Another mirrored core xy question
@Veti Thanks for pointing that out, idk why i had it like that, here is the full config:
; Configuration file for Duet WiFi (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.1.10 on Wed Dec 23 2020 01:01:14 GMT+0000 (Greenwich Mean Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"My Printer" ; set printer name M669 K1 ; select CoreXY mode ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S1 ; physical drive 0 goes forwards M569 P1 S1 ; physical drive 1 goes forwards M569 P2 S1 ; physical drive 2 goes forwards M569 P3 S1 ; physical drive 3 goes forwards M584 X0 Y1 Z2 E3 ; set drive mapping M350 X16 Y16 Z16 E8 I1 ; configure microstepping with interpolation M92 X160 Y160 Z1600.00 E400.00 ; set steps per mm M566 X900.00 Y900.00 Z60.00 E2000.00 ; set maximum instantaneous speed changes (mm/min) M203 X12000.00 Y12000.00 Z400.00 E4800.00 ; set maximum speeds (mm/min) M201 X800 Y800 Z20.00 E2000.00 ; set accelerations (mm/s^2) M906 X800 Y800 Z650 E1300 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S10 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X330 Y270 Z300 S0 ; set axis maxima ; Endstops M574 X1 S1 P"xstop" ; configure active-high endstop for low end on X via pin xstop M574 Y1 S1 P"ystop" ; configure active-high endstop for low end on Y via pin ystop M574 Z1 S2 ; configure Z-probe endstop for low end on Z ; Z-Probe M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch M558 P9 C"^zprobe.in" H3 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds G31 P500 X-35 Y0 Z3.4 ; set Z probe trigger value, offset and trigger height M557 X25:275 Y0:250 S50 ; define mesh grid ; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"e1heat" T0 ; create bed heater output on bedheat and map it to sensor 0 ********* HEAT BED ON E1 Temporary. M307 H0 A162.9 C183.2 D2.0 S1.00 V24.1 B0 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"e0temp" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S280 ; set temperature limit for heater 1 to 280C ; Fans M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C M572 D0 S0.05 ;Pressure Advance setting M501 ; Custom settings
@Fisher said in Another mirrored core xy question:
M308 S1 P"e0temp" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin e0tempthis is incorrect. find the correct beta value in your thermistor documentation.
@Veti Ok thanks, im going to get the basics sorted before i try and understand what a beta value is.
To resolve mirroring on a CoreYX printer, you need to swap the X and Y motor connections over, either physically or in M584. It's also possible to correct it by changing the M669 matrix, but that is over-complicated for solving this.
@dc42 thanks, i will still need to amend my endstop location and homeall / homey directions i assume.
Yes. Get G1 H2 moves working properly first, then sort out the endstop config and homing files. https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinter#Section_Testing_motor_movement
All sorted Thanks once again.
@Veti Would you be able to explain a little more about whats wrong with this or point me towards some info on thermister settings / what is a beta value? my hotend thermistor is a generic one from e3d, my bed thermister is integrated into silicone heat mat - cheap chinese one doubut i'll be able to find any documentation for it.
@Fisher If it's an E3D thermistor, it would use
Y"thermistor" T100000 B4725 C7.06e-8
those tend to be B3950 thermistors.
the beta value describes how the resistance changes with temperature as different thermistors behave differently.
if you have the wrong value it could easily read 200C but the actual temperature could be 20C off.
