    Unable to update Firmware on Duet Mini 5+ Ethernet
    Hardware dev
    • Vetiundefined
      Veti
      I was able to update the firmware from beta 2 to beta4
      The Update to Beta4.1 Fails with
      M997 S0
      Operation has been cancelled
      Updating to Beta4.1 via usb is working fine.
      It seems the writing fails
      here is the M122 after the failed firmware update
      M122
      RepRapFirmware for Duet 3 Mini 5+ version 3.2-beta4.1 running on Duet 3 Mini5plus Ethernet (standalone mode)
      Board ID: MB72M-P867A-G65J0-40TFS-LJD0Z-Z63P3
      Used output buffers: 1 of 40 (11 max)
      Static ram: 98728
      Dynamic ram: 128300 of which 504 recycled
      Never used RAM 33588, free system stack 200 words
      Tasks: NETWORK(ready,162) ETHERNET(blocked,568) HEAT(blocked,188) CanReceiv(blocked,967) CanSender(blocked,372) CanClock(blocked,363) TMC(blocked,109) MAIN(running,513) IDLE(ready,20) AIN(blocked,272)
      Owned mutexes:
      Last reset 00:00:10 ago, cause: watchdog
      Last software reset at 2020-12-14 17:32, reason: User, GCodes spinning, available RAM 33692, slot 1
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00430000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
      Error status: 0x00
      Supply voltage: min 0.0, current 23.9, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 0: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 99, reads 2096, writes 9, timeouts 0, DMA errors 0
      Driver 1: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 99, reads 2096, writes 9, timeouts 0, DMA errors 0
      Driver 2: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 99, reads 2095, writes 9, timeouts 0, DMA errors 0
      Driver 3: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 99, reads 2095, writes 9, timeouts 0, DMA errors 0
      Driver 4: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 99, reads 2096, writes 9, timeouts 0, DMA errors 0
      Driver 5: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 99, reads 2096, writes 9, timeouts 0, DMA errors 0
      Driver 6: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 99, reads 2095, writes 9, timeouts 0, DMA errors 0
      Date/time: 2020-12-14 18:07:06
      Slowest loop: 2.07ms; fastest: 0.12ms
      === Storage ===
      Free file entries: 10
      SD card longest read time 0.6ms, write time 0.0ms, max retries 0
      FreeDm 169 (min 169), maxWait 0ms, bed compensation in use: none, comp offset 0.000
      === MainDDARing ===
      === AuxDDARing ===
      Bed heaters = 0 -1, chamberHeaters = -1 -1
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 120.00ms; fastest: 0.03ms
      HTTP sessions: 1 of 8
      - Ethernet -
      State: active
      Error counts: 0 0 0 0 0
      Socket states: 5 2 2 2 2 0 0 0
      === CAN ===
      Messages queued 95, send timeouts 93, received 0, lost 0, longest wait 0ms for reply type 0, free buffers 15
      code_text
      • Vetiundefined
        Veti
        i also tried the different iap from https://www.dropbox.com/s/iw2wx23ta226b3c/Duet3_SDiap_Mini5plus.bin?dl=0
        same thing
        the size is different to the one supplied on the usb card.
          Try this IAP. You will need to rename it by removing the "32" from the name.
          Duet3_SDiap32_Mini5plus.bin
          • Vetiundefined
            Veti
            yes that works.
            i am able to flash all of the files that failed previously
              Thanks for confirming.
