    Rrf3. 2 + Lc1: no extruder function after new installation
    Firmware installation
    • Frederik
      Frederik last edited by Frederik
      Everytime I want to use the extruder drive, I got the message
      Discarded msg src=121 typ=4510 RID=4095 exp 79
      Bltouch and x endstop are working normal without errors
      M122
      28.1.2021, 10:43:00	Warning: Discarded msg src=121 typ=4510 RID=4095 exp 79
      28.1.2021, 10:42:50	M122
      RepRapFirmware for Duet 3 MB6HC version 3.2 running on Duet 3 MB6HC v1.01 or later (SBC mode)
      Board ID: 08DJM-956BA-NA3TN-6J9DL-3S46S-99AUT
      Used output buffers: 2 of 40 (13 max)
      Static ram: 149788
      Dynamic ram: 63384 of which 128 recycled
      Never used RAM 145532, free system stack 132 words
      Tasks: Linux(ready,75) HEAT(blocked,271) CanReceiv(blocked,809) CanSender(blocked,352) CanClock(blocked,352) TMC(blocked,19) MAIN(running,1217) IDLE(ready,19)
      Owned mutexes: HTTP(MAIN)
      Last reset 07:00:22 ago, cause: software
      Last software reset at 2021-01-28 03:42, reason: User, none spinning, available RAM 145584, slot 0
      Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044a000 BFAR 0x00000000 SP 0x00000000 Task Linu Freestk 0 n/a
      Error status: 0x00
      Aux0 errors 0,0,0
      Aux1 errors 0,0,0
      MCU temperature: min 42.5, current 44.9, max 48.3
      Supply voltage: min 24.0, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
      12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0
      Driver 0: position 73370, standstill, reads 25233, writes 23 timeouts 0, SG min/max 0/186
      Driver 1: position 0, standstill, reads 25233, writes 23 timeouts 0, SG min/max 0/197
      Driver 2: position 13410, standstill, reads 25229, writes 27 timeouts 0, SG min/max 0/162
      Driver 3: position 0, standstill, reads 25229, writes 27 timeouts 0, SG min/max 0/159
      Driver 4: position 0, standstill, reads 25229, writes 27 timeouts 0, SG min/max 0/165
      Driver 5: position 0, standstill, reads 25245, writes 11 timeouts 0, SG min/max 0/0
      Date/time: 2021-01-28 10:42:48
      Slowest loop: 178.90ms; fastest: 0.05ms
      === Storage ===
      Free file entries: 10
      DMs created 125, maxWait 20514412ms, bed compensation in use: none, comp offset 0.000
      === MainDDARing ===
      Scheduled moves 35, completed moves 35, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 5], CDDA state -1
      === AuxDDARing ===
      Bed heaters = 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = 2 -1 -1 -1
      Heater 1 is on, I-accum = 0.0
      Segments left: 0
      Movement lock held by null
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty.
      === CAN ===
      Messages queued 100945, send timeouts 0, received 302664, lost 0, longest wait 3ms for reply type 6029, free buffers 48
      === SBC interface ===
      State: 4, failed transfers: 0
      Last transfer: 3ms ago
      RX/TX seq numbers: 53532/53532
      SPI underruns 0, overruns 0
      Number of disconnects: 0, IAP RAM available 0x2c8a8
      Buffer RX/TX: 0/0-0
      === Duet Control Server ===
      Duet Control Server v3.2.0
      Code buffer space: 4096
      Configured SPI speed: 8000000 Hz
      Full transfers per second: 35.91
      Maximum length of RX/TX data transfers: 4508/652
      M122 b121
      m122 b121
      Diagnostics for board 121:
      Duet TOOL1LC firmware version 3.3beta (2021-01-21 11:34:37)
      Bootloader ID: SAMC21 bootloader version 2.2 (2021-01-16b1)
      Never used RAM 4052, free system stack 0 words
      Move 152 HEAT 89 CanAsync 66 CanRecv 78 CanClock 66 TMC 56 MAIN 203 AIN 62
      Last reset 07:02:27 ago, cause: software
      Last software reset time unknown, reason: OutOfMemory, available RAM 15632, slot 2
      Software reset code 0x01c0 ICSR 0x00000000 SP 0x20003578 Task MAIN Freestk 747 ok
      Stack: 20000d10 00011ceb 20000d10 0001df61 00000000 00004008 20000d10 0001ded5 20000d0c 00004000 a5a5a5a5 a5a5a5a5 00000000 0001dd9d 00004000 00018b21 a5a5a5a5 00018b3d a5a5a5a5 00011b39 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5
      Driver 0: position 0, 859.0 steps/mm, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 98, reads 25306, writes 21, timeouts 0, DMA errors 0, steps req 0 done 0
      Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
      Peak sync jitter 175, peak Rx sync delay 216, resyncs 0, no step interrupt scheduled
      VIN: 23.5V
      MCU temperature: min 38.0C, current 49.2C, max 60.3C
      Ticks since heat task active 103, ADC conversions started 25246436, completed 25246435, timed out 0
      Last sensors broadcast 0x00000002 found 1 110 ticks ago, loop time 0
      CAN messages queued 304190, send timeouts 0, received 228189, lost 0, free buffers 36, min 36, error reg 0
      dup 0, oos 0, bm 0, wbm 0
      Config.g
      G90                                                          ; send absolute coordinates...
      M83                                                          ; ...but relative extruder moves
      M550 P"vcore"                                               ; set printer name
      M669 K1                                                      ; select CoreXY mode
      M569 P0.0 S1
      M569 P0.1 S1
      M569 P0.2 S1
      M569 P0.3 S1
      M569 P0.4 S1
      M569 P121.0 S0
      M584 X0.0 Y0.1 Z0.2:0.3:0.4 E121.0
      M350 X16 Y16 Z16 E16 I1                                      ; configure microstepping with interpolation
      M92 X159.50 Y159.50 Z1600.00 E859.00                         ; set steps per mm
      M566 X900.00 Y900.00 Z60.00 E120.00                          ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00                      ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 E250.00                          ; set accelerations (mm/s^2)
      M906 X1500 Y1500 Z1200 E1000 I100                             ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                                      ; Set idle timeout
      M208 X0 Y0 Z0 S1                                             ; set axis minima
      M208 X380 Y380 Z380 S0                                       ; set axis maxima
      ; Position of Leadscrews
      M671 X-30:450:235 Y200:200:450 S6 ;Position of Leadscrews
      M574 X1 S1 P"121.io2.in"                                     ; configure active-high endstop for low end on X via pin 121.io2.in
      M574 Y1 S1 P"io0.in"                                         ; configure active-high endstop for low end on Y via pin io0.in
      M574 Z1 S2                                                   ; configure Z-probe endstop for low end on Z
      M950 S0 C"121.io0.out"                                       ; create servo pin 0 for BLTouch
      M558 P9 C"^121.io0.in" H5 F120 T9000 A10 B1 R0.5                         ; set Z probe type to bltouch and the dive height + speeds
      ;M558 H30                                                     ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
      G31 P1000 X-28 Y-22 Z3.38                                     ; set Z probe trigger value, offset and trigger height
      ; Mesh Grid
      M557 X0:360 Y0:360 P7:7 ; define mesh grid (Abstand X:Y in mm - Sx:x / Punkte X:Y - Px:x)
      ; Bed Compensation Taper
      M376 H0 ; Height (mm) over which to taper off the bed compensation should be min 20x Times the mean error / 0 or ;
      ; BMG Pressure Advance
      M572 D0:1 S0.000
      ; FW Retraction Mosquito (S)-Retraction Dist. (F) Speed , (Z) ZHopHeight
      M207 S0.5 F4000 Z0.0
      ; Volumetric Extrusion Filament Diameter (D)
      M200 D1.75:1.75
      ; Extrusion Override Factor to 83 %
      M221 S100 D0:1
      ;--Ringing Frequenz
      ;M593 F40.5 ; Ringing Frequency DirectDrive
      ;--Print Monitor - Filament (N) and Nozzle diameter (D)
      M404 N1.75 D0.4
      ;--Duet Laser Filament Monitor
      ;M591 D0 P5 C"121.io1.in" R30:130 E3.0 S0 ; Extruder0 Tolerance 30 to 130%, 3mm comparison length, diabled
      M308 S0 P"temp0" Y"thermistor" T100000 B4138                 ; configure sensor 0 as thermistor on pin temp0
      M950 H0 C"out7" T0                                           ; create bed heater output on out0 and map it to sensor 0
      M307 H0 B0 S1.00                                             ; disable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                                      ; map heated bed to heater 0
      M143 H0 S160                                                 ; set temperature limit for heater 0 to 160C
      M308 S1 P"121.temp0" Y"thermistor" T500000 B4723 C1.19622e-7 ; configure sensor 1 as thermistor on pin 121.temp1
      M950 H1 C"121.out0" T1                                       ; create nozzle heater output on 121.out0 and map it to sensor 1
      M307 H1 B0 S1.00                                             ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S500                                                 ; set temperature limit for heater 1 to 500C
      M308 S2 P"temp1" Y"thermistor" T100000 B4725 C7.06e-8        ; configure sensor 2 as thermistor on pin temp1
      M950 H2 C"out8" T2                                           ; create chamber heater output on out2 and map it to sensor 2
      M307 H2 B0 S1.00                                             ; disable bang-bang mode for the chamber heater and set PWM limit
      M141 H2                                                      ; map chamber to heater 2
      M143 H2 S120                                                 ; set temperature limit for heater 2 to 120C
      ;PID Parameters for 100°C
      M307 H0 R0.641 C754.7 D2.82 S1.00 V24.1
      ; PID Parameters for 350°C
      M307 H1 R2.223 C207.2 D7.81 S1.00 V24.0
      M950 F0 C"121.out2" Q500                                     ; create fan 0 on pin 121.out2 and set its frequency
      M106 P0 C"Mosquito" S0.6 H1 T45                              ; set fan 0 name and value. Thermostatic control is turned on
      M950 F1 C"121.out1" Q500                                     ; create fan 1 on pin 121.out1 and set its frequency
      M106 P1 C"Bauteil" S0 H-1                                    ; set fan 1 name and value. Thermostatic control is turned off
      ;Air Pump Control on SSR_3
      M950 F2 C"out9" Q255 ; create fan 1 on pin 121.out1 and set its frequency
      M106 P2 C"AirCompressor" S0 H-1 ; set fan 1 name and value. Thermostatic control is turned off
      ;Led Beleuchtung
      ; Zone 1
      M950 F3 C"out2" Q500 ; create a output for led zone1 on out3
      M106 P3 S1 ; set output default to on
      ; Zone 2
      M950 F4 C"out3" Q500 ; create a fan output for led zone2 on out4
      M106 P4 S1 ; set output default to on
      ; Toolboard Buttons
      ;button0 LC1.121
      M950 J4 C"121.button0" ; Input 4 uses io4 pin, inverted
      M581 P4 S1 C0 T2 R0 ; configure button for LED ON
      ; button1 LC1.121
      M950 J5 C"121.button1" ; Input 5 uses io5 pin, inverted
      M581 P5 S1 C0 T3 R0 ; configure push button for LED OFF
      ;Tools
      T0
      M563 P0 S"Mosquito" D0 H1 L0 F0:1  ; define tool 0
      M563 P0 S"Mosquito" D0 H1 F0:1:2                             ; define tool 0
      G10 P0 X0 Y0 Z0                                              ; set tool 0 axis offsets
      G10 P0 R0 S0                                                 ; set initial tool 0 active and standby temperatures to 0C
      M501                                                         ; load saved parameters from non-volatile memory
      M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"           ; set voltage thresholds and actions to run on power loss
      T0                                                           ; select first tool
      Regards
      Frederik
        Tool board firmware 3.3beta is not compatible with main board firmware 3.2.
