header))
        Dec 11 23:36:50 lili DuetControlServer[1139]: [info] Connection to Duet established
        Dec 11 23:38:08 lili DuetControlServer[1139]: [warn] Lost connection to Duet (Board is not available (no data response))
        Dec 11 23:38:08 lili DuetControlServer[1139]: [info] Connection to Duet established
        Dec 11 23:38:08 lili DuetControlServer[1139]: [warn] Controller has been reset
        Dec 11 23:38:08 lili DuetControlServer[1139]: [warn] File: Out-of-order reply: ''
        Dec 11 23:38:08 lili DuetControlServer[1139]: [info] Aborted job file
        Dec 11 23:38:08 lili DuetControlServer[1139]: [info] Cancelled printing file 0:/gcodes/Cable holder - Part 1.gcode, print time was 0h 25m
        • kuonundefined
          kuon
          I disabled all unnecessary services on the PI (noticed that things like lightdm, alsa or bluetooth were running by default). I have been printing for about 24h with this setup with no crash so far.
          I will update this topic in a few days if it actually fixed the problem.
          • observatoerundefined
            observatoer
            This post is deleted!
            • kuonundefined
              kuon
              Still no crash after 2 days.
              Here are the services I disabled:
              sudo systemctl disable lightdm
              sudo systemctl disable cups
              sudo systemctl disable wpa_supplicant
              sudo systemctl disable alsa
              sudo systemctl disable alsa-state
              sudo systemctl disable bluealsa
              sudo systemctl disable apt-daily-upgrade.timer
              sudo systemctl disable apt-daily.timer
              sudo systemctl disable bluetooth
