Error building RepRapFirmware 3.3-dev
Building "Duet3" I get the following. Also tried to build "Duet3_Debug" it errors with "arm-none-eabi-gcc.exe: error: ./src/Fans/LocalFan.: No such file or directory".
21:07:16 **** Incremental Build of configuration Duet3 for project RepRapFirmware ****
make -j12 all
Building target: Duet3Firmware_MB6HC.elf
Invoking: Cross G++ Linker
arm-none-eabi-gcc -L"N:\GitHub\CoreN2G\SAME70_CAN_SDHC_USB_RTOS" -L"N:\GitHub\RRFLibraries\SAME70_RTOS" -L"N:\GitHub\FreeRTOS\SAME70" -L"N:\GitHub\CANlib\SAME70_RTOS" --specs=nosys.specs -Os -Wl,--gc-sections -Wl,--fatal-warnings -mcpu=cortex-m7 -mfpu=fpv5-d16 -mfloat-abi=hard -T"N:\GitHub\RepRapFirmware\src\Hardware\SAME70\same70q20b_flash.ld" -Wl,-Map,"N:\GitHub\RepRapFirmware\Duet3/Duet3Firmware_MB6HC.map" -o "Duet3Firmware_MB6HC.elf" -mthumb -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--entry=Reset_Handler -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -Wl,--warn-unresolved-symbols -Wl,--start-group ./src/libcpp/eh_alloc.o ./src/libcpp/vterminate.o ./src/libc/memcmp.o ./src/libc/memcpy.o ./src/libc/memmove.o ./src/libc/memset.o ./src/libc/nano-mallocr.o ./src/libc/strptime.o ./src/bossa/Applet.o ./src/bossa/BossaFlash.o ./src/bossa/Device.o ./src/bossa/EefcFlash.o ./src/bossa/Flasher.o ./src/bossa/Samba.o ./src/bossa/WordCopyApplet.o ./src/bossa/WordCopyArm.o ./src/Tools/Filament.o ./src/Tools/Spindle.o ./src/Tools/Tool.o ./src/Storage/CRC16.o ./src/Storage/CRC32.o ./src/Storage/FileInfoParser.o ./src/Storage/FileStore.o ./src/Storage/MassStorage.o ./src/ObjectModel/ObjectModel.o ./src/Networking/LwipEthernet/Lwip/src/netif/bridgeif.o ./src/Networking/LwipEthernet/Lwip/src/netif/bridgeif_fdb.o ./src/Networking/LwipEthernet/Lwip/src/netif/ethernet.o ./src/Networking/LwipEthernet/Lwip/src/netif/lowpan6.o ./src/Networking/LwipEthernet/Lwip/src/netif/lowpan6_ble.o ./src/Networking/LwipEthernet/Lwip/src/netif/lowpan6_common.o ./src/Networking/LwipEthernet/Lwip/src/netif/slipif.o ./src/Networking/LwipEthernet/Lwip/src/netif/zepif.o ./src/Networking/LwipEthernet/Lwip/src/core/ipv6/dhcp6.o ./src/Networking/LwipEthernet/Lwip/src/core/ipv6/ethip6.o ./src/Networking/LwipEthernet/Lwip/src/core/ipv6/icmp6.o ./src/Networking/LwipEthernet/Lwip/src/core/ipv6/inet6.o ./src/Networking/LwipEthernet/Lwip/src/core/ipv6/ip6.o ./src/Networking/LwipEthernet/Lwip/src/core/ipv6/ip6_addr.o ./src/Networking/LwipEthernet/Lwip/src/core/ipv6/ip6_frag.o ./src/Networking/LwipEthernet/Lwip/src/core/ipv6/mld6.o ./src/Networking/LwipEthernet/Lwip/src/core/ipv6/nd6.o ./src/Networking/LwipEthernet/Lwip/src/core/ipv4/autoip.o ./src/Networking/LwipEthernet/Lwip/src/core/ipv4/dhcp.o ./src/Networking/LwipEthernet/Lwip/src/core/ipv4/etharp.o ./src/Networking/LwipEthernet/Lwip/src/core/ipv4/icmp.o ./src/Networking/LwipEthernet/Lwip/src/core/ipv4/igmp.o ./src/Networking/LwipEthernet/Lwip/src/core/ipv4/ip4.o ./src/Networking/LwipEthernet/Lwip/src/core/ipv4/ip4_addr.o ./src/Networking/LwipEthernet/Lwip/src/core/ipv4/ip4_frag.o ./src/Networking/LwipEthernet/Lwip/src/core/altcp.o ./src/Networking/LwipEthernet/Lwip/src/core/altcp_alloc.o ./src/Networking/LwipEthernet/Lwip/src/core/altcp_tcp.o ./src/Networking/LwipEthernet/Lwip/src/core/def.o ./src/Networking/LwipEthernet/Lwip/src/core/dns.o ./src/Networking/LwipEthernet/Lwip/src/core/inet_chksum.o ./src/Networking/LwipEthernet/Lwip/src/core/init.o ./src/Networking/LwipEthernet/Lwip/src/core/ip.o ./src/Networking/LwipEthernet/Lwip/src/core/mem.o ./src/Networking/LwipEthernet/Lwip/src/core/memp.o ./src/Networking/LwipEthernet/Lwip/src/core/netif.o ./src/Networking/LwipEthernet/Lwip/src/core/pbuf.o ./src/Networking/LwipEthernet/Lwip/src/core/raw.o ./src/Networking/LwipEthernet/Lwip/src/core/stats.o ./src/Networking/LwipEthernet/Lwip/src/core/sys.o ./src/Networking/LwipEthernet/Lwip/src/core/tcp.o ./src/Networking/LwipEthernet/Lwip/src/core/tcp_in.o ./src/Networking/LwipEthernet/Lwip/src/core/tcp_out.o ./src/Networking/LwipEthernet/Lwip/src/core/timeouts.o ./src/Networking/LwipEthernet/Lwip/src/core/udp.o ./src/Networking/LwipEthernet/Lwip/src/apps/netbiosns/netbiosns.o ./src/Networking/LwipEthernet/Lwip/src/apps/mdns/mdns.o ./src/Networking/LwipEthernet/Lwip/src/api/api_lib.o ./src/Networking/LwipEthernet/Lwip/src/api/api_msg.o ./src/Networking/LwipEthernet/Lwip/src/api/err.o ./src/Networking/LwipEthernet/Lwip/src/api/if_api.o ./src/Networking/LwipEthernet/Lwip/src/api/netbuf.o ./src/Networking/LwipEthernet/Lwip/src/api/netdb.o ./src/Networking/LwipEthernet/Lwip/src/api/netifapi.o ./src/Networking/LwipEthernet/Lwip/src/api/sockets.o ./src/Networking/LwipEthernet/Lwip/src/api/tcpip.o ./src/Networking/LwipEthernet/GMAC/ethernet_sam.o ./src/Networking/LwipEthernet/LwipEthernetInterface.o ./src/Networking/LwipEthernet/LwipSocket.o ./src/Networking/FtpResponder.o ./src/Networking/HttpResponder.o ./src/Networking/Network.o ./src/Networking/NetworkBuffer.o ./src/Networking/NetworkInterface.o ./src/Networking/NetworkResponder.o ./src/Networking/TelnetResponder.o ./src/Networking/UploadingNetworkResponder.o ./src/Movement/StepperDrivers/DriverMode.o ./src/Movement/StepperDrivers/TMC22xx.o ./src/Movement/StepperDrivers/TMC2660.o ./src/Movement/StepperDrivers/TMC51xx.o ./src/Movement/Kinematics/CoreKinematics.o ./src/Movement/Kinematics/FiveBarScaraKinematics.o ./src/Movement/Kinematics/HangprinterKinematics.o ./src/Movement/Kinematics/Kinematics.o ./src/Movement/Kinematics/LinearDeltaKinematics.o ./src/Movement/Kinematics/PolarKinematics.o ./src/Movement/Kinematics/RotaryDeltaKinematics.o ./src/Movement/Kinematics/ScaraKinematics.o ./src/Movement/Kinematics/ZLeadscrewKinematics.o ./src/Movement/HeightControl/HeightController.o ./src/Movement/BedProbing/Grid.o ./src/Movement/BedProbing/RandomProbePointSet.o ./src/Movement/DDA.o ./src/Movement/DDARing.o ./src/Movement/DriveMovement.o ./src/Movement/Move.o ./src/Movement/RawMove.o ./src/Movement/StepTimer.o ./src/Movement/StraightProbeSettings.o ./src/Linux/DataTransfer.o ./src/Linux/LinuxInterface.o ./src/Libraries/sha1/sha1.o ./src/Libraries/sd_mmc/ctrl_access.o ./src/Libraries/sd_mmc/sd_mmc.o ./src/Libraries/sd_mmc/sd_mmc_mem.o ./src/Libraries/sd_mmc/sd_mmc_spi.o ./src/Libraries/Fatfs/diskio.o ./src/Libraries/Fatfs/fattime_rtc.o ./src/Libraries/Fatfs/ff.o ./src/Libraries/Fatfs/ffunicode.o ./src/InputMonitors/InputMonitor.o ./src/Heating/Sensors/AdditionalOutputSensor.o ./src/Heating/Sensors/CpuTemperatureSensor.o ./src/Heating/Sensors/CurrentLoopTemperatureSensor.o ./src/Heating/Sensors/DhtSensor.o ./src/Heating/Sensors/LinearAnalogSensor.o ./src/Heating/Sensors/RemoteSensor.o ./src/Heating/Sensors/RtdSensor31865.o ./src/Heating/Sensors/SensorWithPort.o ./src/Heating/Sensors/SpiTemperatureSensor.o ./src/Heating/Sensors/TemperatureSensor.o ./src/Heating/Sensors/Thermistor.o ./src/Heating/Sensors/ThermocoupleSensor31855.o ./src/Heating/Sensors/ThermocoupleSensor31856.o ./src/Heating/Sensors/TmcDriverTemperatureSensor.o ./src/Heating/FOPDT.o ./src/Heating/Heat.o ./src/Heating/Heater.o ./src/Heating/HeaterMonitor.o ./src/Heating/LocalHeater.o ./src/Heating/RemoteHeater.o ./src/Heating/TemperatureError.o ./src/Hardware/SharedSpi/SharedSpiClient.o ./src/Hardware/SharedSpi/SharedSpiDevice.o ./src/Hardware/SAME70/Ethernet/ksz8081rna/ethernet_phy.o ./src/Hardware/SAME70/Ethernet/GmacInterface.o ./src/Hardware/SAME70/Devices.o ./src/Hardware/SAME70/Main.o ./src/Hardware/ExceptionHandlers.o ./src/Hardware/I2C.o ./src/Hardware/IoPorts.o ./src/Hardware/NonVolatileMemory.o ./src/Hardware/SoftwareReset.o ./src/GPIO/GpInPort.o ./src/GPIO/GpOutPort.o ./src/GCodes/GCodeBuffer/BinaryParser.o ./src/GCodes/GCodeBuffer/ExpressionParser.o ./src/GCodes/GCodeBuffer/GCodeBuffer.o ./src/GCodes/GCodeBuffer/StringParser.o ./src/GCodes/GCodeException.o ./src/GCodes/GCodeFileInfo.o ./src/GCodes/GCodeInput.o ./src/GCodes/GCodeMachineState.o ./src/GCodes/GCodeQueue.o ./src/GCodes/GCodes.o ./src/GCodes/GCodes2.o ./src/GCodes/GCodes3.o ./src/GCodes/GCodes4.o ./src/GCodes/ObjectTracker.o ./src/GCodes/RestorePoint.o ./src/GCodes/Trigger.o ./src/FilamentMonitors/Duet3DFilamentMonitor.o ./src/FilamentMonitors/FilamentMonitor.o ./src/FilamentMonitors/LaserFilamentMonitor.o ./src/FilamentMonitors/PulsedFilamentMonitor.o ./src/FilamentMonitors/RotatingMagnetFilamentMonitor.o ./src/FilamentMonitors/SimpleFilamentMonitor.o ./src/Fans/Fan.o ./src/Fans/FansManager.o ./src/Fans/LedStripDriver.o ./src/Fans/LocalFan.o ./src/Fans/RemoteFan.o ./src/Endstops/Endstop.o ./src/Endstops/EndstopsManager.o ./src/Endstops/LocalZProbe.o ./src/Endstops/RemoteZProbe.o ./src/Endstops/StallDetectionEndstop.o ./src/Endstops/SwitchEndstop.o ./src/Endstops/ZProbe.o ./src/Endstops/ZProbeEndstop.o ./src/Duet3_V06/Pins_Duet3_V06.o ./src/Comms/AuxDevice.o ./src/Comms/FirmwareUpdater.o ./src/Comms/PanelDueUpdater.o ./src/CAN/CanInterface.o ./src/CAN/CanMessageGenericConstructor.o ./src/CAN/CanMotion.o ./src/CAN/CommandProcessor.o ./src/CAN/ExpansionManager.o ./src/Logger.o ./src/OutputMemory.o ./src/Platform.o ./src/PortControl.o ./src/PrintMonitor.o ./src/RepRap.o ./src/RepRapFirmware.o ./src/Roland.o ./src/Scanner.o ./src/Stream.o ./src/Tasks.o -lCoreN2G -lRRFLibraries -lFreeRTOS -lCANlib -lsupc++ -Wl,--end-group -lm
arm-none-eabi-gcc.exe: error: ./src/Endstops/E: No such file or directory
makefile:93: recipe for target 'Duet3Firmware_MB6HC.elf' failed
make: *** [Duet3Firmware_MB6HC.elf] Error 1
"make -j12 all" terminated with exit code 2. Build might be incomplete.21:07:20 Build Failed. 2 errors, 0 warnings. (took 4s.448ms)
I suspect you are using a version of Make that doesn't handle long lines. There are some notes in the Build Instructions on this.
Thanks so much for your response.
It sounds good, so I downloaded the tools again and made sure all the tools are on path. I noticed that the
I even ran them from the DOS window and get the same thing.N:\GitHub\RepRapFirmware\Duet3>make Duet3Firmware_MB6HC.elf
arm-none-eabi-gcc ...
<Really Long Make line>
make: *** [Duet3Firmware_MB6HC.elf] Error 1N:\GitHub\RepRapFirmware\Duet3>which arm-none-eabi-gcc.exe
/n/Program Files (x86)/GNU Arm Embedded Toolchain/10 2020-q4-major/bin/arm-none-eabi-gcc.exeN:\GitHub\RepRapFirmware\Duet3>which make
/n/Program Files/GNU ARM Eclipse/Build Tools/2.6-201507152002/bin/makeN:\GitHub\RepRapFirmware\Duet3>
@dc42 said in Error building RepRapFirmware 3.3-dev:
For the "Instructions for Windows", step 3, Download and install GNU Arm Eclipse, the link is deprecated. There is a link that says "As of 2018-03-19 this project can be found here".
Going to that link "GNU MCU Eclipse (formerly GNU ARM Eclipse)" claims it is also deprecated "DEPRECATED: as of 2020, the project was migrated to the Eclipse Foundation (https://github.com/eclipse-embed-cdt)"
I then went to the Eclipse install software and check everything having to do with ARM. Get the exact same error.
I suggest you install this https://xpack.github.io/windows-build-tools/ if you haven't already, then adjust your PATH so that the version of make.exe from that installation is picked up before any other. You can type "where make" at the Windows command prompt to find out where make is being fetched from.
Yah... I tried several combinations (starting with the ones in the instructions) and finally gave up on Windows.
I installed a Virtual Box with a Ubuntu distribution and got it all working. Just avoided the whole make/rm command line length issue all together.
Thanks
