    3.3b1: Can’t pause or cancel file in progress
    Beta Firmware
    1
    1
    125
    • TypQxQundefined
      TypQxQ
      I run 3.3b1 on 6HC+3HC+SBC with DWC3.2.2. While printing, i loose the ability to pause or cancel the current job.
      2021-02-27 17:14:56	M1
      Error: M1: Pause the print before attempting to cancel it
      2021-02-27 17:14:52	M0
      Error: M0: Pause the print before attempting to cancel it
      2021-02-27 17:14:48	M25
      Error: M25: Cannot pause print, because no file is being printed!
      2021-02-27 16:57:08	M122 B1
      Diagnostics for board 1:
      Duet EXP3HC firmware version 3.3beta1 (2021-02-14 16:32:08)
      Bootloader ID: SAME5x bootloader version 2.2 (2021-01-16b1)
      Never used RAM 154784, free system stack 0 words
      Tasks: Move(notifyWait,80) HEAT(delaying,69) CanAsync(notifyWait,72) CanRecv(notifyWait,82) CanClock(notifyWait,74) TMC(notifyWait,30) MAIN(running,207) AIN(delaying,260)
      Last reset 08:56:06 ago, cause: power up
      Last software reset at 2020-11-10 18:16, reason: StackOverflow, available RAM 154112, slot 0
      Software reset code 0x0100 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0000080e BFAR 0xe000ed38 SP 0x2002ffb4 Task � Freestk 4294967295 ok
      Stack: 2000137c 200013b0 0002525d 00000000 0003e418 20001598 20003b28 00000000 00024885 200014b4 20003ab0 00000000 00f00000 e000ef34 c0000000 20003b30 000249c5 0002472c 61000000 ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff
      Driver 0: position 78019, 160.0 steps/mm,  ok, reads 60727, writes 0 timeouts 0, SG min/max 0/1023, steps req 51010289 done 51010128
      Driver 1: position -441066, 160.0 steps/mm,  ok, reads 60726, writes 0 timeouts 0, SG min/max 0/1023, steps req 53426002 done 53425629
      Driver 2: position 35383024, 830.0 steps/mm,  ok, reads 60727, writes 0 timeouts 0, SG min/max 0/1023, steps req 9814045 done 9814008
      Moves scheduled 1552785, completed 1552782, in progress 1, hiccups 0, step errors 0, maxPrep 151, maxOverdue 3, maxInc 1, mcErrs 0, gcmErrs 0
      Peak sync jitter 11, peak Rx sync delay 191, resyncs 0, next step interrupt due in 20 ticks, enabled
      VIN: 24.1V, V12: 12.1V
      MCU temperature: min 39.8C, current 40.0C, max 40.2C
      Ticks since heat task active 14, ADC conversions started 32166756, completed 32166754, timed out 0
      Last sensors broadcast 0x00000002 found 1 19 ticks ago, loop time 0
      CAN messages queued 82129, send timeouts 0, received 428755, lost 0, free buffers 36, min 36, error reg 0
      dup 0, oos 9, bm 0, wbm 0
      2021-02-27 16:57:03	M122 B0
      RepRapFirmware for Duet 3 MB6HC version 3.3beta1 running on Duet 3 MB6HC v0.6 or 1.0 (SBC mode)
      Board ID: 08DJM-956L2-G43S4-6JKDD-3SJ6L-TB62G
      Used output buffers: 1 of 40 (18 max)
      Static ram: 148196
      Dynamic ram: 62796 of which 304 recycled
      Never used RAM 139376, free system stack 118 words
      Tasks: Linux(ready,105) HEAT(delaying,283) CanReceiv(notifyWait,774) CanSender(notifyWait,357) CanClock(delaying,342) TMC(notifyWait,18) MAIN(running,667) IDLE(ready,20)
      Owned mutexes: HTTP(MAIN)
      Last reset 08:55:08 ago, cause: software
      Last software reset at 2021-02-27 08:01, reason: MemoryProtectionFault mmarValid daccViol, GCodes spinning, available RAM 140492, slot 2
      Software reset code 0x0163 HFSR 0x00000000 CFSR 0x00000082 ICSR 0x0444a804 BFAR 0x00000008 SP 0x204327b0 Task Linu Freestk 316 ok
      Stack: 2042efd0 00000063 00000003 00000000 0048ff96 00406dab 00406eb8 61030000 00406d7f 004865b4 20000000 403e0000 204327e8 20432a14 00000106 41f00001 20426e68 00486954 00000001 00000000 20432a14 20432950 00486960 00000000 20432950 00406eeb 2042da88
      Error status: 0x00
      Aux0 errors 0,0,0
      Aux1 errors 0,0,0
      MCU temperature: min 45.1, current 45.6, max 46.3
      Supply voltage: min 31.8, current 31.9, max 32.0, under voltage events: 0, over voltage events: 0, power good: yes
      12V rail voltage: min 12.0, current 12.0, max 12.1, under voltage events: 0
      Driver 0: position 71013, ok, reads 65003, writes 0 timeouts 0, SG min/max 0/1023
      Driver 1: position -608, ok, reads 65003, writes 0 timeouts 0, SG min/max 0/1023
      Driver 2: position 111952, standstill, reads 65004, writes 0 timeouts 0, SG min/max not available
      Driver 3: position 298, ok, reads 65002, writes 0 timeouts 0, SG min/max 0/1023
      Driver 4: position 0, ok, reads 65002, writes 0 timeouts 0, SG min/max 0/1023
      Driver 5: position 0, ok, reads 65002, writes 0 timeouts 0, SG min/max 0/1023
      Date/time: 2021-02-27 16:57:02
      Slowest loop: 47.36ms; fastest: 0.06ms
      === Storage ===
      Free file entries: 10
      DMs created 125, maxWait 0ms, bed compensation in use: mesh, comp offset 0.000
      === MainDDARing ===
      Scheduled moves 1425778, completed moves 1425718, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3
      === AuxDDARing ===
      Heater 0 is on, I-accum = 0.1
      Heater 1 is on, I-accum = 0.0
      Segments left: 1
      Movement lock held by null
      HTTP* is doing "M122 B0" in state(s) 0
      Telnet is idle in state(s) 0
      File* is doing "G1 X197.882004 Y238.949997 E0.019730" in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Queue* is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty.
      === CAN ===
      Messages queued 430408, send timeouts 3051, received 82507, lost 0, longest wait 22ms for reply type 6024, peak Tx sync delay 557, free buffers 49 (min 33)
      === SBC interface ===
      State: 4, failed transfers: 2
      Last transfer: 1ms ago
      RX/TX seq numbers: 51371/38827
      SPI underruns 1, overruns 1
      Number of disconnects: 1, IAP RAM available 0x2d410
      Buffer RX/TX: 2688/128-4080
      === Duet Control Server ===
      Duet Control Server v3.2.2
      File:
      Buffered code: G1 X197.814 Y238.249 E0.01973
      Buffered code: G1 X197.780 Y237.545 E0.01973
      Buffered code: G1 X197.780 Y236.841 E0.01973
      Buffered code: G1 X197.814 Y236.137 E0.01973
      Buffered code: G1 X197.882 Y235.436 E0.01973
      Buffered code: G1 X197.984 Y234.739 E0.01973
      Buffered code: G1 X198.119 Y234.048 E0.01972
      Buffered code: G1 X198.288 Y233.364 E0.01973
      Buffered code: G1 X198.489 Y232.689 E0.01973
      Buffered code: G1 X198.723 Y232.025 E0.01973
      Buffered code: G1 X198.989 Y231.373 E0.01973
      Buffered code: G1 X199.285 Y230.734 E0.01973
      Buffered code: G1 X199.613 Y230.110 E0.01973
      Buffered code: G1 X199.970 Y229.503 E0.01973
      Buffered code: G1 X200.356 Y228.914 E0.01973
      Buffered code: G1 X200.770 Y228.344 E0.01973
      Buffered code: G1 X201.211 Y227.795 E0.01973
      Buffered code: G1 X201.678 Y227.268 E0.01973
      Buffered code: G1 X202.170 Y226.764 E0.01973
      Buffered code: G1 X202.686 Y226.284 E0.01973
      Buffered code: G1 X203.224 Y225.830 E0.01972
      Buffered code: G1 X203.784 Y225.402 E0.01973
      Buffered code: G1 X204.363 Y225.002 E0.01973
      Buffered code: G1 X204.962 Y224.631 E0.01973
      Buffered code: G1 X205.577 Y224.288 E0.01973
      Buffered code: G1 X206.208 Y223.976 E0.01973
      Buffered code: G1 X206.854 Y223.695 E0.01972
      Buffered code: G1 X207.513 Y223.445 E0.01973
      Buffered code: G1 X208.183 Y223.227 E0.01973
      Buffered code: G1 X208.862 Y223.042 E0.01972
      Buffered code: G1 X209.550 Y222.890 E0.01973
      ==> 1460 bytes
      Code buffer space: 2560
      Configured SPI speed: 8000000 Hz
      Full transfers per second: 57.94
      Maximum length of RX/TX data transfers: 4932/1688
      File /opt/dsf/sd/gcodes/RearLeft v6.2.gcode is selected, processing
