    DWC (3.2) not showing object height (might be DSF related)
    Duet Web Control
    326
    • garyd9undefined
      garyd9
      Every now and then, I come across .gcode files where the object height isn't shown in DWC. Sometimes this is because of a change in my slicer (cura 4.8 now), but I've changed so many things for my printer in the past few days that I don't know what to point at.
      This is being uploaded to DSF 3.2 (RRF 3.2) with DWC 3.2. The layer height, filament usage and slicer estimated print time are all showing up, but the "object height" isn't (which also prevents "layer" based time estimations when printing.)
      Other files sliced with the same slicer and similar settings work fine. I'll attach a .zip file (renamed to add a "gcode" extension to make the board code happy) containing two gcode files. Both are sliced with Cura 4.8 and they are using similar settings. (At the very least, the startup and ending scripts are identical.)
      One shows a layer height in DWC, and one doesn't.
      I'm unable to test this with RRF 3.2 (standalone.)
      When opening this attachment, please remember that it's really a .zip file containing gcode files (and not a gcode file.) Just rename it to drop ".gcode" from the filename. 🙂
      LayerHeights.zip.gcode
      "I'm not saying that you are wrong - I'm just trying to fit it into my real world simulated experience."
        One thing I note is the file size. 7mb vs 16mb. I think there may be a file size limit beyond which it doesn't try to scan the whole file for certain details. But @chrishamm would have to clarify.
        garyd9undefined 1 Reply Last reply Reply Quote 0
        • garyd9undefined
          garyd9 @Phaedrux
          The irony is that cura (and likely other slicers) leave comments in the gcode file with the max Z height printed.
          RRF (and DSF) scan the gcode files for comments like this for other variables already. For example, slicer estimated print time, layer height, etc.
          ;MAXZ:4
          • garyd9undefined
            garyd9
            Here's a smaller 7MB gcode file that also doesn't show a layer height in DWC (via DSF.) It's using the same slicer settings.
            As with the previous upload, the file is actually a .zip file, but the extension changed to make the forum software happy. Download, change the extension to .zip, and the gcode is within.
            smaller bow maker v3.zip.gcode
              I'll take a closer look a bit later.
              • garyd9undefined
                garyd9
                Odd. After I started printing the smaller (7MB) file, the job height has shown up in DWC. The larger (16mb) file was printed, but the job height never showed up.
                Maybe I'm just losing my mind.
                  Well that scan isn't instant, so maybe it hadn't done it yet on the smaller file yet. I'm not exactly sure of the inner workings there.
                  • chrishammundefined
                    chrishamm administrators
                    The last G0/G1 ... Z code is too far from the end of the G-code file (-418284 chars). DSF scans only the last 256KiB (~262144 chars) and RRF scans even less. But you can increase this limit in /opt/dsf/conf/config.json via key FileInfoReadLimitFooter. If you double that value, it will scan the last 512KiB which would suffice for your particular file. Note that file info parsing may take longer though.
                    Duet software engineer
