    cannot get 3hc to connect.
    Firmware installation
    1.7k
    • bamundefined
      bam @dc42
      @dc42 4 flashes then it stops then 4 flashes. It’s asking for firmware update. I think.
        The error codes indicated by flashes are lisated at https://duet3d.dozuki.com/Wiki/CAN_connection#Section_LED_behaviour_and_error_codes. Normally you would see alternating 2 or 3 flashes (indicating no valid firmware installed followed by 4 flashes. Anyway, 4 flashes indicates that the main board didn't respond. This normally means that either the main board is not running, or the CAN connection is broken or mis-wired.
        bamundefined 2 Replies Last reply Reply Quote 0
        • bamundefined
          bam @dc42
          @dc42 That’s probably the issue then because I am just using standard issue phone cord
          • bamundefined
            bam @Veti
            @Veti ; Configuration file for Duet 3 (firmware version 3)
            ; generated by RepRapFirmware Configuration Tool v3.2.0 on Fri Jan 01 2021 12:00:51 GMT-0500 (Eastern Standard Time)
            M550 P"Duet 3" ; set printer name
            M569 P0.2 S0 ; physical drive 0.2 goes backwards
            M569 P0.4 S1 ; physical drive 0.4 goes forwards
            M569 P0.5 S1 ; physical drive 0.5 goes forwards
            M569 P1.0 S1 ; physical drive 1.0 goes forwards
            M569 P1.1 S1 ; physical drive 1.1 goes forwards
            M584 X0.0 Y0.1 Z0.2 E0.4:0.5:1.0:1.1 ; set drive mapping
            M350 X16 Y16 Z16 E16:16:16:16 I1 ; configure microstepping with interpolation
            M92 X100.00 Y100.00 Z400.00 E100.00:100.00:100.00:100.00 ; set steps per mm
            M566 X600.00 Y600.00 Z18.00 E300.00:300.00:300.00:300.00 ; set maximum instantaneous speed changes (mm/min)
            M203 X6000.00 Y6000.00 Z180.00 E6000.00:6000.00:6000.00:6000.00 ; set maximum speeds (mm/min)
            M201 X1500.00 Y1500.00 Z100.00 E10000.00:10000.00:10000.00:10000.00 ; set accelerations (mm/s^2)
            M906 X500 Y500 Z500 E800:800:800:800 I30 ; set motor currents (mA) and motor idle factor in per cent
            M84 S30 ; Set idle timeout
            M208 X-50 Y-10 Z0 S1 ; set axis minima
            M208 X300 Y300 Z350 S0 ; set axis maxima
            M574 Z1 S3 ; configure sensorless endstop for low end on Z
            M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
            M557 X20:200 Y20:200 S40 ; define mesh grid
            M308 S0 P"temp0" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 0 as thermistor on pin temp0
            M143 H0 S100 ; set temperature limit for heater 0 to 100C
            M308 S1 P"1.temp0" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin 1.temp0
            M143 H1 S300 ; set temperature limit for heater 1 to 300C
            M308 S2 P"1.temp1" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 2 as thermistor on pin 1.temp1
            M950 H2 C"out2" T2 ; create nozzle heater output on out2 and map it to sensor 2
            M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
            M143 H2 S300 ; set temperature limit for heater 2 to 300C
            M950 F0 C"1.out3" Q500 ; create fan 0 on pin 1.out3 and set its frequency
            M106 P0 S1 H1:2 T45 ; set fan 0 value. Thermostatic control is turned on
            M950 F1 C"1.out4" Q500 ; create fan 1 on pin 1.out4 and set its frequency
            M106 P1 S1 H1:2 T45 ; set fan 1 value. Thermostatic control is turned on
            T0 ; select first tool
            • bamundefined
              bam @dc42
              @dc42 changed the can address switches on 3hc to 1, same as the config.g file. now we have a slow flash on the mb and a fast flash on the eb
              bamundefined 1 Reply Last reply Reply Quote 0
              • bamundefined
                bam @bam
                @bam fast flash is no connection to mb
                  dc42 administrators @bam
                  @bam said in cannot get 3hc to connect.:
                  That should be OK if it is short and wired with the middle 2 pins straight through; however it may be wired crossed.
                  Thar suggests a problem with the CAN wiring.
                  bamundefined 3 Replies Last reply Reply Quote 0
                  • bamundefined
                    bam
                    • bamundefined
                      bam @dc42
                      @dc42 i just took a look and the wires are not crossed
                      • bamundefined
                        bam
                        m122
                        RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v1.01 or later (SBC mode)
                        Board ID: 08DJM-956BA-NA3TJ-6JTD2-3SN6K-9BAQU
                        Used output buffers: 1 of 40 (14 max)
                        Static ram: 154604
                        Dynamic ram: 162320 of which 100 recycled
                        Exception stack ram used: 272
                        Never used ram: 75920
                        Tasks: NETWORK(ready,1968) HEAT(blocked,476) CanReceiv(suspended,3820) CanSender(suspended,1488) CanClock(blocked,1436) TMC(blocked,192) MAIN(running,5056) IDLE(ready,76)
                        Owned mutexes:
                        Last reset 00:06:53 ago, cause: software
                        Last software reset details not available
                        Error status: 0
                        MCU temperature: min 43.7, current 44.6, max 44.8
                        Supply voltage: min 24.0, current 24.1, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
                        12V rail voltage: min 12.2, current 12.2, max 12.3, under voltage events: 0
                        Driver 0: standstill, reads 6854, writes 14 timeouts 0, SG min/max 0/0
                        Driver 1: standstill, reads 6855, writes 14 timeouts 0, SG min/max 0/0
                        Driver 2: standstill, reads 6855, writes 14 timeouts 0, SG min/max 0/0
                        Driver 3: standstill, reads 6858, writes 11 timeouts 0, SG min/max 0/0
                        Driver 4: standstill, reads 6856, writes 14 timeouts 0, SG min/max 0/0
                        Driver 5: standstill, reads 6856, writes 14 timeouts 0, SG min/max 0/0
                        Date/time: 2021-01-01 23:45:44
                        Slowest loop: 2102.42ms; fastest: 0.14ms
                        === Storage ===
                        Free file entries: 10
                        === MainDDARing ===
                        Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
                        === AuxDDARing ===
                        Segments left: 0
                        Movement lock held by null
                        HTTP* is ready with "M122" in state(s) 0
                        Telnet is idle in state(s) 0
                        File is idle in state(s) 0
                        USB is idle in state(s) 0
                        Aux is idle in state(s) 0
                        Queue is idle in state(s) 0
                        LCD is idle in state(s) 0
                        SBC is idle in state(s) 0
                        Daemon* is idle in state(s) 0
                        Aux2 is idle in state(s) 0
                        Code queue is empty.
                        === Network ===
                        Slowest loop: 0.81ms; fastest: 0.01ms
                        HTTP sessions: 0 of 8
                        • Ethernet -
                          State: disabled
                          Error counts: 0 0 0 0 0
                          === CAN ===
                          Messages sent 1636, longest wait 0ms for type 0
                          === Linux interface ===
                          State: 0, failed transfers: 7
                          Last transfer: 17ms ago
                          RX/TX seq numbers: 46099/13071
                          SPI underruns 7, overruns 7
                          Number of disconnects: 0
                          Buffer RX/TX: 0/0-0
                          === Duet Control Server ===
                          Duet Control Server v3.1.1
                          Code buffer space: 4096
                          Full transfers per second: 1.17
                          1/1/2021, 11:45:04 PM m115
                          FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.1.1 ELECTRONICS: Duet 3 MB6HC v1.01 or later FIRMWARE_DATE: 2020-05-19b2
                        • bamundefined
                          bam @dc42
                          @dc42 what does this mean?
                          M32 "0:/gcodes/Duet3Firmware_EXP3HC.bin"
                          Error: Unterminated string in line 3
                          • bamundefined
                            bam @dc42
                            @dc42 and now this
                            Warning: Incompatible firmware, please upgrade as soon as possible
                            • Vetiundefined
                              Veti @bam
                              M32 is start a print.
                              you want to print a firmware binary file?
                              and why is that file in the gcodes folder?
                              bamundefined 2 Replies Last reply Reply Quote 1
                              • bamundefined
                                bam @Veti
                                @Veti I Got It!!! 🙂 Finally!!
                                m122 b1
                                Diagnostics for board 1:
                                Duet EXP3HC firmware version 3.2-RC2 (2020-12-24)
                                Bootloader ID: not available
                                Never used RAM 154536, free system stack 200 words
                                HEAT 75 CanAsync 94 CanRecv 87 TMC 64 MAIN 173 AIN 257
                                Last reset 00:00:35 ago, cause: software
                                Last software reset data not available
                                Driver 0: position 0, 100.0 steps/mm, standstill, reads 63861, writes 16 timeouts 0, SG min/max 0/0
                                Driver 1: position 0, 100.0 steps/mm, standstill, reads 63863, writes 16 timeouts 0, SG min/max 0/0
                                Driver 2: position 0, 80.0 steps/mm, standstill, reads 63871, writes 11 timeouts 0, SG min/max 0/0
                                Moves scheduled 0, completed 0, in progress 0, hiccups 0
                                No step interrupt scheduled
                                VIN: 24.1V, V12: 12.2V
                                MCU temperature: min 45.9C, current 46.1C, max 46.1C
                                Ticks since heat task active 73, ADC conversions started 35564, completed 35564, timed out 0
                                Last sensors broadcast 0x00000006 found 2 76 ticks ago, loop time 0
                                CAN messages queued 243, send timeouts 0, received 252, lost 0, free buffers 36
                                1/2/2021, 1:13:10 AM m122
                                RepRapFirmware for Duet 3 MB6HC version 3.2-RC2 running on Duet 3 MB6HC v1.01 or later (SBC mode)
                                Used output buffers: 1 of 40 (13 max)
                                Static ram: 149788
                                Dynamic ram: 62676 of which 136 recycled
                                Never used RAM 146232, free system stack 200 words
                                Tasks: Linux(ready,119) HEAT(blocked,188) CanReceiv(blocked,836) CanSender(blocked,371) CanClock(blocked,360) TMC(blocked,53) MAIN(running,1217) IDLE(ready,19)
                                Owned mutexes: HTTP(MAIN)
                                Last reset 00:00:15 ago, cause: software
                                Last software reset time unknown, reason: StuckInSpinLoop, GCodes spinning, available RAM 147880, slot 1
                                Software reset code 0x0083 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0040080f BFAR 0x00000000 SP 0x204334e4 Task Linu Freestk 443 ok
                                Stack: 00429a2d 00429ab0 61000000 a5a5a5a5 a5a5a5a5 a5a5a5a5 00000000 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5
                                Error status: 0x00
                                Aux0 errors 0,0,0
                                Aux1 errors 0,0,0
                                MCU temperature: min 43.8, current 46.0, max 46.1
                                Driver 0: position 0, standstill, reads 23487, writes 14 timeouts 0, SG min/max 0/0
                                Driver 1: position 0, standstill, reads 23487, writes 14 timeouts 0, SG min/max 0/0
                                Driver 2: position 0, standstill, reads 23487, writes 14 timeouts 0, SG min/max 0/0
                                Driver 3: position 0, standstill, reads 23491, writes 11 timeouts 0, SG min/max 0/0
                                Driver 4: position 0, standstill, reads 23488, writes 14 timeouts 0, SG min/max 0/0
                                Driver 5: position 0, standstill, reads 23488, writes 14 timeouts 0, SG min/max 0/0
                                Date/time: 2021-01-02 01:13:08
                                Slowest loop: 0.45ms; fastest: 0.05ms
                                === Storage ===
                                DMs created 125, maxWait 0ms, bed compensation in use: none, comp offset 0.000
                                === MainDDARing ===
                                === AuxDDARing ===
                                Segments left: 0
                                Daemon is idle in state(s) 0
                                === CAN ===
                                Messages queued 55, send timeouts 0, received 95, lost 0, longest wait 1ms for reply type 6018, free buffers 48
                                === SBC interface ===
                                State: 4, failed transfers: 0
                                Last transfer: 2ms ago
                                RX/TX seq numbers: 442/442
                                SPI underruns 0, overruns 0
                                Number of disconnects: 0, IAP RAM available 0x2c8a8
                                Buffer RX/TX: 0/0-0
                                Duet Control Server v3.2.0-rc2
                                Full transfers per second: 35.67
                                Maximum length of RX/TX data transfers: 5196/900
                                • bamundefined
                                  bam @Veti
                                  @Veti i dont know why the file is in there, not sure how to delete either. mightve shown up with the .bin i downloaded.
                                  this whole time ive just been trying to get the boards online and the software updated. I can config the printer later.
                                  twisted pair wasnt actually twisted. just looked twisted.
                                    Phaedrux Moderator @bam
                                    Either right click and delete, or if that won't work, you can try and do it from the SBC side. The first SD card (0:/) is emulated by DCS and its default directory is /opt/dsf/sd
                                    • bamundefined
                                      bam @Phaedrux
                                      @Phaedrux 2021-01-02-012341_1024x768_scrot.png yeah theres nothing here so idk
                                      • Vetiundefined
                                        Veti
                                        you are editing a file called gcodes.g
                                        nothing phaedrux said mentioned any of that.
                                        • bamundefined
                                          bam
                                          thanks for all the helps @dc42 @Veti @Phaedrux @bearer i promise you i will be back. have to make a hardware store run to find an (actual) twisted pair, not this spliced mess, and then start wiring motors and sensors.80B0B486-E3DE-4305-8A35-91BD1102EE6B.jpeg
                                          • bamundefined
                                            bam @Veti
                                            @Veti
                                            i did it from the duet3webcontrol.
                                            sorry if i dont know anything about these and i jumped in feet first.
