"Resume after a power failure" not working
I am using Duet 2 wifi 1.02, firmware version 2.05 on 24V cartesian printer. The resume after power loss feature is not working properly. Sometimes saving to resurrect.g file, sometimes not. Eventually it stopped working at all. Can anyone help me where I might have gone wrong or has anyone experienced that under what conditions it does not work? Thank you
The gcode I use is as follows
M911 S21.0 R23.0 P"M913 X0 Y0 G91 M83 G1 Z3 F1000"
PSU is OMRON 24V 350W -
Try removing the z move from your command to see if it saves correctly then. Perhaps the z move is draining too much power and preventing it from writing.
There are some threads in the forum discussing adding capacitors to allow for a bit more reserve.
