UNSOLVED Event Trigger for Status Messages
is it Possible somehow to Set an Event Trigger?
for example to get a Status Message when the Filament is Inserted in the Filamentswitch
- After Restart of the Bord, Loaded Filament in Tool 0 isn't regocnised anymore!
Tool 1 is ok!
- curl -F "file=@[output_filepath]" "http://MYIP/rr_upload?name=gcodes/[output_filename].gcode"
That code doesn't work in S3D with Duet Web Control 3.2.0 beta4, the Code is for the DuetWifi (other Thread...)
What do you Think about 2.?
After the Board is repowered, It has forgotten the previous loaded filament in Tool 0.
