Solved 3.2 Servo making a grinding noise on reboot/M999
@vasparshin Hi. So you literally connected ground and the exp.e3stop with a 5k resistor? (ie. between ground and the exp.e3stop pin)? Mind sending a photo?
Tinus
Yes that is correct. 5K resistor between ground and the exp.e3stop and taking the signal from exp.e3stop to Arduino. My wiring is a complete mess so I've provided a diagram instead.
Brilliant thanx, got it like that. Working like a dream.
