    Status problem
    Duet Web Control
    • chivelundefined
      chivel
      Dear friends
      I have a problem with head position in Delta printer. At HOME 2 coordinates X and Y =0, but Z =999? I use RepRap 2.03 firmware. May be mistake in firmware? My config and homedelta are applied:
      24d31ae9-e77a-49d0-af20-94004b3bb852-image.png CONFIG.g
      Configuration file for Duet WiFi (firmware version 1.21)
      ; generated by RepRapFirmware Configuration Tool v3.1.9 on Thu Dec 03 2020 14:00:14 GMT+0300 (Москва, стандартное время)
      M550 P"My Printer" ; set printer name
      M665 R630 L960 B350 H1000 ; Set delta radius, diagonal rod length, printable radius and homed height
      M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M92 X350.00 Y350.00 Z350.00 E663.00 ; set steps per mm
      M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
      M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
      M906 X1000 Y1000 Z1000 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 Z0 S1 ; set minimum Z
      M574 X2 Y2 Z2 S1 ; set active high endstops
      M558 P4 H5 F120 T6000 ; set Z probe type to switch and the dive height + speeds
      G31 P50 X0 Y0 Z3.5 ; set Z probe trigger value, offset and trigger height
      M557 R85 S20 ; define mesh grid
      M305 P0 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 0
      M305 P1 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 1
      M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      Config.g.bak
      G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
      HOMEDELTA.G
      ; homedelta.g
      G91 ; relative positioning
      G1 S1 X1105 Y1105 Z1105 F600 ; move all towers to the high end stopping at the endstops (first pass)
      G1 S2 X-5 Y-5 Z-5 F600 ; go down a few mm
      G1 S1 X10 Y10 Z10 F360 ; move all towers up once more (second pass)
      G1 Z-5 F6000 ; move down a few mm so that the nozzle can be centred
      G90 ; absolute positioning
      G1 X0 Y0 F6000 ; move X+Y to the centre
        Can you test your endstops with M119?
        Has anything changed recently?
