    Unsolved DotStar behavior changed with 3.2
    Beta Firmware
    • JT
      JT last edited by
      Hi all,
      just updated my machine to 3.2, running on a Duet 3 MB6HC.
      With the last release i turned on my LEDs via the short following command:
      M150 X0
      M150 R255 U255 B255 S120 F0 Y31
      With 3.2 this won´t work anymore. By try and error i found out that when i change the command to X1 i can turn on the LEDs again.
      But to turn them off i have to stay with X0. So something strange happens here. Anyone faced the same behavior?
      • Luke'sLaboratory
        Luke'sLaboratory last edited by
        Hi there!
        Per the release notes, the default behavior for LED's is to expect that they are Neopixel, not Dotstar.
        https://github.com/Duet3D/RepRapFirmware/blob/v3-dev/WHATS_NEW_RRF3.md
        Luke
        http://lukeslab.online
          dc42 administrators @JT last edited by
          @JT I have added this to my list to test/investigate. The Neopixel/DotStar driver was changed in 3.2 and unfortunately I did not have a working DotStar strip to test with.
            dc42 administrators @dc42 last edited by
            I confirm that the DotStar driver was not working. I have now fixed it. The fix will be in the 3.3beta3 release. A preview 3.2beta2+ build including the fix is available at https://www.dropbox.com/sh/dupd9u1xppr1om5/AADYg4guuj2n8LJokVqtK-C7a?dl=0.
