    Web request vuejs
    Duet Web Control
    • Matthieuundefined
      Matthieu
      Hello everyone,
      I created a web interface and need to be able to send request to Duet with it.
      I use vuejs with axios, but whenever I try to send request, it fail (no response code).
      Is there some CORS requirement ? A problem with Axios ?
      P.S. : not sure about the category
      JBiscundefined 1 Reply Last reply Reply Quote 0
      • JBiscundefined
        JBisc @Matthieu
        @Matthieu Hey Matthieu,
        I am doing something similar, I am running NodeJs frontend on the RPI and then I use the PythonApi from @wilriker https://github.com/Duet3D/DSF-APIs
        in a FLASK based (Python) backend to communicate with the Duet.
        Would this be a way that would work for you?
        My Setup: Duet 3 MB6HC Main Board with attached RPI
        • chrishammundefined
          chrishamm administrators
          Starting from software version 3.2 you must add M586 C"*" or similar to your config.g if you are using a local dev setup and want to connect to the Duet from there. Btw good luck with Axios, I replaced that dependency in DWC2 a while back because it had too many glitches.
          Duet software engineer
