    DWC Reports NA for Time Estimates
    Duet Web Control wishlist
    1
    1
    434
    • BMMalundefined
      BMMal
      This is somewhat tied to the thread I created on the Firmware side. https://www.duet3d.com/forum/thread.php?id=2237
      DWC should not report NA for the time remaining estimates once the filament used has met or surpassed the total reported for the print. DWC should still be able to calculate estimated time remaining based on layer time and file progress. It seems that the Firmware already does this properly as it gives an estimate on the Panel Due based on layer time and file progress.
      Duet Ethernet - Most likely the most recent Edge firmware
      Duet X5
      7" Panel Due V2
      Cartesian, 4 Nozzles with Flex3Drives, Heated Chamber, Simple Switch Filament Sensing
