    UNSOLVED Installing DSF on a Banana-Pi-M3 with Raspbian OS
    DSF Development
    8
    38
    2.3k
    • JayJayundefined
      JayJay
      Hello All
      I have a Banana-Pi -M3 that I have running a version of Raspbian.
      Im trying to install the DSF package following the guidelines here
      I have the file "duet.3d.list" in the following location "/etc/apt/sources.list.d/duet3d.list"
      im not 100% sure if i have the contents on the file correct as the guide is not so clear.
      I put two lines in that file:
      deb https://pkg.duet3d.com/ stable armv7
      http://pkg.duet3d.com/dists/stable/armv7/binary-armhf/
      then when i run the commands
      wget -q https://pkg.duet3d.com/duet3d.gpg
      sudo mv duet3d.gpg /etc/apt/trusted.gpg.d/
      sudo chown root:root /etc/apt/trusted.gpg.d/duet3d.gpg
      I get an error message :
      bash: https://pkg.duet3d.com/duet3d.gpg: No such file or directory
      Does anyone have any ideas where im going wrong ?
      Stephen6309undefined 1 Reply Last reply Reply Quote 0
      • A Former User?
        A Former User
        I do wget -qO - "https://pkg.duet3d.com/duet3d.gpg" | sudo apt-key add - which essentially does the same thing, but it seems unadvisable to add they key like that ref:
        https://unix.stackexchange.com/questions/332672/how-to-add-a-third-party-repo-and-key-in-debian/582853#582853
        but i'd guess you have some sort of formatting error that causes bash to look for the url instead of passing it as a paramter to wget, how are you running the commands, copy paste, script, both?
        JayJayundefined 1 Reply Last reply Reply Quote 0
        • Stephen6309undefined
          Stephen6309 @JayJay
          @JayJay pkg.duet3d.com/duet3d.gpg is not a web page.
          https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Software_Installation
          • A Former User?
            A Former User
            weather or not its a web page is kinda irelevant as its served by a web browser server and downloaded by a web client according to the instruction he listed and you linked to - but somehow OP is passing the url to bash instead of wget.
            • JayJayundefined
              JayJay @A Former User
              @bearer
              Thank you very much for taking the time to reply.
              I have tried inputing each command by manually typing each line in the terminal and I also tried copy paste and still the same occurs i will try the command you listed and see what happens.
              thank you again.
              • JayJayundefined
                JayJay
                im logged in as root and if i try using the code that @bearer listed i get the following error message
                gpg: key DA91C86B: no valid user IDs
                if i follow the link posted by @Stephen6309 i can input the following codes successfully :
                wget -q https://pkg.duet3d.com/duet3d.list
                sudo mv duet3d.list /etc/apt/sources.list.d/duet3d.list
                sudo chown root:root /etc/apt/sources.list.d/duet3d.list
                And with the code
                sudo apt-get install apt-transport-https
                It tells me everything is already the newest version
                But then when i type in :
                sudo apt-get update
                I receive the following error message
                W: GPG error: https://pkg.duet3d.com stable InRelease: Unkown error in executing gpgv
                when i try to use the command
                sudo apt-get install duetsoftwareframework
                it reads the packing list, then builds the depeendency tree and reads the "state" information then reports the following:
                *Some packages could not be installed. This may mean that you have requested an inpossible situation or if you are using the unstable distribution that some required packages have nopt yet been created or have been moved out of Incoming.
                The following information may help resolve the situation:
                the following packages have unmet dependencies:
                duetsoftwareframework :
                Depends : duetcontrolserver (= 3.1.1) but it is not going to be installed
                Depends : duetsd (= 1.0.6) but it is not going to be installed
                Depends : duettools (= 3.1.1) but it is not going to be installed
                Depends : duetwebserver (= 3.1.1) but it is not going to be installed
                Depends : reprapfirmware (>= 3.1.1-1) but it is not going to be installed
                Depends : reprapfirmware (<= 3.1.1-999) but it is not going to be installed
                E: Unable to correct problems, you have held broken packages *
                • A Former User?
                  A Former User
                  Not familiar with the banana pi, can you share the output from uname -a and cat /proc/cpuinfo?
                  • A Former User?
                    A Former User @A Former User
                    This post is deleted!
                    • A Former User?
                      A Former User @JayJay
                      @JayJay said in Installing DSF on a Banana-Pi-M3 with Raspbian OS:
                      btw seems to sugget bananapi with raspios/raspbian isnt fully compatible because it works just fine on the regular pi with regular raspios:
                      pi@raspberrypi:~$ wget -qO - "https://pkg.duet3d.com/duet3d.gpg" | sudo apt-key add -
                      OK
                      pi@raspberrypi:~$
                      • A Former User?
                        @bearer
                        The bananapi runs an ARMv7 processor, so it "should" work
                        Duet Software Framework resembles a collection of programs to control an attached Duet3D board from a Linux-based mini computer (SBC). Since it is using .NET Core, it requires an ARM processor that supports ARMv7 instructions processor is required
                        For clarity: I'm successfully running a banana-pi with DSF and i followed the guide the OP listed so im not sure why it worked for me but not him.
                        • JayJayundefined
                          JayJay
                          uname -a :
                          Linux bpi-iot-ros-ai 3.4.39-BPI-M3-Kernel #1 SMP PREEMT Sat May 26 10:03:38 UTC 2018 arm7l GNU/Linux
                          cat /proc/cpuinfo:
                          Processor                        : ARMv7 Processor rev 5 (v71)
                          processor                        : 0
                          BogoMIPS                         : 4800
                          processor                        : 1
                          BogoMIPS                         : 4800
                          processor                        : 2
                          BogoMIPS                         : 4800
                          processor                        : 3
                          BogoMIPS                         : 4800
                          processor                        : 4
                          BogoMIPS                         : 4800
                          processor                        : 5
                          BogoMIPS                         : 4800
                          processor                        : 6
                          BogoMIPS                         : 4800
                          processor                        : 7
                          BogoMIPS                         : 4800
                          Features                         : swp half thumb fastmult vfp edsp thumbee neon vfpv3 tls vfpv4 idiva idivt
                          CPU implementer                  : 0x41
                          CPU architecture                 : 7
                          CPU Variant                      : 0x0
                          CPU Part                         : 0xc07
                          CPU Revision                     : 5
                          Hardare                          : sun8i
                          Revision                         :  0000
                          Serial                           :        50300102008add2ed0e
                          @CaLviNx
                          you say you have this running on a bananapi, would you be able to share your image if that is even possible.
                          A Former User? A Former User? 2 Replies Last reply Reply Quote 0
                          • A Former User?
                            @JayJay
                            I'm not sure how to do that!
                            My banana-pi is an older M2 (says its an ARMv7 too though)
                            EDIT: im running Debian not raspbian (dont know if that makes a difference or not)
                            OS im running
                            • A Former User?
                              That's not raspbian/raspios is it?
                              • JayJayundefined
                                @bearer
                                well im not sure what its telling you, im a new user to linux in general , I just downloaded the version of raspbian from the bananapi forum my thinking was that if I used a bananapi version of raspbian I would have a better chance of success .
                                Raspbian for Bpi
                                  jay_s_uk @JayJay
                                  @JayJay you may be able to succeed with armbian
                                  • JayJayundefined
                                    JayJay @jay_s_uk
                                    @jay_s_uk
                                    i will try it thank you
                                    • JayJayundefined
                                      JayJay
                                      So progress or a sort.
                                      two steps forward and five back...
                                      I installed armbian THANK YOU @jay_s_uk which successfully allowed me to install DSF.
                                      I set the buffer size as requested, and according to the bananapi docs the M3 has the same pinout as a Rpi.
                                      I now get a new issue !!
                                      When I run : sudo systemctl start duetcontrolserver
                                      It outputs the following:
                                      Dec 20 19:30 bananapim3 DuetControlServer [724] : Started Duet control Server
                                      Dec 20 19:30 bananapim3 DuetControlServer [724] : Duet control Server v3.1.1
                                      Dec 20 19:30 bananapim3 DuetControlServer [724] : Written by Christian Hammacher for Duet3D
                                      Dec 20 19:30 bananapim3 DuetControlServer [724] : Licensed under the terms of the GNU Public License Version 3
                                      Dec 20 19:30 bananapim3 DuetControlServer [724] : [info] Settings Loaded
                                      Dec 20 19:30 bananapim3 DuetControlServer [724] : [Info] Environment initialized
                                      Dec 20 19:30 bananapim3 DuetControlServer [724] : [fatal] Could not connect to Duet (error 517. Cannot put line into event mode)
                                      And that then starts a loop
                                      Ideas ?
                                      • A Former User?
                                        A Former User
                                        You might need the gpio library used? (Sorry can't remember the name, but if you look for the loopback test thread i think it's mentioned there).
                                        edit: found the reference when on computer, so maybe try sudo apt-get install gpiod ?
                                        • JayJayundefined
                                          @bearer
                                          I installed the library and still no go.
                                          i invited a friend over who has a raspberry-pi (3b+) we plugged that in with a copy of official Raspbian image and that worked perfect, so i now know its not the Duet-3 .
                                          i tried to get into armbian-config to set the spi but armbian-config->system->hardware throws up an error :
                                          armbian-config hardware error expected at least 6 tokens for checklist have 4 use --help to list options. submodule.
                                          • JayJayundefined
                                            JayJay
                                            @bearer
                                            So i got raspbian to actaully install the DSF package but i now have an error which is evidently linked to the SPI connection not being activated.
                                            As i get the following error
                                            [Fatal] could not connecto to Duet (error 2 cannot open GPIO device file  '/dev/gpiochip0/
                                            I am not a linux user and I am not that good with coding so i really need a idiots step by step guide on what i need to do to enable the SPI
                                            on the banana-pi (even with raspbian) there is NO section in raspi-config to enable the SPI
                                            so im at a loss as to how i go about enabling it and i looked at some of the online guides on how to do this and i became very very lost as it is all greek to me.
                                            i installed RPI.GPIO but how to actually use it and configure things again all greek to me.
                                            is anyone able to advise ?
