    SBC RPI 3 Installation Problems
    Firmware installation
    • NeueKlasseundefined
      NeueKlasse
      Now i've got an Pi3 to test... (i wanted the Pi for Camera integration...)
      i didn't had these Problems on the Pi4 (whatever.. communication problems...)
      The DuetPi Image was working till i wanted to Update to 3.2.0-rc2..
      to match the Firmware that i Installed during Standalone mode
      Problems with duetcontrolserver is not configured yet,
      and the Other Packages say.. Problems with duetsoftwareframework is not configured yet.
      After Remove sudo apt remove duetcontrolserver and reinstalling....
      it's the same thing, what did i wrong?
      Setting up duetruntime (3.2.0-rc2) ...
      Setting up duetcontrolserver (3.2.0-rc2) ...
      dpkg: error processing package duetcontrolserver (--configure):
      installed duetcontrolserver package post-installation script subprocess returned error exit status 1
      dpkg: dependency problems prevent configuration of duettools:
      duettools depends on duetcontrolserver (= 3.2.0-rc2); however:
      Package duetcontrolserver is not configured yet.
      dpkg: error processing package duettools (--configure):
      dependency problems - leaving unconfigured
      dpkg: dependency problems prevent configuration of duetwebserver:
      duetwebserver depends on duetcontrolserver (>= 3.2.0-rc2); however:
      dpkg: error processing package duetwebserver (--configure):
      dpkg: dependency problems prevent configuration of duetsoftwareframework:
      duetsoftwareframework depends on duetcontrolserver (= 3.2.0-rc2); however:
      duetsoftwareframework depends on duettools (= 3.2.0-rc2); however:
      Package duettools is not configured yet.
      duetsoftwareframework depends on duetwebserver (= 3.2.0-rc2); however:
      Package duetwebserver is not configured yet.
      dpkg: error processing package duetsoftwareframework (--configure):
      dpkg: dependency problems prevent configuration of reprapfirmware:
      reprapfirmware depends on duetsoftwareframework (>= 3.2.0); however:
      Package duetsoftwareframework is not configured yet.
      reprapfirmware depends on duetcontrolserver (>= 1.2.0.0); however:
      dpkg: error processing package reprapfirmware (--configure):
      dpkg: dependency problems prevent configuration of duetwebcontrol:
      duetwebcontrol depends on duetsoftwareframework (>= 3.2.0); however:
      dpkg: error processing package duetwebcontrol (--configure):
      dpkg: dependency problems prevent configuration of duetsd:
      duetsd depends on duetsoftwareframework (>= 3.2.0); however:
      dpkg: error processing package duetsd (--configure):
      Processing triggers for install-info (6.5.0.dfsg.1-4+b1) ...
      Processing triggers for libc-bin (2.28-10+rpi1) ...
      Processing triggers for man-db (2.8.5-2) ...
      Errors were encountered while processing:
      duetcontrolserver
      duettools
      duetwebserver
      reprapfirmware
      duetwebcontrol
      duetsd
      E: Sub-process /usr/bin/dpkg returned an error code (1)
      Prusa Mini, Chiron @ BMG X2
      Metal SLS Printer Development
      • A Former User?
        A Former User
        @NeueKlasse said in SBC RPI 3 Installation Problems:
        edit: backup your /opt/dsf/sd folder to be on the safe side.
        you should probably remove all the duet packages + reprapfirmware package, then install duetsoftwareframwrok letting apt deal with dependencies.
        sudp apt remove duetcontrolserver duetruntime duetsd duetsoftwareframework duettools duetwebcontrol duetwebserver reprapfirmware
        sudo apt install duetsoftwareframework
        or try aptitude, seems to handle dependency issues better than apt.
