UNSOLVED 3.2 DSF: "File: Out-of-order reply"
Using 3.2 on 6HC+3HC+SBC. Started print and it stuck on my homing macro. I include a long debug so nothing is missed.
His usually works without problems.[debug] Waiting for execution of M32 "0:/gcodes/Front Stepper v5.2 - Bottom.gcode" [debug] Processing M32 "0:/gcodes/Front Stepper v5.2 - Bottom.gcode" [info] Selected file /opt/dsf/sd/gcodes/Front Stepper v5.2 - Bottom.gcode [debug] Waiting for finish of M32 "0:/gcodes/Front Stepper v5.2 - Bottom.gcode" => File 0:/gcodes/Front Stepper v5.2 - Bottom.gcode selected for printing [info] Starting file print [debug] Waiting for execution of G10 P0 R200 S200 ; sets the standby temperature [debug] Processing G10 P0 R200 S200 ; sets the standby temperature [debug] Waiting for finish of G10 P0 R200 S200 ; sets the standby temperature [debug] Waiting for execution of ; generated by SuperSlicer 2.3.55 on 2021-01-16 at 23:00:27 UTC [debug] Processing ; generated by SuperSlicer 2.3.55 on 2021-01-16 at 23:00:27 UTC [debug] Waiting for finish of ; generated by SuperSlicer 2.3.55 on 2021-01-16 at 23:00:27 UTC [debug] Waiting for execution of ; [debug] Processing ; [debug] Waiting for finish of ; [debug] Waiting for execution of ; external perimeters extrusion width = 0.40mm [debug] Processing ; external perimeters extrusion width = 0.40mm [debug] Waiting for finish of ; external perimeters extrusion width = 0.40mm [debug] Waiting for execution of ; perimeters extrusion width = 0.50mm [debug] Processing ; perimeters extrusion width = 0.50mm [debug] Waiting for finish of ; perimeters extrusion width = 0.50mm [debug] Waiting for execution of ; infill extrusion width = 0.50mm [debug] Processing ; infill extrusion width = 0.50mm [debug] Waiting for finish of ; infill extrusion width = 0.50mm [debug] Waiting for execution of ; solid infill extrusion width = 0.50mm [debug] Processing ; solid infill extrusion width = 0.50mm [debug] Waiting for finish of ; solid infill extrusion width = 0.50mm [debug] Waiting for execution of ; top infill extrusion width = 0.40mm [debug] Processing ; top infill extrusion width = 0.40mm [debug] Waiting for finish of ; top infill extrusion width = 0.40mm [debug] Waiting for execution of ; first layer extrusion width = 0.42mm [debug] Processing ; first layer extrusion width = 0.42mm [debug] Waiting for finish of ; first layer extrusion width = 0.42mm [debug] Waiting for execution of ; object:{"name":"Front Stepper v5","id":"Front Stepper v5.2 - Bottom.stl id:0 copy 0","object_center":[250.000000,250.000000,0.000000],"boundingbox_center":[250.000000,250.000000,26.315001],"boundingbox_size":[82.299988,106.585815,52.630001]} [debug] Processing ; object:{"name":"Front Stepper v5","id":"Front Stepper v5.2 - Bottom.stl id:0 copy 0","object_center":[250.000000,250.000000,0.000000],"boundingbox_center":[250.000000,250.000000,26.315001],"boundingbox_size":[82.299988,106.585815,52.630001]} [debug] Waiting for execution of ; plater:{"center":[250.000000,250.000000,0.000000],"boundingbox_center":[250.000000,250.000000,26.315001],"boundingbox_size":[82.299988,106.585815,52.630001]} [debug] Waiting for execution of ;TYPE:Custom [debug] Waiting for execution of ; custom gcode: start_gcode [debug] Waiting for execution of G10 P0 R0 S0 ; Don't heat the tools yet [debug] Waiting for execution of G10 P1 R0 S0 ; Don't heat the tools yet [debug] Waiting for finish of ; object:{"name":"Front Stepper v5","id":"Front Stepper v5.2 - Bottom.stl id:0 copy 0","object_center":[250.000000,250.000000,0.000000],"boundingbox_center":[250.000000,250.000000,26.315001],"boundingbox_size":[82.299988,106.585815,52.630001]} [debug] Processing ; plater:{"center":[250.000000,250.000000,0.000000],"boundingbox_center":[250.000000,250.000000,26.315001],"boundingbox_size":[82.299988,106.585815,52.630001]} [debug] Waiting for finish of ; plater:{"center":[250.000000,250.000000,0.000000],"boundingbox_center":[250.000000,250.000000,26.315001],"boundingbox_size":[82.299988,106.585815,52.630001]} [debug] Waiting for execution of G10 P2 R0 S0 ; Don't heat the tools yet [debug] Processing ;TYPE:Custom [debug] Waiting for execution of M140 S60 ; Heat the bed first [debug] Waiting for finish of ;TYPE:Custom [debug] Processing ; custom gcode: start_gcode [debug] File: Sent G10 P0 R200 S200 ; sets the standby temperature, remaining space 1488, needed 48 [debug] Waiting for finish of ; custom gcode: start_gcode [debug] File: Sent ; first layer extrusion width = 0.42mm, remaining space 1420, needed 68 [debug] Processing G10 P0 R0 S0 ; Don't heat the tools yet [debug] Waiting for finish of G10 P0 R0 S0 ; Don't heat the tools yet [debug] Processing G10 P1 R0 S0 ; Don't heat the tools yet [debug] Waiting for finish of G10 P1 R0 S0 ; Don't heat the tools yet [debug] Processing G10 P2 R0 S0 ; Don't heat the tools yet [debug] Waiting for execution of M116 H0 S2 ; Wait for the bed to reach its temperature +-2 degC. [debug] Waiting for finish of G10 P2 R0 S0 ; Don't heat the tools yet [debug] Waiting for execution of G10 P0 R175 S220 ; Set temperature for the first tool used. [debug] Processing M140 S60 ; Heat the bed first [debug] Waiting for finish of M140 S60 ; Heat the bed first [debug] Processing M116 H0 S2 ; Wait for the bed to reach its temperature +-2 degC. [debug] Waiting for finish of M116 H0 S2 ; Wait for the bed to reach its temperature +-2 degC. [debug] Waiting for execution of M98 P"/sys/custom/Conditional_HomeAll.g" ; Only home if not already homed. [debug] Processing G10 P0 R175 S220 ; Set temperature for the first tool used. [debug] Waiting for finish of G10 P0 R175 S220 ; Set temperature for the first tool used. [debug] Processing M98 P"/sys/custom/Conditional_HomeAll.g" ; Only home if not already homed. [debug] Waiting for finish of M98 P"/sys/custom/Conditional_HomeAll.g" ; Only home if not already homed. [debug] Waiting for execution of G0 Z5 F5000 ; Ensure nozzle is at 5mm over the bed [debug] Processing G0 Z5 F5000 ; Ensure nozzle is at 5mm over the bed [debug] Waiting for finish of G0 Z5 F5000 ; Ensure nozzle is at 5mm over the bed [debug] Waiting for execution of T0 ; Mount extruder first used (even if only one extruder used). Waits for temperature inside the script. [debug] Processing T0 ; Mount extruder first used (even if only one extruder used). Waits for temperature inside the script. [debug] Waiting for finish of T0 ; Mount extruder first used (even if only one extruder used). Waits for temperature inside the script. [debug] Waiting for execution of ; custom gcode end: start_gcode [debug] Processing ; custom gcode end: start_gcode [debug] Waiting for finish of ; custom gcode end: start_gcode [debug] Waiting for execution of G21 ; set units to millimeters [debug] Processing G21 ; set units to millimeters [debug] Waiting for finish of G21 ; set units to millimeters [debug] Waiting for execution of G90 ; use absolute coordinates [debug] Processing G90 ; use absolute coordinates [debug] Waiting for finish of G90 ; use absolute coordinates [debug] Waiting for execution of M83 ; use relative distances for extrusion [debug] Processing M83 ; use relative distances for extrusion [debug] Waiting for finish of M83 ; use relative distances for extrusion [debug] Waiting for execution of ; custom gcode: start_filament_gcode [debug] Processing ; custom gcode: start_filament_gcode [debug] Waiting for finish of ; custom gcode: start_filament_gcode [debug] Waiting for execution of ; Filament gcode [debug] Waiting for execution of ; custom gcode end: start_filament_gcode [debug] Processing ; Filament gcode [debug] Waiting for finish of ; Filament gcode [debug] Waiting for execution of ;LAYER_CHANGE [debug] Processing ; custom gcode end: start_filament_gcode [debug] Waiting for execution of ;Z:0.3 [debug] Waiting for finish of ; custom gcode end: start_filament_gcode [debug] Waiting for execution of ;HEIGHT:0.3 [debug] Processing ;LAYER_CHANGE [debug] Waiting for finish of ;LAYER_CHANGE [debug] Processing ;Z:0.3 [debug] Waiting for finish of ;Z:0.3 [debug] Processing ;HEIGHT:0.3 [debug] Waiting for finish of ;HEIGHT:0.3 [debug] File: Suspending code G10 P0 R200 S200 ; sets the standby temperature [debug] File: Suspending code ; first layer extrusion width = 0.42mm [debug] Macro file start.g not found [debug] File: Disposing macro file start.g [debug] File: Sent G10 P0 R200 S200 ; sets the standby temperature, remaining space 1488, needed 48 [debug] File: -> Resumed suspended code [debug] File: Sent ; first layer extrusion width = 0.42mm, remaining space 1420, needed 68 [debug] File: -> Resumed suspended code [debug] File: Sent G10 P0 R0 S0 ; Don't heat the tools yet, remaining space 1372, needed 48 [debug] File: Sent G10 P1 R0 S0 ; Don't heat the tools yet, remaining space 1324, needed 48 [debug] File: Sent G10 P2 R0 S0 ; Don't heat the tools yet, remaining space 1276, needed 48 [debug] File: Sent M140 S60 ; Heat the bed first, remaining space 1244, needed 32 [debug] File: Sent M116 H0 S2 ; Wait for the bed to reach its temperature +-2 degC., remaining space 1204, needed 40 [debug] File: Sent G10 P0 R175 S220 ; Set temperature for the first tool used., remaining space 1156, needed 48 [debug] File: Sent M98 P"/sys/custom/Conditional_HomeAll.g" ; Only home if not already homed., remaining space 1088, needed 68 [debug] File: Sent G0 Z5 F5000 ; Ensure nozzle is at 5mm over the bed, remaining space 1048, needed 40 [debug] File: Sent T0 ; Mount extruder first used (even if only one extruder used). Waits for temperature inside the script., remaining space 1024, needed 24 [debug] File: Sent G21 ; set units to millimeters, remaining space 1000, needed 24 [debug] File: Sent G90 ; use absolute coordinates, remaining space 976, needed 24 [debug] File: Sent M83 ; use relative distances for extrusion, remaining space 952, needed 24 [debug] File: Sent ;LAYER_CHANGE, remaining space 908, needed 44 [debug] File: Sent ;HEIGHT:0.3, remaining space 864, needed 44 [debug] Completed M32 "0:/gcodes/Front Stepper v5.2 - Bottom.gcode" => File 0:/gcodes/Front Stepper v5.2 - Bottom.gcode selected for printing [debug] IPC#853: Connection closed [debug] G10 P0 R200 S200 [debug] Completed G10 P0 R200 S200 ; sets the standby temperature => [debug] Completed ; generated by SuperSlicer 2.3.55 on 2021-01-16 at 23:00:27 UTC [debug] Completed ; [debug] Completed ; external perimeters extrusion width = 0.40mm [debug] Completed ; perimeters extrusion width = 0.50mm [debug] Completed ; infill extrusion width = 0.50mm [debug] Completed ; solid infill extrusion width = 0.50mm [debug] Completed ; top infill extrusion width = 0.40mm [debug] G10 P0 R200 S200 [debug] Waiting for execution of G1 E-0.50000 F3000.00000 [debug] Completed ; first layer extrusion width = 0.42mm [debug] Processing G1 E-0.50000 F3000.00000 [debug] Completed ; plater:{"center":[250.000000,250.000000,0.000000],"boundingbox_center":[250.000000,250.000000,26.315001],"boundingbox_size":[82.299988,106.585815,52.630001]} [debug] Waiting for finish of G1 E-0.50000 F3000.00000 [debug] Completed ; custom gcode: start_gcode [debug] Completed G10 P0 R0 S0 ; Don't heat the tools yet => [debug] Completed ;TYPE:Custom [debug] Completed ; object:{"name":"Front Stepper v5","id":"Front Stepper v5.2 - Bottom.stl id:0 copy 0","object_center":[250.000000,250.000000,0.000000],"boundingbox_center":[250.000000,250.000000,26.315001],"boundingbox_size":[82.299988,106.585815,52.630001]} [debug] G10 P0 R0 S0 [debug] Waiting for execution of G1 Z0.350000 F18000.000 [debug] Processing G1 Z0.350000 F18000.000 [debug] Completed G10 P1 R0 S0 ; Don't heat the tools yet => [debug] Waiting for finish of G1 Z0.350000 F18000.000 [debug] G10 P1 R0 S0 [debug] Waiting for execution of G1 X209.977 Y198.059 [debug] Waiting for execution of G1 E0.50000 F1800.00000 [debug] Processing G1 X209.977 Y198.059 [debug] Completed G10 P2 R0 S0 ; Don't heat the tools yet => [debug] Waiting for finish of G1 X209.977 Y198.059 [debug] Processing G1 E0.50000 F1800.00000 [debug] Waiting for finish of G1 E0.50000 F1800.00000 [debug] Waiting for execution of ;TYPE:Skirt [debug] Waiting for execution of G1 X212.132 Y196.103 E0.12648 [debug] Waiting for execution of G1 X214.377 Y194.468 E0.12072 [debug] Waiting for execution of G1 X216.798 Y193.069 E0.12155 [debug] Waiting for execution of G1 X219.300 Y191.952 E0.11908 [debug] Waiting for execution of G1 X220.807 Y191.424 E0.06944 [debug] Waiting for execution of G1 X223.321 Y190.756 E0.11304 [debug] Processing ;TYPE:Skirt [debug] Waiting for execution of G1 X224.861 Y190.477 E0.06806 [debug] Waiting for execution of G1 X227.411 Y190.213 E0.11144 [debug] Waiting for execution of G1 X250.157 Y190.174 E0.98868 [debug] Waiting for execution of G1 X251.308 Y190.263 E0.05018 [debug] Waiting for execution of G1 X252.377 Y190.512 E0.04775 [debug] G10 P2 R0 S0 [debug] Completed M140 S60 ; Heat the bed first => [debug] Completed G10 P0 R175 S220 ; Set temperature for the first tool used. => [debug] Waiting for finish of ;TYPE:Skirt [debug] Completed M116 H0 S2 ; Wait for the bed to reach its temperature +-2 degC. => [debug] Processing G1 X212.132 Y196.103 E0.12648 [debug] Waiting for finish of G1 X212.132 Y196.103 E0.12648 [debug] Processing G1 X214.377 Y194.468 E0.12072 [debug] Waiting for finish of G1 X214.377 Y194.468 E0.12072 [debug] Processing G1 X216.798 Y193.069 E0.12155 [debug] Waiting for finish of G1 X216.798 Y193.069 E0.12155 [debug] Processing G1 X219.300 Y191.952 E0.11908 [debug] Waiting for finish of G1 X219.300 Y191.952 E0.11908 [debug] Processing G1 X220.807 Y191.424 E0.06944 [debug] Waiting for finish of G1 X220.807 Y191.424 E0.06944 [debug] Processing G1 X223.321 Y190.756 E0.11304 [debug] Waiting for finish of G1 X223.321 Y190.756 E0.11304 [debug] Processing G1 X224.861 Y190.477 E0.06806 [debug] Waiting for finish of G1 X224.861 Y190.477 E0.06806 [debug] Processing G1 X227.411 Y190.213 E0.11144 [debug] Waiting for finish of G1 X227.411 Y190.213 E0.11144 [debug] Processing G1 X250.157 Y190.174 E0.98868 [debug] Waiting for finish of G1 X250.157 Y190.174 E0.98868 [debug] Processing G1 X251.308 Y190.263 E0.05018 [debug] Waiting for finish of G1 X251.308 Y190.263 E0.05018 [debug] G10 P0 R175 S220 [debug] Waiting for execution of G1 X253.446 Y190.936 E0.04996 [debug] File: Suspending code T0 ; Mount extruder first used (even if only one extruder used). Waits for temperature inside the script. [debug] Waiting for execution of G1 X254.301 Y191.423 E0.04278 [debug] File: Suspending code G21 ; set units to millimeters [debug] File: Suspending code G90 ; use absolute coordinates [debug] Waiting for execution of G1 X255.163 Y192.084 E0.04721 [debug] File: Suspending code M83 ; use relative distances for extrusion [debug] File: Suspending code ;LAYER_CHANGE [debug] File: Suspending code ;HEIGHT:0.3 [info] Starting macro file /sys/custom/Conditional_HomeAll.g on channel File [debug] File: ==> Starting code G0 Z5 F5000 ; Ensure nozzle is at 5mm over the bed [debug] Completed M98 P"/sys/custom/Conditional_HomeAll.g" ; Only home if not already homed. => [debug] Processing G1 X252.377 Y190.512 E0.04775 [debug] Evaluating If block [debug] Waiting for finish of G1 X252.377 Y190.512 E0.04775 [debug] Waiting for execution of G1 X255.968 Y192.922 E0.05052 [debug] Evaluating 0 on channel File [debug] Processing G1 X253.446 Y190.936 E0.04996 [debug] Waiting for finish of G1 X253.446 Y190.936 E0.04996 [debug] Processing G1 X254.301 Y191.423 E0.04278 [debug] Waiting for finish of G1 X254.301 Y191.423 E0.04278 [debug] Processing G1 X255.163 Y192.084 E0.04721 [debug] Waiting for finish of G1 X255.163 Y192.084 E0.04721 [debug] Processing G1 X255.968 Y192.922 E0.05052 [debug] Waiting for finish of G1 X255.968 Y192.922 E0.05052 [debug] Requesting update of key job, seq 760 -> 762 [error] Failed to get macro response within 3000ms from SBC (channel File) [warn] File: Out-of-order reply: 'Macro file /sys/custom/Conditional_HomeAll.g not found ' [warn] File: Out-of-order reply: '' [info] Macro file /sys/custom/Conditional_HomeAll.g not found [warn] Macro file has been started on channel File but none was requested [debug] Evaluating 1 on channel File [debug] Updated key job [debug] Evaluating 2 on channel File [debug] Evaluating 3 on channel File [debug] Evaluating !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed || !move.axes[3].homed on channel File [debug] Evaluation result: (!move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed || !move.axes[3].homed) = False [debug] End of If block [debug] Finished codes from macro file /sys/custom/Conditional_HomeAll.g [info] Finished macro file /sys/custom/Conditional_HomeAll.g [warn] Cannot set macro file finished because there is no file ID [debug] IPC#854: Got new UNIX connection, checking permissions...
Diag:
=== Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.2 running on Duet 3 MB6HC v0.6 or 1.0 (SBC mode) Board ID: 08DJM-956L2-G43S4-6JKDD-3SJ6L-TB62G Used output buffers: 1 of 40 (16 max) === RTOS === Static ram: 149788 Dynamic ram: 65316 of which 152 recycled Never used RAM 143576, free system stack 128 words Tasks: Linux(ready,71) HEAT(blocked,271) CanReceiv(blocked,809) CanSender(blocked,341) CanClock(blocked,352) TMC(blocked,19) MAIN(running,720) IDLE(ready,19) Owned mutexes: HTTP(MAIN) === Platform === Last reset 06:39:54 ago, cause: software Last software reset at 2021-01-16 17:37, reason: User, none spinning, available RAM 143816, slot 0 Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task Linu Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 Aux1 errors 0,0,0 MCU temperature: min 38.4, current 45.5, max 46.3 Supply voltage: min 27.9, current 31.9, max 32.0, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 12.0, current 12.0, max 12.1, under voltage events: 0 Driver 0: position 159870, standstill, reads 2082, writes 36 timeouts 0, SG min/max 0/1023 Driver 1: position 0, standstill, reads 2082, writes 36 timeouts 0, SG min/max 0/1023 Driver 2: position 7282, standstill, reads 2027, writes 91 timeouts 0, SG min/max 0/162 Driver 3: position 0, standstill, reads 2083, writes 35 timeouts 0, SG min/max 0/455 Driver 4: position 0, standstill, reads 2083, writes 35 timeouts 0, SG min/max 0/834 Driver 5: position 0, standstill, reads 2083, writes 35 timeouts 0, SG min/max 0/658 Date/time: 2021-01-17 00:17:00 Slowest loop: 2999.36ms; fastest: 0.05ms === Storage === Free file entries: 10 SD card 0 not detected, interface speed: 37.5MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === DMs created 125, maxWait 13404166ms, bed compensation in use: mesh, comp offset 0.000 === MainDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 2], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 Heater 0 is on, I-accum = 0.1 === GCodes === Segments left: 0 Movement lock held by null HTTP* is doing "M122" in state(s) 0 Telnet is idle in state(s) 0 File* is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue* is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === CAN === Messages queued 213300, send timeouts 0, received 288328, lost 0, longest wait 1ms for reply type 6018, free buffers 48 === SBC interface === State: 4, failed transfers: 0 Last transfer: 1ms ago RX/TX seq numbers: 22968/24073 SPI underruns 0, overruns 0 Number of disconnects: 0, IAP RAM available 0x2c8a8 Buffer RX/TX: 0/0-0 === Duet Control Server === Duet Control Server v3.2.0 File: Finishing macro /sys/custom/Conditional_HomeAll.g, started by G0 Z5 F5000 ; Ensure nozzle is at 5mm over the bed > Next stack level Suspended code: T0 ; Mount extruder first used (even if only one extruder used). Waits for temperature inside the script. Suspended code: G21 ; set units to millimeters Suspended code: G90 ; use absolute coordinates Suspended code: M83 ; use relative distances for extrusion Suspended code: ;LAYER_CHANGE Suspended code: ;HEIGHT:0.3 Pending code: G1 E-0.50000 F3000.00000 Pending code: G1 Z0.350000 F18000.000 Pending code: G1 X209.977 Y198.059 Pending code: G1 E0.50000 F1800.00000 Pending code: G1 X212.132 Y196.103 E0.12648 Pending code: G1 X214.377 Y194.468 E0.12072 Pending code: G1 X216.798 Y193.069 E0.12155 Pending code: G1 X219.300 Y191.952 E0.11908 Pending code: G1 X220.807 Y191.424 E0.06944 Pending code: G1 X223.321 Y190.756 E0.11304 Pending code: G1 X224.861 Y190.477 E0.06806 Pending code: G1 X227.411 Y190.213 E0.11144 Pending code: G1 X250.157 Y190.174 E0.98868 Pending code: G1 X251.308 Y190.263 E0.05018 Pending code: G1 X252.377 Y190.512 E0.04775 Pending code: G1 X253.446 Y190.936 E0.04996 Pending code: G1 X254.301 Y191.423 E0.04278 Pending code: G1 X255.163 Y192.084 E0.04721 Pending code: G1 X255.968 Y192.922 E0.05052 Code buffer space: 4096 Configured SPI speed: 8000000 Hz Full transfers per second: 42.28 Maximum length of RX/TX data transfers: 3720/1688 File /opt/dsf/sd/gcodes/Front Stepper v5.2 - Bottom.gcode is selected, processing
After Canceling the print I tried restarting it but it says it is already printing.
2021-01-17 00:25:02 M32 "0:/gcodes/Front Stepper v5.2 - Bottom.gcode" Error: M32: Cannot set file to print, because a file is already being printed 2021-01-17 00:20:49 Cancelled printing file 0:/gcodes/Front Stepper v5.2 - Bottom.gcode, print time was 0h 19m
Diag after trying to restart:
=== Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.2 running on Duet 3 MB6HC v0.6 or 1.0 (SBC mode) Board ID: 08DJM-956L2-G43S4-6JKDD-3SJ6L-TB62G Used output buffers: 1 of 40 (16 max) === RTOS === Static ram: 149788 Dynamic ram: 65316 of which 152 recycled Never used RAM 143576, free system stack 128 words Tasks: Linux(blocked,71) HEAT(blocked,271) CanReceiv(blocked,809) CanSender(blocked,341) CanClock(blocked,352) TMC(blocked,19) MAIN(running,720) IDLE(ready,19) Owned mutexes: HTTP(MAIN) === Platform === Last reset 06:48:26 ago, cause: software Last software reset at 2021-01-16 17:37, reason: User, none spinning, available RAM 143816, slot 0 Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task Linu Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 Aux1 errors 0,0,0 MCU temperature: min 45.4, current 45.6, max 45.8 Supply voltage: min 31.9, current 31.9, max 32.0, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 12.0, current 12.0, max 12.1, under voltage events: 0 Driver 0: position 159870, standstill, reads 31841, writes 0 timeouts 0, SG min/max not available Driver 1: position 0, standstill, reads 31841, writes 0 timeouts 0, SG min/max not available Driver 2: position 9282, standstill, reads 31841, writes 0 timeouts 0, SG min/max not available Driver 3: position 0, standstill, reads 31837, writes 4 timeouts 0, SG min/max 0/152 Driver 4: position 0, standstill, reads 31837, writes 4 timeouts 0, SG min/max 0/201 Driver 5: position 0, standstill, reads 31836, writes 4 timeouts 0, SG min/max 0/124 Date/time: 2021-01-17 00:25:32 Slowest loop: 77.73ms; fastest: 0.06ms === Storage === Free file entries: 10 SD card 0 not detected, interface speed: 37.5MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === DMs created 125, maxWait 2861714ms, bed compensation in use: mesh, comp offset 0.000 === MainDDARing === Scheduled moves 2, completed moves 2, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 Heater 0 is on, I-accum = 0.1 === GCodes === Segments left: 0 Movement lock held by null HTTP* is doing "M122" in state(s) 0 Telnet is idle in state(s) 0 File* is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue* is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === CAN === Messages queued 2053, send timeouts 0, received 6149, lost 0, longest wait 1ms for reply type 6013, free buffers 48 === SBC interface === State: 4, failed transfers: 0 Last transfer: 1ms ago RX/TX seq numbers: 2343/3448 SPI underruns 0, overruns 0 Number of disconnects: 0, IAP RAM available 0x2c8a8 Buffer RX/TX: 0/0-0 === Duet Control Server === Duet Control Server v3.2.0 File: Finishing macro /sys/custom/Conditional_HomeAll.g, started by G0 Z5 F5000 ; Ensure nozzle is at 5mm over the bed > Next stack level Code buffer space: 4096 Configured SPI speed: 8000000 Hz Full transfers per second: 3160.22 Maximum length of RX/TX data transfers: 3720/1688 File /opt/dsf/sd/gcodes/Front Stepper v5.2 - Bottom.gcode is selected, processing, paused, cancelled
DSF:
[debug] IPC#938: Received command SimpleCode [debug] Waiting for execution of M32 "0:/gcodes/Front Stepper v5.2 - Bottom.gcode" [debug] Processing M32 "0:/gcodes/Front Stepper v5.2 - Bottom.gcode" [debug] Waiting for finish of M32 "0:/gcodes/Front Stepper v5.2 - Bottom.gcode" => Error: Cannot set file to print, because a file is already being printed [debug] Completed M32 "0:/gcodes/Front Stepper v5.2 - Bottom.gcode" => Error: M32: Cannot set file to print, because a file is already being printed
