    Beta11: "Error: Failed to initialise WiFi module, code -10"
    Firmware installation
    • raykholo
      raykholo last edited by
      Hi folks,
      Setting up a Duet Wifi today… I am running/powering it just over USB, I was able to set up wifi, access the web interface, and then I uploaded the latest beta11 firmware to the web interface. I believe it flashed successfully, but then network went down.
      I have read the wiki sections about updating and fallbacks, but I am confused about what the next step should be.
      I think this board has been sitting dormant for a few months, so it is entirely possible that the ESP8266 firmware is too old, or something else?
      Feedback after reset:
      http://imgur.com/U9KgiNW
      Thanks for the help!
      • raykholo
        An update,
        The next thing I tried to do was manually flash the experimental wifi firmware. This, after sending M552 S1, would report no known networks found followed by Wifi module is idle. I would never get a Duet access point.
        At this point I wiped the SD Card and created gcodes folder and copied macros from the github and sys from the sys-Prusai3.
        After this I did a manual flash of stable main firmware and wifi firmware, and now I was able to set up my wifi network again and access the web interface.
        So, I am now on stable firmware… Will wait until I am better aquainted with all this before try experimental again...
        One other question - I notice the Diag LED is constantly on, I'm not sure if it was before. It will blink off for a sec when the board is reset, but otherwise it is always on. Is this ok?
        Thanks!
          Always read the upgrade notes at https://github.com/dc42/RepRapFirmware/blob/dev/WHATS_NEW.md before installing new firmware. Had you done so, they would have led you to https://duet3d.com/wiki/DuetWiFiFirmware_1.19beta.
          The diag light shares a pin with the Z probe MOD signal, so it is always on when using a type 1 Z probe.
