    Duet2 wifi Not connecting
    Duet Web Control
    3.7k
      Put the SD card in your computer
      Use a text editor to create a file
      Enter the command M587 S"NETWORKNAME" P"PASSWORD" into the file with your network name and password.
      Save the file as addwifi and save it to the macros folder on the SD card.
      Put the card back in the duet and power it on by connecting to usb
      Use YAT to send the command M98 Paddwifi
      That will run the macro and try adding your ssid and password
      The send m552 S1 and see if it connects.
      Just because they say there is no security stopping it doesn't mean that it will work. There could be other technical reasons preventing it that were just not aware of.
      • Tisum1979undefined
        Tisum1979
        not sure how to get to text editor.
          note pad on windows
            Tisum1979
            Is that normal for Wifi vcc 3.33, reset reason turned on by main processor
              yes that's normal.
                Tisum1979
                on my duet2 board the 3.3v light is red not green
                  Tisum1979
                  Hey this is what things say as of now for my Duet2 wifi-WiFi module is trying to connect<LF>
                  Failed messages: pending 0, notready 0, noresp 0<LF>
                  WiFi firmware version 1.23<LF>
                  WiFi MAC address 98:f4:ab:cf:be:21<LF>
                  WiFi Vcc 3.33, reset reason Turned on by main processor<LF>
                  WiFi flash size 4194304, free heap 28112<LF>
                  Socket states: 0 0 0 0 0 0 0 0<LF>
                  ok<LF>
                  M587<LF>
                  Remembered networks:<LF>
                  MySpectrumWiFiF8-2G IP=192.168.1.1 GW=0.0.0.0 NM=0.0.0.0<LF>
                  ok<LF>
                  WiFi reported error: Failed while trying to connect to MySpectrumWiFiF8-2G<LF>
                  WiFi module is idle<LF>
                    Tisum1979
                    Can I upgrade firmware from 2.05.1 / wifi firmware version 1.23 if I can not get onto my WCB?
                      Tisum1979
                      ok so I created a access point which isn't connected to the internet however I typed in my IP address and the control board popped up and the blue light is on to my wifi but I can not get my WCB to connect
                        Phaedrux Moderator @Tisum1979
                        @Tisum1979 said in Duet2 wifi Not connecting:
                        Where did you get that ip address? Are you sure it's correct?
                        You mean on your router, or with the Duet itself as an access point?
                        Yes you can, but I would suggest getting connected first and doing it from the DWC if at all possible.
                        https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware
