    How to disable mesh probing grid?
    Gcode meta commands
    • Depundefined
      Dep
      The G29 command can be run with the extruder installed. This is unacceptable for a toolchanger.
      I want to write a macro that will check if there is an extruder on the carriage and start the calibration.
      I can remove the M557 command from config.g so that the G29 command cannot be executed. But after running the macro, the probing grid will be defined and the G29 command can start probing.
      Is there a way to clean up the probing grid definition?
      • chrishammundefined
        chrishamm administrators
        If you are using an experimental 3.2 version (> 3.1.1) you can create mesh.g that is executed when you run G29. Right at the start you can then add a check to abort the macro file if a tool is selected. It could look something like
        if state.currentTool != -1
          abort "Cannot do mesh probing when a tool is selected"
        G29 S0
        Or just deselect the tool (if set) and then continue with mesh probing
        T-1
        G29 S0
        Duet software engineer
        • Depundefined
          Dep
          I am currently using 3.2-beta 4.1
          Thanks for the quick response! So I will do it.
          • Stephen6309undefined
            Stephen6309
            An alternative is to use G32 and in bed.g put:
            G29 S1 ; load current heightmap.csv
            if result > 1 ; if no heightmap.csv, make one.
            G29 S0
