SOLVED RRF 3.2RC1 - SPI task faulted on abort comand
Running 3.2RC1 on 6HC+3HC+SBC. Checked version and all are upgraded.
My macros seem to stop working. The following executed the first line as I can see on the printer.
Worked fine on B4.1.
Seems I can cause this by issuing abort command in a macro.[debug] Waiting for execution of G53 G0 X597 F6000 ; Move to the parking position with tool-0. This is 1mm less than pickup position (macro code) [debug] Waiting for execution of M581 P-1 T4 ; Remove trigger for when tool disconects while disconnecting it. (macro code) [debug] Waiting for execution of ; Unlock (macro code) [debug] Waiting for execution of M98 P"/sys/custom/tool_unlock.g" ; Unlock the tool (macro code) [debug] Waiting for execution of ; Move back carriage (macro code) [debug] Processing ; Prepare for moving [debug] Waiting for finish of ; Prepare for moving [debug] Completed ; Prepare for moving [debug] Processing M400 ;Wait for current moves to finish [debug] Waiting for finish of M400 ;Wait for current moves to finish [debug] Processing M106 S0 [debug] Waiting for finish of M106 S0 [debug] Processing M208 X600 ; Set axis software limits and min/max switch-triggering positions. Extended with tools [debug] Completed ; Note: tool offsets are applied at this point unless we preempt commands with G53! [debug] Completed ; Note: Prior to this macro, XYZ have been saved to slot 2 by the firmware as though a G60 S2 were executed. [debug] Waiting for finish of M208 X600 ; Set axis software limits and min/max switch-triggering positions. Extended with tools [debug] Waiting for execution of G53 G0 X575 F6000 ; Move the carraige to retract the pin until it clears the tool. (macro code) [debug] Processing M98 P"/sys/custom/EndStop_X-Max_Deactivate.g" ; Don't use the X max as EmergencyStop. [debug] Waiting for finish of M98 P"/sys/custom/EndStop_X-Max_Deactivate.g" ; Don't use the X max as EmergencyStop. [debug] Waiting for execution of G53 G0 X500 F30000 ; Rapid to a position where a future tool change won't hurt anything by returning to this position via its G60 S2 (macro code) [debug] Waiting for execution of M581 P3 T4 S1 ; Reattach trigger for when tool disconects after disconnecting it. (macro code) [debug] Processing M302 P0 ; Prevent Cold Extrudes, just in case temp setpoints are at 0 [debug] Waiting for finish of M302 P0 ; Prevent Cold Extrudes, just in case temp setpoints are at 0 [debug] Processing M400 ; Wait for current moves to finish [debug] Waiting for finish of M400 ; Wait for current moves to finish [debug] Processing ; Move into position [debug] Waiting for finish of ; Move into position [debug] Processing G53 G0 X555 F30000 ; Fast Move to the pickup position with tool-0. [debug] Waiting for finish of G53 G0 X555 F30000 ; Fast Move to the pickup position with tool-0. [debug] Processing G53 G0 X597 F6000 ; Move to the parking position with tool-0. This is 1mm less than pickup position [debug] Waiting for finish of G53 G0 X597 F6000 ; Move to the parking position with tool-0. This is 1mm less than pickup position [debug] Processing M581 P-1 T4 ; Remove trigger for when tool disconects while disconnecting it. [debug] Waiting for finish of M581 P-1 T4 ; Remove trigger for when tool disconects while disconnecting it. [debug] Processing ; Unlock [debug] Waiting for finish of ; Unlock [debug] Processing M98 P"/sys/custom/tool_unlock.g" ; Unlock the tool [debug] Waiting for finish of M98 P"/sys/custom/tool_unlock.g" ; Unlock the tool [debug] Processing ; Move back carriage [debug] Waiting for finish of ; Move back carriage [debug] Processing G53 G0 X575 F6000 ; Move the carraige to retract the pin until it clears the tool. [debug] Waiting for finish of G53 G0 X575 F6000 ; Move the carraige to retract the pin until it clears the tool. [debug] Processing G53 G0 X500 F30000 ; Rapid to a position where a future tool change won't hurt anything by returning to this position via its G60 S2 [debug] Waiting for finish of G53 G0 X500 F30000 ; Rapid to a position where a future tool change won't hurt anything by returning to this position via its G60 S2 [debug] Processing M581 P3 T4 S1 ; Reattach trigger for when tool disconects after disconnecting it. [debug] Waiting for finish of M581 P3 T4 S1 ; Reattach trigger for when tool disconects after disconnecting it. [debug] HTTP: Sent M400 ;Wait for current moves to finish, remaining space 1512, needed 24 [debug] HTTP: Sent M106 S0, remaining space 1480, needed 32 [debug] HTTP: Sent M208 X600 ; Set axis software limits and min/max switch-triggering positions. Extended with tools, remaining space 1448, needed 32 [debug] HTTP: Sent M98 P"/sys/custom/EndStop_X-Max_Deactivate.g" ; Don't use the X max as EmergencyStop., remaining space 1376, needed 72 [debug] HTTP: Sent M302 P0 ; Prevent Cold Extrudes, just in case temp setpoints are at 0, remaining space 1344, needed 32 [debug] HTTP: Sent M400 ; Wait for current moves to finish, remaining space 1320, needed 24 [debug] HTTP: Sent G53 G0 X555 F30000 ; Fast Move to the pickup position with tool-0., remaining space 1280, needed 40 [debug] HTTP: Sent G53 G0 X597 F6000 ; Move to the parking position with tool-0. This is 1mm less than pickup position, remaining space 1240, needed 40 [debug] HTTP: Sent M581 P-1 T4 ; Remove trigger for when tool disconects while disconnecting it., remaining space 1200, needed 40 [debug] HTTP: Sent M98 P"/sys/custom/tool_unlock.g" ; Unlock the tool, remaining space 1140, needed 60 [debug] HTTP: Sent G53 G0 X575 F6000 ; Move the carraige to retract the pin until it clears the tool., remaining space 1100, needed 40 [debug] HTTP: Sent G53 G0 X500 F30000 ; Rapid to a position where a future tool change won't hurt anything by returning to this position via its G60 S2, remaining space 1060, needed 40 [debug] HTTP: Sent M581 P3 T4 S1 ; Reattach trigger for when tool disconects after disconnecting it., remaining space 1012, needed 48 [debug] Completed M400 ;Wait for current moves to finish [debug] HTTP: Suspending code M302 P0 ; Prevent Cold Extrudes, just in case temp setpoints are at 0 [debug] Completed M106 S0 [debug] HTTP: Suspending code M400 ; Wait for current moves to finish [debug] Completed M208 X600 ; Set axis software limits and min/max switch-triggering positions. Extended with tools [debug] HTTP: Suspending code G53 G0 X555 F30000 ; Fast Move to the pickup position with tool-0. [debug] HTTP: Suspending code G53 G0 X597 F6000 ; Move to the parking position with tool-0. This is 1mm less than pickup position [debug] HTTP: Suspending code M581 P-1 T4 ; Remove trigger for when tool disconects while disconnecting it. [debug] Waiting for execution of ; Check so the tool is unmounted steady. (macro code) [debug] HTTP: Suspending code M98 P"/sys/custom/tool_unlock.g" ; Unlock the tool [debug] Processing ; Check so the tool is unmounted steady. [debug] HTTP: Suspending code G53 G0 X575 F6000 ; Move the carraige to retract the pin until it clears the tool. [debug] Waiting for finish of ; Check so the tool is unmounted steady. [debug] HTTP: Suspending code G53 G0 X500 F30000 ; Rapid to a position where a future tool change won't hurt anything by returning to this position via its G60 S2 [debug] HTTP: Suspending code M581 P3 T4 S1 ; Reattach trigger for when tool disconects after disconnecting it. [info] Starting macro file /sys/custom/EndStop_X-Max_Deactivate.g on channel HTTP [debug] HTTP: ==> Starting code M98 P"/sys/custom/EndStop_X-Max_Deactivate.g" ; Don't use the X max as EmergencyStop. [debug] Waiting for execution of M950 J14 C"nil" ; Don't use the input pin on io4 on the exp1 board as X max. (macro code) [debug] Processing M950 J14 C"nil" ; Don't use the input pin on io4 on the exp1 board as X max. [debug] Waiting for finish of M950 J14 C"nil" ; Don't use the input pin on io4 on the exp1 board as X max. [debug] HTTP: Sent M950 J14 C"nil" ; Don't use the input pin on io4 on the exp1 board as X max., remaining space 1492, needed 44 [debug] Requesting update of key move, seq 75 -> 76 [debug] Completed M950 J14 C"nil" ; Don't use the input pin on io4 on the exp1 board as X max. [debug] Finished codes from macro file /sys/custom/EndStop_X-Max_Deactivate.g [info] Finished macro file /sys/custom/EndStop_X-Max_Deactivate.g [debug] Updated key move [debug] HTTP: ==> Unfinished starting code: M98 P"/sys/custom/EndStop_X-Max_Deactivate.g" ; Don't use the X max as EmergencyStop. [debug] HTTP: Disposing macro file /sys/custom/EndStop_X-Max_Deactivate.g [debug] HTTP: Sent M302 P0 ; Prevent Cold Extrudes, just in case temp setpoints are at 0, remaining space 1504, needed 32 [debug] HTTP: -> Resumed suspended code [debug] HTTP: Sent M400 ; Wait for current moves to finish, remaining space 1480, needed 24 [debug] HTTP: -> Resumed suspended code [debug] HTTP: Sent G53 G0 X555 F30000 ; Fast Move to the pickup position with tool-0., remaining space 1440, needed 40 [debug] HTTP: -> Resumed suspended code [debug] HTTP: Sent G53 G0 X597 F6000 ; Move to the parking position with tool-0. This is 1mm less than pickup position, remaining space 1400, needed 40 [debug] Completed M98 P"/sys/custom/EndStop_X-Max_Deactivate.g" ; Don't use the X max as EmergencyStop. [debug] HTTP: -> Resumed suspended code [debug] HTTP: Sent M581 P-1 T4 ; Remove trigger for when tool disconects while disconnecting it., remaining space 1360, needed 40 [debug] HTTP: -> Resumed suspended code [debug] HTTP: -> Resumed suspended code [debug] HTTP: -> Resumed suspended code [debug] HTTP: -> Resumed suspended code [debug] HTTP: -> Resumed suspended code [debug] Cancelled ; Check so the tool is unmounted steady. [info] Aborted macro file /sys/custom/tfree_end.g [debug] Cancelled M581 P3 T4 S1 ; Reattach trigger for when tool disconects after disconnecting it. [debug] Cancelled G53 G0 X500 F30000 ; Rapid to a position where a future tool change won't hurt anything by returning to this position via its G60 S2 [debug] Cancelled G53 G0 X555 F30000 ; Fast Move to the pickup position with tool-0. [debug] Cancelled G53 G0 X575 F6000 ; Move the carraige to retract the pin until it clears the tool. [debug] Cancelled M98 P"/sys/custom/tool_unlock.g" ; Unlock the tool [debug] Cancelled ; Move back carriage [debug] Cancelled ; Move into position [debug] Cancelled M581 P-1 T4 ; Remove trigger for when tool disconects while disconnecting it. [debug] Cancelled G53 G0 X597 F6000 ; Move to the parking position with tool-0. This is 1mm less than pickup position [debug] Cancelled M400 ; Wait for current moves to finish [debug] Completed M302 P0 ; Prevent Cold Extrudes, just in case temp setpoints are at 0 [debug] Cancelled ; Unlock [debug] Finished codes from macro file /sys/custom/tfree_end.g [debug] HTTP: ==> Unfinished starting code: M98 P"/sys/custom/tfree_end.g" ; Set axis max for print area [debug] HTTP: Disposing macro file /sys/custom/tfree_end.g [debug] Completed M98 P"/sys/custom/tfree_end.g" ; Set axis max for print area [debug] Completed G53 G0 Y515 F30000 ; Rapid to the Y approach position with tool. [debug] Finished codes from macro file tfree49.g [info] Finished macro file tfree49.g [debug] HTTP: ==> Unfinished starting code: T-1 [debug] HTTP: Disposing macro file tfree49.g [debug] Requesting update of key heat, seq 16 -> 17 [debug] Updated key heat [debug] Requesting update of key inputs, seq 22 -> 23 [debug] Updated key inputs [debug] Completed T-1 [debug] Finished codes from macro file homez.g [info] Finished macro file homez.g [debug] HTTP: ==> Unfinished starting code: M98 P"homez.g" ; Home Z [debug] HTTP: Disposing macro file homez.g [debug] HTTP: Sent G32 ; Run 3-point bed calibration defined in bed.g, remaining space 1512, needed 24 [debug] HTTP: -> Resumed suspended code [debug] Completed M98 P"homez.g" ; Home Z [info] Starting macro file bed.g on channel HTTP [debug] HTTP: ==> Starting code G32 ; Run 3-point bed calibration defined in bed.g [debug] Waiting for execution of ; bed.g (macro code) [debug] Waiting for execution of ; called to perform automatic bed compensation via G32 (macro code) [debug] Waiting for execution of ; (macro code) [debug] Processing ; bed.g [debug] Waiting for execution of ;G91 ; Relative to move bed down (macro code) [debug] Waiting for finish of ; bed.g [debug] Waiting for execution of ;G0 Z5 F6000 ; Move the bed further from the nozzle prior to any tool moves. No G53 needed because this is a relative move. (macro code) [debug] Processing ; called to perform automatic bed compensation via G32 [debug] Waiting for finish of ; called to perform automatic bed compensation via G32 [debug] Completed ; called to perform automatic bed compensation via G32 [debug] Waiting for execution of ;G90 ; Return to absolute (macro code) [debug] Processing ; [debug] Completed ; bed.g [debug] Waiting for finish of ; [debug] Waiting for execution of T49 ; Select and Set Z switch to Probe (macro code) [debug] Completed ; [debug] Processing ;G91 ; Relative to move bed down [debug] Waiting for execution of G30 P0 X5 Y264.5 Z-99999 ; probe near left leadscrew (macro code) [debug] Waiting for finish of ;G91 ; Relative to move bed down [debug] Completed ;G91 ; Relative to move bed down [debug] Processing ;G0 Z5 F6000 ; Move the bed further from the nozzle prior to any tool moves. No G53 needed because this is a relative move. [debug] Waiting for execution of G30 P1 X495 Y495 Z-99999 ; probe near back leadscrew (macro code) [debug] Waiting for finish of ;G0 Z5 F6000 ; Move the bed further from the nozzle prior to any tool moves. No G53 needed because this is a relative move. [debug] Waiting for execution of G30 P2 X495 Y5 Z-99999 S3 ; probe near front leadscrew and calibrate 3 motors (macro code) [debug] Completed ;G0 Z5 F6000 ; Move the bed further from the nozzle prior to any tool moves. No G53 needed because this is a relative move. [debug] Processing ;G90 ; Return to absolute [debug] Waiting for finish of ;G90 ; Return to absolute [debug] Completed ;G90 ; Return to absolute [debug] Processing T49 ; Select and Set Z switch to Probe [debug] Waiting for finish of T49 ; Select and Set Z switch to Probe [debug] Waiting for execution of echo "Gantry deviation of " ^ move.calibration.initial.deviation ^ "mm obtained." (macro code) [debug] Processing G30 P0 X5 Y264.5 Z-99999 ; probe near left leadscrew [debug] Waiting for finish of G30 P0 X5 Y264.5 Z-99999 ; probe near left leadscrew [debug] Waiting for execution of T-1 ; Deselect ProbeTool (macro code) [debug] Processing G30 P1 X495 Y495 Z-99999 ; probe near back leadscrew [debug] Waiting for finish of G30 P1 X495 Y495 Z-99999 ; probe near back leadscrew [debug] Processing G30 P2 X495 Y5 Z-99999 S3 ; probe near front leadscrew and calibrate 3 motors [debug] Waiting for finish of G30 P2 X495 Y5 Z-99999 S3 ; probe near front leadscrew and calibrate 3 motors [debug] Processing echo "Gantry deviation of " ^ move.calibration.initial.deviation ^ "mm obtained." [debug] HTTP: Sent T49 ; Select and Set Z switch to Probe, remaining space 1512, needed 24 [debug] HTTP: Sent G30 P0 X5 Y264.5 Z-99999 ; probe near left leadscrew, remaining space 1456, needed 56 [debug] HTTP: Sent G30 P1 X495 Y495 Z-99999 ; probe near back leadscrew, remaining space 1400, needed 56 [debug] HTTP: Sent G30 P2 X495 Y5 Z-99999 S3 ; probe near front leadscrew and calibrate 3 motors, remaining space 1336, needed 64 [debug] HTTP: Suspending code G30 P0 X5 Y264.5 Z-99999 ; probe near left leadscrew [debug] HTTP: Suspending code G30 P1 X495 Y495 Z-99999 ; probe near back leadscrew [debug] HTTP: Suspending code G30 P2 X495 Y5 Z-99999 S3 ; probe near front leadscrew and calibrate 3 motors [debug] Macro file tpre49.g not found [debug] HTTP: ==> Starting code T49 ; Select and Set Z switch to Probe [debug] HTTP: Disposing macro file tpre49.g [debug] HTTP: ==> Unfinished starting code: T49 ; Select and Set Z switch to Probe [debug] HTTP: Sent G30 P0 X5 Y264.5 Z-99999 ; probe near left leadscrew, remaining space 1456, needed 56 [debug] HTTP: -> Resumed suspended code [debug] HTTP: Sent G30 P1 X495 Y495 Z-99999 ; probe near back leadscrew, remaining space 1400, needed 56 [debug] HTTP: -> Resumed suspended code [debug] HTTP: Sent G30 P2 X495 Y5 Z-99999 S3 ; probe near front leadscrew and calibrate 3 motors, remaining space 1336, needed 64 [debug] HTTP: -> Resumed suspended code [debug] HTTP: Suspending code G30 P0 X5 Y264.5 Z-99999 ; probe near left leadscrew [debug] HTTP: Suspending code G30 P1 X495 Y495 Z-99999 ; probe near back leadscrew [debug] HTTP: Suspending code G30 P2 X495 Y5 Z-99999 S3 ; probe near front leadscrew and calibrate 3 motors [info] Starting macro file tpost49.g on channel HTTP [debug] HTTP: ==> Starting code T49 ; Select and Set Z switch to Probe [debug] Waiting for execution of ; Mounting (macro code) [debug] Waiting for execution of ; runs after firmware thinks Tool49 is selected (macro code) [debug] Waiting for execution of ; Note: tool offsets are applied at this point! (macro code) [debug] Waiting for execution of ; Note that commands prefixed with G53 will NOT apply the tool offset. (macro code) [debug] Waiting for execution of ; Check so no tool is mounted before trying to mount one. (macro code) [debug] Processing ; Mounting [debug] Waiting for finish of ; Mounting [debug] Processing ; runs after firmware thinks Tool49 is selected [debug] Waiting for finish of ; runs after firmware thinks Tool49 is selected [debug] Processing ; Note: tool offsets are applied at this point! [debug] Waiting for finish of ; Note: tool offsets are applied at this point! [debug] Processing ; Note that commands prefixed with G53 will NOT apply the tool offset. [debug] Waiting for finish of ; Note that commands prefixed with G53 will NOT apply the tool offset. [debug] Completed ; Mounting [debug] Processing ; Check so no tool is mounted before trying to mount one. [debug] Completed ; runs after firmware thinks Tool49 is selected [debug] Waiting for finish of ; Check so no tool is mounted before trying to mount one. [debug] Completed ; Note: tool offsets are applied at this point! [debug] Completed ; Note that commands prefixed with G53 will NOT apply the tool offset. [debug] Completed ; Check so no tool is mounted before trying to mount one. [debug] Evaluating If block [debug] Evaluating 3 on channel HTTP [debug] Evaluating sensors.gpIn[3].value!=1 on channel HTTP [debug] Evaluation result: (sensors.gpIn[3].value!=1) = True [debug] Doing Abort [debug] Waiting for execution of abort "tpost49.g: Tool already picked up. Manually return tool to the dock" (macro code) [debug] Processing abort "tpost49.g: Tool already picked up. Manually return tool to the dock" [debug] Evaluating "tpost49.g: Tool already picked up. Manually return tool to the dock" on channel HTTP [debug] Waiting for finish of abort "tpost49.g: Tool already picked up. Manually return tool to the dock" [debug] Completed abort "tpost49.g: Tool already picked up. Manually return tool to the dock" [debug] Finished codes from macro file tpost49.g [info] Finished macro file tpost49.g [debug] Completed T49 ; Select and Set Z switch to Probe => tpost49.g: Tool already picked up. Manually return tool to the dock
Continuing:
[fatal] Abnormal program termination [fatal] SPI task faulted System.ObjectDisposedException: The CancellationTokenSource has been disposed. at System.Threading.CancellationTokenSource.ThrowObjectDisposedException() at System.Threading.CancellationTokenSource.Cancel() at DuetControlServer.FileExecution.Macro.Abort() in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/FileExecution/Macro.cs:line 236 at DuetControlServer.SPI.Channel.Processor.AbortFile(Boolean abortAll, Boolean printStopped) in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/SPI/Channel/Processor.cs:line 463 at DuetControlServer.SPI.Channel.Processor.Run() in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/SPI/Channel/Processor.cs:line 591 at DuetControlServer.SPI.Channel.Manager.Run() in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/SPI/Channel/Manager.cs:line 104 at DuetControlServer.SPI.Interface.Run() in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/SPI/Interface.cs:line 810 [debug] IPC#69: Subscriber connection requested to terminate [debug] IPC#69: Subscription processor unregistered [debug] IPC#12: Subscriber connection requested to terminate [debug] IPC#69: Connection closed [debug] IPC#12: Subscription processor unregistered [debug] IPC#12: Connection closed [debug] IPC#4: Subscriber connection requested to terminate [debug] IPC#8: Subscriber connection requested to terminate [debug] IPC#4: Subscription processor unregistered [debug] IPC#4: Connection closed [debug] IPC#8: Subscription processor unregistered [debug] IPC#8: Connection closed [debug] Cancelled G30 P2 X495 Y5 Z-99999 S3 ; probe near front leadscrew and calibrate 3 motors [debug] IPC#70: Connection closed [debug] IPC#13: Connection closed [debug] IPC#9: Connection closed [debug] Cancelled G30 P1 X495 Y495 Z-99999 ; probe near back leadscrew [debug] IPC#5: Connection closed [info] Event logging stopped [debug] HTTP: Disposing macro file tpost49.g [warn] HTTP: Aborting orphaned macro file bed.g [info] Aborted macro file bed.g [warn] HTTP: ==> Cancelling unfinished starting code: G32 ; Run 3-point bed calibration defined in bed.g [warn] HTTP: Aborting orphaned macro file homeall.g [info] Aborted macro file homeall.g [warn] HTTP: ==> Cancelling unfinished starting code: G28 [fatal] SPI task faulted System.ObjectDisposedException: The CancellationTokenSource has been disposed. at System.Threading.CancellationTokenSource.ThrowObjectDisposedException() at System.Threading.CancellationTokenSource.Cancel() at DuetControlServer.FileExecution.Macro.Abort() in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/FileExecution/Macro.cs:line 236 at DuetControlServer.SPI.Channel.Processor.AbortFile(Boolean abortAll, Boolean printStopped) in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/SPI/Channel/Processor.cs:line 463 at DuetControlServer.SPI.Channel.Processor.Run() in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/SPI/Channel/Processor.cs:line 591 at DuetControlServer.SPI.Channel.Manager.Run() in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/SPI/Channel/Manager.cs:line 104 at DuetControlServer.SPI.Interface.Run() in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/SPI/Interface.cs:line 810 [debug] Update task terminated [debug] Periodic updater task terminated [debug] Cancelled G28 [debug] Job task terminated [debug] Cancelled echo "Gantry deviation of " ^ move.calibration.initial.deviation ^ "mm obtained." [debug] Cancelled G30 P0 X5 Y264.5 Z-99999 ; probe near left leadscrew [debug] IPC#81: Connection closed [debug] IPC task terminated [debug] Stopping plugins and saving their execution state [debug] Cancelled G32 ; Run 3-point bed calibration defined in bed.g [debug] Cancelled G29 S1 ; Enable and load Mesh Bed Compensation [info] Application has shut down
And the Debug after the board restarted:
=== Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.2-RC1 running on Duet 3 MB6HC v0.6 or 1.0 (SBC mode) Board ID: 08DJM-956L2-G43S4-6JKDD-3SJ6L-TB62G Used output buffers: 1 of 40 (14 max) === RTOS === Static ram: 149788 Dynamic ram: 64212 of which 176 recycled Never used RAM 144656, free system stack 128 words Tasks: Linux(ready,49) HEAT(blocked,296) CanReceiv(blocked,833) CanSender(blocked,352) CanClock(blocked,352) TMC(blocked,19) MAIN(running,1189) IDLE(ready,19) Owned mutexes: HTTP(MAIN) === Platform === Last reset 00:34:59 ago, cause: software Last software reset at 2020-12-21 23:34, reason: StackOverflow, GCodes spinning, available RAM 144732, slot 0 Software reset code 0x4103 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0040080e BFAR 0x00000000 SP 0x2045ffb4 Task Freestk 46173 bad marker Stack: 20432de0 20432e14 0046b47d 00000000 00004ff0 00004ff0 20433058 20433534 0046aaa9 20432dec 2041fe00 00000000 00f00000 e000ef34 c0000000 2041fe0c 0046abd1 0046a93c 21000000 ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff Error status: 0x00 Aux0 errors 0,0,0 Aux1 errors 0,0,0 MCU temperature: min 39.5, current 42.0, max 42.2 Supply voltage: min 27.9, current 31.9, max 32.0, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 12.0, current 12.0, max 12.1, under voltage events: 0 Driver 0: position 177775, standstill, reads 31972, writes 24 timeouts 0, SG min/max 0/135 Driver 1: position 13151, standstill, reads 31972, writes 24 timeouts 0, SG min/max 0/143 Driver 2: position 12800, standstill, reads 31973, writes 23 timeouts 0, SG min/max 0/81 Driver 3: position 0, standstill, reads 31977, writes 19 timeouts 0, SG min/max 0/142 Driver 4: position 0, standstill, reads 31978, writes 19 timeouts 0, SG min/max 0/156 Driver 5: position 0, standstill, reads 31978, writes 19 timeouts 0, SG min/max 0/99 Date/time: 2020-12-22 00:09:58 Slowest loop: 122.73ms; fastest: 0.05ms === Storage === Free file entries: 10 SD card 0 not detected, interface speed: 37.5MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === DMs created 125, maxWait 241564ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 36, completed moves 36, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 === GCodes === Segments left: 0 Movement lock held by null HTTP* is doing "M122" in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === CAN === Messages queued 8459, send timeouts 0, received 25255, lost 0, longest wait 1ms for reply type 6043, free buffers 47 === SBC interface === State: 4, failed transfers: 0 Last transfer: 2ms ago RX/TX seq numbers: 14024/26259 SPI underruns 0, overruns 0 Number of disconnects: 1, IAP RAM available 0x2c85c Buffer RX/TX: 0/0-0 === Duet Control Server === Duet Control Server v3.2.0-rc1 Code buffer space: 4096 Configured SPI speed: 8000000 Hz Full transfers per second: 35.73 Maximum length of RX/TX data transfers: 3359/36
This post is deleted!
This macro always crashes for me on RC1. Can anyone confirm?
M118 S"Start testing" L1 abort "Testing Abort" M118 S"Aborted already" L1
@TypQxQ said in RRF 3.2RC1 - SPI task faulted on abort comand:
Thanks, I can confirm that. It will be fixed in RC2.
