    Gcode to make LED Light flash on/off repeatedly
    Gcode meta commands
    • EducatingSavvasundefined
      EducatingSavvas
      Hi I'm trying to make a LED flash on and off in a loop during a machine state.
      I have done this in the daemon.g file but noticing a long pause at the end of the part of the script that performs the light switch, while the rest of the daemon.g file is being looped through.
      if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed || !move.axes[3].homed ; if axes 0,1,2 and 3 are not homed do...
      	M42 P2 S0.4
      	M42 P1 S0
      	G4 P200
      	M42 P2 S0
      	M42 P1 S0.4
      	G4 P200
      	M42 P2 S0.4
      	M42 P1 S0
      	G4 P200
      	M42 P2 S0
      	M42 P1 S0.4
      	G4 P200
      elif state.status == "idle"
      	M42 P2 S0
      	M42 P1 S0
      Is there a way of creating a loop outside of the daemon.g file which I could reference to turn on or off with an M98 command, so the flashing light is more consistent?
      • fcwiltundefined
        fcwilt
        Have you considered just using an LED that has a built-in flasher?
        EducatingSavvasundefined 1 Reply Last reply Reply Quote 0
          EducatingSavvas @fcwilt
          @fcwilt Hi Frederick, I'm using a WWRGB LED strip for it's range of colours, so would prefer to achieve this onboard the Duet. Cheers, Savvas
          One alternative is to increase the dwell time to match the time it takes to go through the rest of the code in the daemon.g file - making the flashing seem more consistent.
          • xeratoundefined
            xerato
            If you manage to make, the code work properly? If yes, can you please share the code here?
            dc42undefined xeratoundefined 2 Replies Last reply Reply Quote 0
              dc42 administrators @xerato
              @xerato @EducatingSavvas there is a delay of 10 seconds between consecutive executions of daemon.g. This is to avoid SD card access contention between daemon.g and a file being printed. If you need a smaller delay, put all that code inside a while-loop, and include a shorter delay (e.g. G4 S1) at the end of the loop.
              • xeratoundefined
                xerato @xerato
                @xerato said in Gcode to make LED Light flash on/off repeatedly:
                I just got the same led strips, but I didn't know that it could be complicated to set them up properly. I thought they would have an application like a smart led light bulb, so I just set the time to choose the color. I'm thinking right now of buying other strips from the vont brand. My friend who has these strips told me they have a proper application, so we have no problem setting them up. So if you didn't make the code work let me know, and I will order new strips momentarily.
