    cannot get 3hc to connect.
    Firmware installation
    1.6k
    • bamundefined
      bam
      m409
      {"key":"","flags":"","result":{"boards":[{}],"directories":{},"fans":[],"heat":{},"inputs":[{},{},{},{},{},{},{},{},{},{},{},{}],"job":{},"limits":{},"move":{},"network":{},"sensors":{},"seqs":{},"spindles":[{},{}],"state":{},"tools":[],"volumes":[{}]}}
      12/31/2020, 11:18:40 PM Warning: 12V under-voltage event (9.4V)
      12/31/2020, 11:16:15 PM m98 p"config.g"
      12/31/2020, 11:16:03 PM m98 p "config.g"
      Error: M98: non-empty string expected
      12/31/2020, 11:15:53 PM m98 p config.g
      12/31/2020, 11:15:42 PM m98 p
      12/31/2020, 11:15:37 PM m98
      Error: M98: missing parameter 'P'
      12/31/2020, 11:14:50 PM Download of config.g successful after 0s
      12/31/2020, 11:14:08 PM M98 P"config.g"
      12/31/2020, 11:13:59 PM M98 P"config.g
      Error: Unterminated string
      12/31/2020, 11:13:35 PM M98 P"config.g
      12/31/2020, 11:12:22 PM m115 b15
      Error: M115: Response timeout: CAN addr 15, req type 6024, RID=2
      12/31/2020, 11:12:22 PM Connection to Duet established
      12/31/2020, 11:12:22 PM Warning: Lost connection to Duet (Timeout while waiting for transfer ready pin)
      12/31/2020, 11:12:05 PM m115 b126
      Error: M115: Response timeout: CAN addr 126, req type 6024, RID=1
      12/31/2020, 11:12:05 PM Connection to Duet established
      12/31/2020, 11:12:04 PM Warning: Lost connection to Duet (Timeout while waiting for transfer ready pin)
      12/31/2020, 11:05:22 PM m115
      FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.1.1 ELECTRONICS: Duet 3 MB6HC v1.01 or later FIRMWARE_DATE: 2020-05-19b2
      12/31/2020, 11:04:35 PM m451
      12/31/2020, 11:02:56 PM M952 b126 a1
      Error: M952: Response timeout: CAN addr 126, req type 2010, RID=0
      12/31/2020, 11:02:56 PM Connection to Duet established
      12/31/2020, 11:02:56 PM Warning: Lost connection to Duet (Timeout while waiting for transfer ready pin)
      12/31/2020, 11:01:45 PM M954 b126
      Warning: M954: Command is not supported
      12/31/2020, 10:59:27 PM Connection to Duet established
      12/31/2020, 10:59:27 PM Warning: Lost connection to Duet (Board is not available (no header))
      12/31/2020, 10:57:43 PM M115 b126
      Error: M115: Response timeout: CAN addr 126, req type 6024, RID=2
      12/31/2020, 10:57:43 PM Connection to Duet established
      12/31/2020, 10:57:43 PM Warning: Lost connection to Duet (Timeout while waiting for transfer ready pin)
      12/31/2020, 10:54:47 PM M115 b126
      12/31/2020, 10:54:46 PM Connection to Duet established
      12/31/2020, 10:54:46 PM Warning: Lost connection to Duet (Timeout while waiting for transfer ready pin)
      12/31/2020, 10:53:57 PM Warning: 12V under-voltage event (9.5V)
      12/31/2020, 10:52:10 PM M115 b126
      Error: M115: Response timeout: CAN addr 126, req type 6024, RID=0
      12/31/2020, 10:52:10 PM Connection to Duet established
      12/31/2020, 10:52:10 PM Warning: Lost connection to Duet (Timeout while waiting for transfer ready pin)
      12/31/2020, 10:50:06 PM M115
      12/31/2020, 10:49:46 PM Upload of Duet3Firmware_MB6HC.bin successful after 0s
      12/31/2020, 10:44:33 PM M115
      12/31/2020, 10:42:49 PM M115 B1
      Error: M115: Response timeout: CAN addr 1, req type 6024, RID=5
      12/31/2020, 10:42:49 PM Connection to Duet established
      12/31/2020, 10:42:48 PM Warning: Lost connection to Duet (Timeout while waiting for transfer ready pin)
      12/31/2020, 10:42:44 PM M115 B123
      Error: M115: Response timeout: CAN addr 123, req type 6024, RID=4
      12/31/2020, 10:42:43 PM Connection to Duet established
      12/31/2020, 10:42:43 PM Warning: Lost connection to Duet (Timeout while waiting for transfer ready pin)
      12/31/2020, 10:42:33 PM M115 B121
      Error: M115: Response timeout: CAN addr 121, req type 6024, RID=3
      12/31/2020, 10:42:33 PM Connection to Duet established
      12/31/2020, 10:42:32 PM Warning: Lost connection to Duet (Timeout while waiting for transfer ready pin)
      12/31/2020, 10:42:21 PM M115 B122
      Error: M115: Response timeout: CAN addr 122, req type 6024, RID=2
      12/31/2020, 10:42:20 PM Connection to Duet established
      12/31/2020, 10:42:20 PM Warning: Lost connection to Duet (Timeout while waiting for transfer ready pin)
      12/31/2020, 10:40:47 PM m954
      12/31/2020, 10:40:24 PM m997 b1
      Error: M997: Response timeout: CAN addr 1, req type 6024, RID=1
      12/31/2020, 10:40:24 PM Connection to Duet established
      12/31/2020, 10:40:24 PM Warning: Lost connection to Duet (Timeout while waiting for transfer ready pin)
      12/31/2020, 10:40:08 PM m954 b1
      12/31/2020, 10:31:45 PM m954 b1
      12/31/2020, 10:31:38 PM m954
      12/31/2020, 10:26:56 PM m997 b1
      Error: M997: Response timeout: CAN addr 1, req type 6024, RID=0
      12/31/2020, 10:26:56 PM Connection to Duet established
      12/31/2020, 10:26:55 PM Warning: Lost connection to Duet (Timeout while waiting for transfer ready pin)
      12/31/2020, 10:19:10 PM m575 p1b57600 s1
      12/31/2020, 10:18:08 PM M122
      RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v1.01 or later (SBC mode)
      Board ID: 08DJM-956BA-NA3TJ-6JTD2-3SN6K-9BAQU
      Used output buffers: 1 of 40 (10 max)
      Static ram: 154604
      Dynamic ram: 161360 of which 20 recycled
      Exception stack ram used: 224
      Never used ram: 77008
      Tasks: NETWORK(ready,1980) HEAT(blocked,1416) CanReceiv(suspended,3820) CanSender(suspended,1488) CanClock(blocked,1460) TMC(blocked,204) MAIN(running,5128) IDLE(ready,76)
      Owned mutexes:
      Last reset 00:00:40 ago, cause: software
      Last software reset details not available
      Error status: 0
      MCU temperature: min 46.8, current 47.1, max 47.3
      Supply voltage: min 24.0, current 24.1, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
      12V rail voltage: min 12.2, current 12.3, max 12.3, under voltage events: 0
      Driver 0: standstill, reads 1305, writes 11 timeouts 0, SG min/max 0/0
      Driver 1: standstill, reads 1306, writes 11 timeouts 0, SG min/max 0/0
      Driver 2: standstill, reads 1306, writes 11 timeouts 0, SG min/max 0/0
      Driver 3: standstill, reads 1307, writes 11 timeouts 0, SG min/max 0/0
      Driver 4: standstill, reads 1307, writes 11 timeouts 0, SG min/max 0/0
      Driver 5: standstill, reads 1308, writes 11 timeouts 0, SG min/max 0/0
      Date/time: 2020-12-31 22:18:06
      Slowest loop: 3.44ms; fastest: 0.14ms
      === Storage ===
      Free file entries: 10
      Hiccups: 0(0), FreeDm: 375, MinFreeDm: 375, MaxWait: 0ms
      === MainDDARing ===
      Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
      === AuxDDARing ===
      Bed heaters = -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
      Segments left: 0
      Movement lock held by null
      HTTP* is ready with "M122" in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon* is idle in state(s) 0 0, running macro
      Aux2 is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 1.08ms; fastest: 0.01ms
      Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions
      HTTP sessions: 0 of 8
      • Ethernet -
        State: disabled
        Error counts: 0 0 0 0 0
        === CAN ===
        Messages sent 0, longest wait 0ms for type 0
        === Linux interface ===
        State: 0, failed transfers: 0
        Last transfer: 17ms ago
        RX/TX seq numbers: 60298/1291
        SPI underruns 0, overruns 0
        Number of disconnects: 0
        Buffer RX/TX: 0/0-0
        === Duet Control Server ===
        Duet Control Server v3.1.1
        Daemon:
        Finishing macro daemon.g, started by system
      Next stack level
      Code buffer space: 4096
      Configured SPI speed: 8000000 Hz
      Full transfers per second: 32.20
      12/31/2020, 10:17:29 PM m997 b#
      12/31/2020, 10:16:35 PM m997
      12/31/2020, 9:54:11 PM Connected to duet3
      • Vetiundefined
        Veti
        post your config.g
        also
        it seems you have a problem with your power supply
        bamundefined 2 Replies Last reply Reply Quote 0
        • A Former User?
          A Former User @bam
          @bam said in cannot get 3hc to connect.:
          btw the first one worked (as did the 3rd from the bottom); so no syntax or other errors in the config.g file (edit: at that time)
            When the system has settled down, does the red LED on the 3HC flash in sync with the red LED on the main board, half a second pff and half a second on? If it doesn't then the CAN connection is missing.
            I suggest you update DSF and RRF to the 3.2RC2, or alternatively run the main board in standalone mode until you have established communication with the 3HC.
            • bamundefined
              bam @Veti
              @Veti that happened when I flipped the switch off
              • bamundefined
                bam @dc42
                @dc42 when I had the main board on 3.2 it wouldn’t talk to the DWC
                • bamundefined
                  bam @dc42
                  @dc42 4 flashes only on the 3hc
                    dc42 administrators @bam
                    Do you mean it flashes 4 times and then repeats, or something else?
                    What do you have the address switches set to?
                    bamundefined 1 Reply Last reply Reply Quote 0
                      PS - RRF 3.2 on the main board will need DSF 3.2 on the Pi to connect.
                      • bamundefined
                        bam @dc42
                        @dc42 4 flashes then it stops then 4 flashes. It’s asking for firmware update. I think.
                          The error codes indicated by flashes are lisated at https://duet3d.dozuki.com/Wiki/CAN_connection#Section_LED_behaviour_and_error_codes. Normally you would see alternating 2 or 3 flashes (indicating no valid firmware installed followed by 4 flashes. Anyway, 4 flashes indicates that the main board didn't respond. This normally means that either the main board is not running, or the CAN connection is broken or mis-wired.
                          • bamundefined
                            bam @dc42
                            @dc42 That’s probably the issue then because I am just using standard issue phone cord
                            • bamundefined
                              bam @Veti
                              @Veti ; Configuration file for Duet 3 (firmware version 3)
                              ; generated by RepRapFirmware Configuration Tool v3.2.0 on Fri Jan 01 2021 12:00:51 GMT-0500 (Eastern Standard Time)
                              M550 P"Duet 3" ; set printer name
                              M569 P0.1 S1 ; physical drive 0.1 goes forwards
                              M569 P0.2 S0 ; physical drive 0.2 goes backwards
                              M569 P0.4 S1 ; physical drive 0.4 goes forwards
                              M569 P0.5 S1 ; physical drive 0.5 goes forwards
                              M569 P1.0 S1 ; physical drive 1.0 goes forwards
                              M569 P1.1 S1 ; physical drive 1.1 goes forwards
                              M584 X0.0 Y0.1 Z0.2 E0.4:0.5:1.0:1.1 ; set drive mapping
                              M350 X16 Y16 Z16 E16:16:16:16 I1 ; configure microstepping with interpolation
                              M92 X100.00 Y100.00 Z400.00 E100.00:100.00:100.00:100.00 ; set steps per mm
                              M566 X600.00 Y600.00 Z18.00 E300.00:300.00:300.00:300.00 ; set maximum instantaneous speed changes (mm/min)
                              M203 X6000.00 Y6000.00 Z180.00 E6000.00:6000.00:6000.00:6000.00 ; set maximum speeds (mm/min)
                              M201 X1500.00 Y1500.00 Z100.00 E10000.00:10000.00:10000.00:10000.00 ; set accelerations (mm/s^2)
                              M906 X500 Y500 Z500 E800:800:800:800 I30 ; set motor currents (mA) and motor idle factor in per cent
                              M84 S30 ; Set idle timeout
                              M208 X-50 Y-10 Z0 S1 ; set axis minima
                              M208 X300 Y300 Z350 S0 ; set axis maxima
                              M574 Z1 S3 ; configure sensorless endstop for low end on Z
                              M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
                              M557 X20:200 Y20:200 S40 ; define mesh grid
                              M308 S0 P"temp0" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 0 as thermistor on pin temp0
                              M143 H0 S100 ; set temperature limit for heater 0 to 100C
                              M308 S1 P"1.temp0" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin 1.temp0
                              M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
                              M143 H1 S300 ; set temperature limit for heater 1 to 300C
                              M308 S2 P"1.temp1" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 2 as thermistor on pin 1.temp1
                              M950 H2 C"out2" T2 ; create nozzle heater output on out2 and map it to sensor 2
                              M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
                              M143 H2 S300 ; set temperature limit for heater 2 to 300C
                              M950 F0 C"1.out3" Q500 ; create fan 0 on pin 1.out3 and set its frequency
                              M106 P0 S1 H1:2 T45 ; set fan 0 value. Thermostatic control is turned on
                              M950 F1 C"1.out4" Q500 ; create fan 1 on pin 1.out4 and set its frequency
                              M106 P1 S1 H1:2 T45 ; set fan 1 value. Thermostatic control is turned on
                              T0 ; select first tool
                              • bamundefined
                                bam @dc42
                                @dc42 changed the can address switches on 3hc to 1, same as the config.g file. now we have a slow flash on the mb and a fast flash on the eb
                                • bamundefined
                                  bam @bam
                                  @bam fast flash is no connection to mb
                                    That should be OK if it is short and wired with the middle 2 pins straight through; however it may be wired crossed.
                                    Thar suggests a problem with the CAN wiring.
                                    bamundefined 3 Replies Last reply Reply Quote 0
                                    • bamundefined
                                      bam
                                      • bamundefined
                                        bam @dc42
                                        @dc42 i just took a look and the wires are not crossed
                                        • bamundefined
                                          bam
                                          m122
                                          Used output buffers: 1 of 40 (14 max)
                                          Static ram: 154604
                                          Dynamic ram: 162320 of which 100 recycled
                                          Exception stack ram used: 272
                                          Never used ram: 75920
                                          Tasks: NETWORK(ready,1968) HEAT(blocked,476) CanReceiv(suspended,3820) CanSender(suspended,1488) CanClock(blocked,1436) TMC(blocked,192) MAIN(running,5056) IDLE(ready,76)
                                          Owned mutexes:
                                          Last reset 00:06:53 ago, cause: software
                                          Error status: 0
                                          MCU temperature: min 43.7, current 44.6, max 44.8
                                          12V rail voltage: min 12.2, current 12.2, max 12.3, under voltage events: 0
                                          Driver 0: standstill, reads 6854, writes 14 timeouts 0, SG min/max 0/0
                                          Driver 1: standstill, reads 6855, writes 14 timeouts 0, SG min/max 0/0
                                          Driver 2: standstill, reads 6855, writes 14 timeouts 0, SG min/max 0/0
                                          Driver 3: standstill, reads 6858, writes 11 timeouts 0, SG min/max 0/0
                                          Driver 4: standstill, reads 6856, writes 14 timeouts 0, SG min/max 0/0
                                          Driver 5: standstill, reads 6856, writes 14 timeouts 0, SG min/max 0/0
                                          Date/time: 2021-01-01 23:45:44
                                          Slowest loop: 2102.42ms; fastest: 0.14ms
                                          === Storage ===
                                          === MainDDARing ===
                                          === AuxDDARing ===
                                          Segments left: 0
                                          === Network ===
                                          Slowest loop: 0.81ms; fastest: 0.01ms
                                          • Ethernet -
                                            State: disabled
                                            === CAN ===
                                            Messages sent 1636, longest wait 0ms for type 0
                                            State: 0, failed transfers: 7
                                            RX/TX seq numbers: 46099/13071
                                            SPI underruns 7, overruns 7
                                            Buffer RX/TX: 0/0-0
                                            Full transfers per second: 1.17
                                            1/1/2021, 11:45:04 PM m115
                                          • bamundefined
                                            bam @dc42
                                            @dc42 what does this mean?
                                            M32 "0:/gcodes/Duet3Firmware_EXP3HC.bin"
                                            Error: Unterminated string in line 3
                                            Vetiundefined 1 Reply Last reply Reply Quote 0
