    Failed to Enable Endstops
    1.6k
    • Tpmosesundefined
      Tpmoses
      Today I upgraded the firmware on my Duet 2 Wifi from 2.x to the newest 3.2, I also redid my configuration with the rep rap config tool to be compatible. When I went to home for the first time I received an error saying "failed to enable end stops" I am not sure where I have gone wrong. Any help would be much appreciated.
      Here is the updated config file,
      config (1).g
      • Tpmosesundefined
        Tpmoses
        I am also having an issue with the temp readings on my heaters reading - 273.1 C.
        Thanks
        • fcwiltundefined
          fcwilt
          First let me suggest that in the future you use the </> tags to embed code into your post.
          For example here is the file you posted using those tags. Notice that it appears in it's own scrollable section.
          ; generated by RepRapFirmware Configuration Tool v3.2.2 on Fri Jan 22 2021 11:13:01 GMT-0600 (Central Standard Time)
          M550 P"Caymas 3D Printer"                          ; set printer name
          M569 P0 S1                                         ; physical drive 0 goes forwards
          M569 P1 S0                                         ; physical drive 1 goes forwards
          M569 P2 S0                                         ; physical drive 2 goes forwards
          M569 P3 S0                                         ; physical drive 3 goes forwards
          M584 X0 Y1 Z2 E3                                   ; set drive mapping
          M92 X320.00 Y320.00 Z640.00 E40.00                 ; set steps per mm
          M566 X200.00 Y200.00 Z12.00 E120.00                ; set maximum instantaneous speed changes (mm/min)
          M203 X3000.00 Y3000.00 Z3400.00 E4000.00            ; set maximum speeds (mm/min)
          M201 X200.00 Y200.00 Z12.00 E250.00                ; set accelerations (mm/s^2)
          M906 X2000 Y2000 Z2800 E800 I30                    ; set motor currents (mA) and motor idle factor in per cent
          M208 X1100 Y1100 Z1100 S0                          ; set axis maxima
          M574 X1 S0 P"xstop"                                ; configure active-low endstop for low end on X via pin xstop
          M574 Y1 S0 P"ystop"                                ; configure active-low endstop for low end on Y via pin ystop
          M574 Z1 S2                                         ; configure Z-probe endstop for low end on Z
          M558 P1 C"zprobe.in+zprobe.mod" H5 F240 T3600      ; set Z probe type to unmodulated and the dive height + speeds
          G31 P500 X570 Y570 Z1.8                            ; set Z probe trigger value, offset and trigger height
          M557 X100:1100 Y100:1100 S100                      ; define mesh grid
          M308 S1 P"bedtemp" Y"thermistor" T100000 B4138     ; configure sensor 0 as thermistor on pin bedtemp
          M307 H0 B0 S1.00                                   ; disable bang-bang mode for the bed heater and set PWM limit
          M308 S0 P"e0temp" Y"thermistor" T100000 B4138      ; configure sensor 1 as thermistor on pin e0temp
          M143 H1 S320                                       ; set temperature limit for heater 1 to 320C
          M950 F0 C"fan0" Q500                               ; create fan 0 on pin fan0 and set its frequency
          M106 P0 S0 H-1                                     ; set fan 0 value. Thermostatic control is turned off
          M950 F1 C"fan1" Q500                               ; create fan 1 on pin fan1 and set its frequency
          M106 P1 S1 H1 T45                                  ; set fan 1 value. Thermostatic control is turned on
          M575 P1 S1 B57600                                  ; enable support for PanelDue
          Here is one of your end stop specifications
          M574 X1 S0 P"xstop"
          Notice the S parameter value. From the docs:
          Snnn 1 = switch-type (eg microswitch) endstop input, 2 = Z probe (when used to home an axis other than Z), 3 = single motor load detection, 4 = multiple motor load detection (see Notes).
          • fcwiltundefined
            fcwilt @Tpmoses
            @Tpmoses said in Failed to Enable Endstops:
            Thanks
            You have the values of the S parameters swapped - should be S0 in the first, S1 in the second .
            But I don't think that should cause the -273.1 - that corresponds to a missing thermistor.
            Tpmosesundefined 1 Reply Last reply Reply Quote 0
            • Vetiundefined
              Veti
              can you post your old config?
              Tpmosesundefined 2 Replies Last reply Reply Quote 0
              • Tpmosesundefined
                Tpmoses
                Thank you, I will embed like that in the future. That change has worked, however now the x and y axis' do not move when homed, any advice?
                • fcwiltundefined
                  fcwilt @Tpmoses
                  So both the error message about the end stops is gone AND the temperature readings are correct?
                  • Tpmosesundefined
                    Tpmoses @fcwilt
                    @fcwilt I made that change, however the sensors remain the same reading There is a temperature daughterboard that the sensors are run wired through. Forgive me for not mentioning it, I inherited this printer at work from a former employee who built it.
                    • Tpmosesundefined
                      Tpmoses @Veti
                      This post is deleted!
                      • Tpmosesundefined
                        Tpmoses @Veti
                        @Veti Here is the old config
                        ; generated by RepRapFirmware Configuration Tool v3.1.4 on Tue Jul 21 2020 13:39:57 GMT-0500 (Central Daylight Time)
                        M569 P8 S1                                         ; physical drive 6 goes forwards
                        M569 P6 S0                                         ; physical drive 8 goes forwards
                        M569 P5 S0                                         ; physical drive 5 goes forwards
                        M584 X8 Y6 Z2 E5                                   ; set drive mapping
                        M92 X320.00 Y320.00 Z640.00 E4.00                  ; set steps per mm
                        M203 X3000.00 Y3000.00 Z340.00 E4000.00            ; set maximum speeds (mm/min)
                        M201 X200.00 Y200.00 Z20.00 E250.00                ; set accelerations (mm/s^2)
                        M574 X1 Y1 S0                                      ; set active low and disabled endstops
                        M574 Z1 S2                                         ; set endstops controlled by probe
                        M558 P1 H5 F240 T3600                              ; set Z probe type to unmodulated and the dive height + speeds
                        G31 P500 X570 Y570 Z1.18                           ; set Z probe trigger value, offset and trigger height
                        M305 P0 X151                                       ; configure thermocouple for heater 0
                        M305 P1 X150                                       ; configure thermocouple for heater 1
                        M106 P0 S0 I0 F500 H-1                             ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                        M106 P1 S1 I0 F500 H1 T45                          ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                        • Vetiundefined
                          Veti
                          your old config had a thermocouple, your new one has a thermistor configured
                          • fcwiltundefined
                            fcwilt
                            Well based on the old config you need to use one of the "thermocouple" values in M308 - you currently have "thermistor".
                            Try one or the other of them and see if they work.
                            • Tpmosesundefined
                              Tpmoses @fcwilt
                              @fcwilt I tried having the bed as a thermocouple and it went to 2000.0 C, Could it be due to the sensors being wired through the daughter board? maybe I need to call to a different sensor?
                              • Tpmosesundefined
                                Tpmoses
                                The page with information on the board had this to say about it.
                                "If your daughter board has two LEDs labelled FAULT then it uses MAX31856 chips. In this case the terminal blocks labelled 1 and 2 on the lower daughter board will be temperature measurement channels 150 and 151 respectively."
                                • fcwiltundefined
                                  fcwilt @Tpmoses
                                  Did you try both values?
                                  I've never used one of the add-on boards so I'm not sure what parameters you need in M308.
                                  Do you check the M308 docs?
                                  • fcwiltundefined
                                    fcwilt @Tpmoses
                                    So do those values 150 and 151 need to be used somewhere in the config.g file?
                                    • Tpmosesundefined
                                      Tpmoses
                                      I was able to get the bed sensor to read, using this line.
                                      M308 S0 P"spi.cs1" Y"thermocouple-max31856"
                                      M307 H0 B0 S1
                                      • Tpmosesundefined
                                        Tpmoses
                                        The Heating Element temp now works too, the Callout is the spi.cs1, the number changes based on the port on the daughter chip.
                                        • fcwiltundefined
                                          fcwilt
                                          Excellent - glad to hear you got it working.
                                          And I learned something new in the process - thank you.
                                          Anything else not working?
                                          • Tpmosesundefined
                                            Tpmoses @fcwilt
                                            @fcwilt The x and y drives wont run and I am guessing the extruder will have the same problem as it is on that board, they are on a breakout board not the standard drive ports. The previous config the ports used were 8, 6, and 5 respectively, in the new configuration they were assigned as 0, 1 and 3. Z didn't change, and its the only one that is still working. When I assign them like the previous config nothing happens, so I am guessing when I say there is probably a callout in the drive assignment that I am missing.
