    RRF3.2 upgrade help
    Using Duet Controllers
    87
    • CTRDevelopments
      CTRDevelopments last edited by
      Hi, I have just upgraded from RRF2 to 3.2 (via 3.0). I have modified my config.g, but am getting some strange errors which must be my mistakes/misunderstandings.
      Firstly I am getting an error when I home the x and y axis (not tried z yet), where it tells me 'endstop type 0 is not longer supported, use type 1 and invert'. However I dont think I am using type 0? I am using sensorless homing, which worked fine previously
      I also get am getting wierd errors on the temps for both the bed and the nozzle where they have clearly defaulted to 2000 degrees.
      Lastly, when I startup the printer the paneldue gives 'bad command 00' and then displays 'heater 2 not found' 'heater 3 not found' and so on.
      yes there are 2 motors on y, 2 extruder motors, and 3 z motors 🙂
      Any help would be most appreciated
      Many thanks
      code below
      ; General Preferences
      M111 S0 ; Debugging off
      G21 ; Work in millimetres
      M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Configure automatic saving on power loss
      M564 H0 ; Allow movements before homing
      M550 P"CTR 3DPrintR" ; Set machine name
      M552 S1 ; Enable network
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M569 P0 S1 ; Drive 0 goes forwards, X Axis
      M569 P3 S1 ; Drive 3 goes forwards, E0
      M569 P4 S1 ; Drive 4 goes backwards, E1
      M569 P5 S1 ; Drive 5 goes forwards, Y Axis
      M569 P6 S1 ; Drive 6 goes forwards, Y Axis
      M569 P7 S1 ; Drive 7 goes forwards, Z Axis
      M569 P8 S1 ; Drive 8 goes forwards, Z Axis
      M569 P9 S1 ; Drive 9 goes forwards, Z Axis
      M584 X0 Y5:6 Z7:8:9 E3:4 ; New drive mapping
      M92 X320 Y320 Z1600 E880:745 ; Set steps per mm
      M566 X500 Y500 Z12 E120 ; Set maximum instantaneous speed changes (mm/min)
      M203 X30000 Y30000 Z150 E5000 ; Set maximum speeds (mm/min)
      M201 X750 Y750 Z250 E3000 ; Set accelerations (mm/s^2)
      M906 X1000 Y1500 Z1500 E1500:500 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      ;Axis Limits
      M208 X490 Y495 Z400 S0 ; Set axis maxima
      M574 X1 S3 ; Set Stall endstops X
      M574 Y1 S4 ; Set Stall endstops Y
      M915 H200 X Y S3 R3 F0 ; Configure Stall Endstops, set X and Y to sensitivity 3, Rehome when stall, unfiltered
      ;Z-Probe
      M558 P1 C"zprobe.in" H5 F120 T6000 ; Set Z probe type to unmodulated and the dive height + speeds
      G31 P500 X-55 Y60 Z3.32 ; Set Z probe trigger value, offset and trigger height, Positive Value of Z moves the head closer to the bed
      M557 X20:410 Y80:430 S50 ; Define mesh grid
      ;Mechanical Setup
      M671 X-85:620:620 Y300:60:500 S5 ; Ballscrews at centre left, front right and rear right
      M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 C0 R4700 ; Set thermistor + ADC parameters for heater 0
      M950 H0 C"bedheat" T0 ; Create bed heater output on bedhaeat and map it to sensor 0
      M307 H0 B0 S1.00 ; Disable Bang Bang mode for the bed heater and set PWM limit
      M140 H0 ; Map heatbed to heater 0
      M308 S0 P"spi.cs1" Y"max31865" F50 ; Set thermistor + ADC parameters for heater 1 and remap it to channel 200
      M950 H1 C"e0heat" T1 ; Create nozzle heater output on e0heat and map it to sensor 1
      M307 H1 B0 S1.00 ; Disable Bang Bang mode for the bed heater and set PWM limit
      M950 F0 C"fan0" Q500 ; Create fan0 on pin 0 and set its frequency
      M106 P0 S0 H-1 ; Set fan0 value. Thermostatic control is off
      M950 F1 C"fan1" Q500 ; Create fan1 on pin 0 and set its frequency
      M106 P1 T20:40 H100:101:102 I1 F25000 ; Set fan0 value. Thermostatic control is on at 45 degrees. Case Cooling Fan
      M563 P0 D0:1 H1 ; Define tool 0
      G10 P0 X0 Y0 Z0 ; Set tool 0 axis offsets, Positive Value of Z moves the head closer to the bed
      M307 H1 A505.7 C412.1 D3.9 S1.00 V24.2 B0
      M567 P0 E1:1
      ; Magnetic Filament Sensor
      ;M591 D0 P4 C3 S1 R0:300 L25.0 E20 ;Duet3D rotating magnet sensor for extruder drive 0, connected to E0 endstop input, enabled, sensitivity 25.0mm.rev, 70% to 300% tolerance, 30mm detection length
      M501
        Post your homing files.
        Post the results of M122 and M98 P"config.g"
        Did you generate a fresh config set using the web tool?
        https://configtool.reprapfirmware.org/Start
        If you did, did you also take the entire package including the homing files etc?
        • CTRDevelopments
          I didn't use the tool directly, as I could work out how to get 2 motors on the extruder and 3 on the z etc. But I made a basic setup and copied the changes.
          ; homex.g
          ; called to home the X axis
          G91 ; use relative positioning
          G1 H2 X0.5 Y-0.5 F10000 ; energise
          M400 ; make sure everything has stopped before we make changes
          G4 P100 ; wait 400ms
          ;M913 X25 Y25 ; drop motor currents to 50%
          M915 H200 X Y S10 R0 F0 ; set X and Y to sensitivity 10, do nothing when stall, unfiltered
          G1 H2 Z3 F5000 ; lift Z 3mm
          G1 H1 X1 F3000 ; move right 1mm, stopping at the endstop
          G4 P100 ; wait 100ms
          G1 H1 X-500 F3000 ; move left 400mm, stopping at the endstop
          G1 H1 X2 F2000 ; move away from end
          G1 H2 Z-3 F1200 ; lower Z
          G90 ; back to absolute positioning
          M400 ; make sure everything has stopped before we reset the motor currents
          ;M913 X100 Y100 ; motor currents back to 100%
          M574 X1 S0 ; Define active low and unused microswitches
          • CTRDevelopments
            ; homey.g
            ; called to home the Y axis
            M913 X75 Y75 ; drop motor currents to 75%
            M915 H200 X Y S7 R0 F0 ; set X and Y to sensitivity 7, do nothing when stall, unfiltered
            G1 H1 Y1 F2000 ; move away from end
            G1 H1 Y-500 F3000 ; move to the front 400mm, stopping at the endstop
            G1 H1 Y2 F2000 ; move away from end
            M915 H200 X Y S3 R3 F0 ; set X and Y to sensitivity 3, Rehome when stall, unfiltered
            • CTRDevelopments
              ; homez.g
              ; called to home the Z axis
              ; generated by RepRapFirmware Configuration Tool on Mon Jan 01 2018 19:47:24 GMT+0000 (GMT Standard Time)
              G90 ; relative positioning
              G1 Z5 F6000 ; lift Z relative to current position
              G90 ; absolute positioning
              G1 X40 Y40 F6000 ; go to first probe point
              G91 ; relative positioning
              G1 Z5 F100 ; lift Z relative to current position
              • CTRDevelopments
                M122
                RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2 running on Duet WiFi 1.0 or 1.01 + DueX5
                Board ID: 08DAM-999TL-MQ4S4-6JKDJ-3SD6K-1QGBZ
                Used output buffers: 3 of 24 (12 max)
                Static ram: 23460
                Dynamic ram: 73716 of which 0 recycled
                Never used RAM 14904, free system stack 191 words
                Tasks: NETWORK(ready,175) HEAT(blocked,323) DUEX(blocked,35) MAIN(running,548) IDLE(ready,19)
                Owned mutexes:
                Last reset 00:01:27 ago, cause: software
                Last software reset at 2021-01-29 06:57, reason: User, GCodes spinning, available RAM 14904, slot 1
                Error status: 0x00
                Aux0 errors 0,0,0
                MCU temperature: min 17.7, current 18.2, max 19.0
                Supply voltage: min 24.3, current 24.4, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes
                Driver 0: position 0, standstill, SG min/max not available
                Driver 1: position 0, standstill, SG min/max not available
                Driver 2: position 0, standstill, SG min/max not available
                Driver 5: position 0, standstill, SG min/max not available
                Driver 6: position 0, standstill, SG min/max not available
                Driver 7: position 0, standstill, SG min/max not available
                Driver 8: position 0, standstill, SG min/max not available
                Driver 9: position 0, standstill, SG min/max not available
                Driver 10: position 0
                Driver 11: position 0
                Date/time: 2021-01-29 06:58:33
                Cache data hit count 107583709
                Slowest loop: 11.37ms; fastest: 0.20ms
                === Storage ===
                Free file entries: 10
                SD card longest read time 3.0ms, write time 0.0ms, max retries 0
                === MainDDARing ===
                === AuxDDARing ===
                Segments left: 0
                Movement lock held by null
                HTTP is idle in state(s) 0
                Telnet is idle in state(s) 0
                File is idle in state(s) 0
                USB is idle in state(s) 0
                Aux is idle in state(s) 0
                Trigger is idle in state(s) 0
                Queue is idle in state(s) 0
                LCD is idle in state(s) 0
                Daemon is idle in state(s) 0
                Code queue is empty.
                === Network ===
                Slowest loop: 288.93ms; fastest: 0.00ms
                Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
                HTTP sessions: 1 of 8
                • WiFi -
                  Network state is active
                  WiFi firmware version 1.25
                  WiFi MAC address 5c:cf:7f:2c:27:7e
                  WiFi Vcc 3.37, reset reason Turned on by main processor
                  WiFi flash size 4194304, free heap 24640
                  WiFi IP address 192.168.86.66
                  WiFi signal strength -55dBm, mode 802.11n, reconnections 0, sleep mode modem
                  Clock register 00002002
                  === DueX ===
                  Read count 1, 0.68 reads/min
                • CTRDevelopments
                  1/29/2021, 6:59:04 AM M98 P"config.g"
                  HTTP is enabled on port 80
                  FTP is disabled
                  TELNET is disabled
                  Error: Unknown sensor type name "max31865"
                  Warning: Sensor number 1 has not been defined
                  Error: Sensor number out of range
                  Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 530C
                  Error: Heater 2 not found
                  Error: Heater 3 not found
                  Error: Heater 4 not found
                  Error: Heater 5 not found
                  Error: Heater 6 not found
                  Error: Heater 7 not found
                  • CTRDevelopments
                    Sorry for the spam! It just looked clearer to me
                    Many thanks
                    • CTRDevelopments
                      OK, I have fixed the temperatures not showing. It seems a couple of typos on my behalf
                      • CTRDevelopments
                        aha, it seems the macros were causing the issue, all fixed
                          So you've got it all working now?
