    Custom Output Pin?
    Firmware developers
    • TLAS
      TLAS last edited by
      I'm looking to develop some code to run a set of LEDs - what's the best pin to use for a custom digital output? I don't need the duex pins.
        The easiest pins to use are probably the 5 additional heater pins on the expansion connector.
        • TLAS
          TLAS last edited by
          So I've decided to incorporate the Duex 2 due to the on-board voltage conversion and additional heaters. The card also mentions that it has the uncommitted in/out pins? Where are they in the firmware?
            See https://duet3d.com/wiki/Using_servos_and_controlling_unused_I/O_pins.
