    Duet WiFi in Ender 5 Plus
    Firmware installation
    • Odie9undefined
      Odie9
      I have a Duet WiFi v1.0 with RepRap firmware v1.2 loaded on it. I upgraded to a Duet Wifi in a homebuilt delta. I want to reuse the old v 1.0 in an Ender 5 Plus. I tried to use the RepRap Configuration Tool to create a new firmware but the hardware isn't supported by it any more. Anyone have a 1.2 cartesian configuration they could post? If not, any other suggestions on how to use this board for a cartesian printer?
      TIA
      Odie9
      • Vetiundefined
        Veti
        @Odie9 said in Duet WiFi in Ender 5 Plus:
        if you are setting up a new printer just update to 3.1.1
        you need to update to 3.0 first.
        • Odie9undefined
          Odie9
          Will 3.x run on Duet WiFi v1.0 hardware?
          • Odie9undefined
            Odie9
            It's not listed in the config tool.
            Vetiundefined 1 Reply Last reply Reply Quote 0
            • Vetiundefined
              Veti @Odie9
              @Odie9
              yes
              • Odie9undefined
                Odie9
                What do I pick as a model to configure in the config tool? The Duet WiFi is set up for a delta now, I need to change it to cartesian. Thanks for the help.
                • Vetiundefined
                  Veti
                  go for custom and on the next page select cartesian.
                  you will replace all files with the newly generated files.
                  this is a good guide for a ender 3
                  https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+2:+Configuration/38
                  you can go along with most of it, replacing specifics for your printer, eg size and thermistors
