    Fetching Duet state from Raspberry
    Gcode meta commands
    • No2undefined
      No2
      Hi there,
      I was wondering if there is a way to fetch the current state of the duet from the raspberry (the exact line of GCode that is currently executed would be perfect)
      • chrishammundefined
        chrishamm administrators
        You should be able to use the line property like in echo line or M118 S{"Current line: " ^ line}. It should work both in SBC and standalone mode.
        Duet software engineer
        • No2undefined
          No2
          That's actually the property i was looking for, problem is i dont know how to access the duet console from the raspberry (im using SBC mode), do you have a clue ?
          I am trying to access it in the raspberry, not in the web view console
          • No2undefined
            No2
            Found it :
            i used the Pn parameter to redirect it to USB (P1), from there i just have to read the TTY output on the raspberry and do whatever i want with it
