    duet 2 ethernet connection not available
    Duet Web Control
    • MRJEON
      MRJEON last edited by
      m552 s1 p192.168.1.34
      ok
      Network running, IP address = 192.168.1.34
      m552
      Network is enabled, configured IP address: 192.168.1.34, actual IP address: 192.168.1.34
      ok
      m553
      Net mask: 255.255.255.0
      ok
      m554
      Gateway: 192.168.1.255
      ok
      but...Cannot connect to 192.168.1.34
      in tcp/ipv4 setting
      I matched the subnet mask and gateway, but I can't connect to dwc..
      what's wrong..?
      • ShaneHooper
        ShaneHooper last edited by
        Are you using YAT?
        Try stopping the ethernet with:
        M552 S0 Stops Ethernet
        then
        M552 S1 Starts Ethernet (displays current IP address)
        M552 S1 P0.0.0.0 Sets Dynamic IP (P=desired ip address)
        M552 S1 Pxxxxxx Sets Static IP
        also make sure you're using 2.4Ghz but that might not matter if ethernet
        Machinist / Designer at https://3ddistributed.com/corexy-3d-printer/
        Thingiverse: https://www.thingiverse.com/shanehooper/designs
        • MRJEON
          m552 s0
          Network stopped
          ok
          m552 s1
          ok
          m552 s1 p0.0.0.0
          ok
          ok
          but... I can't connect DWC...
            Phaedrux Moderator @MRJEON last edited by Phaedrux
            @MRJEON said in duet 2 ethernet connection not available:
            Is that really your gateway?
            Typically the gateway would be 192.168.1.1
            The .255 address would be the broadcast address.
            Two addresses that can't be used in your example are 192.168.123.0 and 192.168.123.255 because binary addresses with a host portion of all ones and all zeros are invalid. The zero address is invalid because it's used to specify a network without specifying a host. The 255 address (in binary notation, a host address of all ones) is used to broadcast a message to every host on a network. Just remember that the first and last address in any network or subnet can't be assigned to any individual host.
            Ideally you should set the Duet to use DHCP to obtain an address from your router. Then set the router to reserve that address for the Duet to keep it static.
