Non-heater based temperature alarms for M143
  • Hi, it would be nice to set up non-heater based temperature alarms for things like motors using M143 that aren't tied to a specific heater, only a temperature sensor. It would also be nice to have the option to pause the current print instead of just shutting the printer down on an overheat.
    I know this could probably be done using daemon.g and some meta gcode, but that seems highly inelegant and the code to monitor temperature and fault out is already there for monitoring heaters.
