    variable (height) to calculate average trigger height
    Gcode meta commands
    • appjawsundefined
      appjaws
      I would like to have a variable (height) that would be incremented by the Z probe value, move.axes[2].userPosition, 10 times and then I would need to calculate the average, (height/10) but limit this result to 3 decimal places and then update G31 in the config file.
      How is a variable defined?
      Is this possible? If so could you show an example please.
      Thanks for any help
      appjaws - Core XYUV Duet Ethernet Duex5
      firmware 3.5.0-rc.4 Web Interface 3.5.0-rc.4
      Ormerod 1-converted to laser engraver, Duet wifi
      OpenSCAD version 2024.03.18
      Simplify3D 5.1.2
      • fcwiltundefined
        fcwilt @appjaws
        @appjaws said in variable (height) to calculate average trigger height:
        Thanks for any help
        Currently variables are not implemented.
        You can use existing properties of "dummy" objects that you create.
        You cannot set a property value directly, you have to use a command that will achieve the desired result.
        So if you created, as an example, a dummy axis, A you could use the following to set its userPosition property.
        • Reset to zero: G90 G1 A0
        • Increment by current Z position: G91 G1 A{ move.axes[2].userPosition}
        But I don't know how you would update the trigger height in the G31 command in the config file.
