    Cannot connect to DWC (wifi) but printer says wifi connecting
    Duet Web Control
    • EricE555undefined
      EricE555
      I have had this up and running a couple of weeks now. At some point I rebooted and ever since I cannot connect to the DWC. When I startup the printer the screen says it connects to wifi but I can't get to DWC.
      I have manually reinstalled RRF and DWC using instructions here https://forum.duet3d.com/topic/9134/can-t-connect-to-dwc ; issuing M997 S0 and M997 S1 through direct connect to computer. No luck.
      Anybody see any issues? What should I try?
      M122 below:
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2.2 running on Duet WiFi 1.02 or later
      Board ID: 0JD0M-9P6B2-NJ4S4-6J1DA-3SD6M-KV1QL
      Used output buffers: 1 of 24 (12 max)
      Static ram: 23460
      Dynamic ram: 73672 of which 24 recycled
      Never used RAM 14924, free system stack 182 words
      Tasks: NETWORK(ready,177) HEAT(blocked,308) MAIN(running,400) IDLE(ready,20)
      Owned mutexes: WiFi(NETWORK) USB(MAIN)
      Last reset 00:02:46 ago, cause: software
      Last software reset at 2021-02-28 05:31, reason: User, GCodes spinning, available RAM 14924, slot 1
      Error status: 0x08
      Aux0 errors 0,0,0
      MCU temperature: min 29.7, current 30.3, max 30.5
      Supply voltage: min 1.6, current 1.7, max 1.8, under voltage events: 0, over voltage events: 0, power good: no
      Driver 0: position 0, ok, SG min/max not available
      Driver 1: position 0, ok, SG min/max not available
      Driver 2: position -1152, ok, SG min/max not available
      Driver 3: position 0, ok, SG min/max not available
      Driver 4: position 0, ok, SG min/max not available
      Driver 5: position 0
      Driver 6: position 0
      Driver 7: position 0
      Driver 8: position 0
      Driver 9: position 0
      Driver 10: position 0
      Driver 11: position 0
      Cache data hit count 278246041
      Slowest loop: 6.79ms; fastest: 0.14ms
      === Storage ===
      Free file entries: 10
      SD card longest read time 3.4ms, write time 0.0ms, max retries 0
      === MainDDARing ===
      Scheduled moves 1, completed moves 1, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
      === AuxDDARing ===
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is ready with "M122" in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      Daemon is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 79.82ms; fastest: 0.00ms
      HTTP sessions: 0 of 8
      • WiFi -
        Network state is active
        WiFi firmware version 1.25
        WiFi MAC address e0:98:06:23:00:4b
        WiFi Vcc 3.40, reset reason Turned on by main processor
        WiFi flash size 4194304, free heap 22704
        WiFi IP address 192.168.0.100
        WiFi signal strength -32dBm, mode 802.11n, reconnections 0, sleep mode modem
        Clock register 00002002
        === Filament sensors ===
        Extruder 0 sensor: ok
        ok
        @EricE555 said in Cannot connect to DWC (wifi) but printer says wifi connecting:
        I thinks it has this IP address. What URL are you trying to connect to in your browser? http://192.1168.0.100 should work, provided your computer is on the same subnet as the Duet. Can you ping that address?
        On your computer open a command prompt window and send ping 192.168.0.100 and post the response Then send ipconfig and post the response.
        • EricE555undefined
          EricE555
          thank you for the reply.
          I cannot ping the address. I don't know networking, my brother does though. I might have to get his help.
          My wifi was not strong enough to reach here reliably so I added a tp-link RE450 in my room with an eithernet plugged in. then I configured it as an access point for the printer. It is up and running fine (as we know because the computer connects to it). It is putting out a wifi with the name 3dprinter. I guess I should try to access that with my computer or phone. I'll post back after I test that.
            It sounds like the Duet is on a different subnet than your computer. The RE450 is probably creating a new network and not bridging between the existing network and it's own wifi network. There might be some settings you can change to allow that.
            Running the Duet in access point mode might be an option, but isn't as convenient.
            • EricE555undefined
              EricE555
              Mystery Solved!
              My switch had gotten bumped and lost power. So my computer happily connected to my wifi and continued to work but had no access to the Access Point that my printer was on because that AP was Ethernet. So now that my computer is back on eithernet and wifi is off, all is well. Whew!
